A Saga, the story of a Schiit upgrade
ALL212
2 words... Wima and clicky.
I’ve replaced the Wima caps with Clarity Cap CMR’s of same value and covered the clicky relays with sound damping.
It will be some time before I can report on any sound changes but the clickyness is much reduced.
Had to use flying leads on the caps and should have mounted one just a tad further from the tube socket.
Not recommended unless you have a lot of patience. Reassembly requires getting 2 lose fit “buttons”, a volume pot and 7 led’s in the right places. Doing that probably took 1/3 of the time of the total project. The 400v clarity cap CMR just barely fits and whatever that height is would be the max size. I’m sure 600v caps would not fit.
It still works!
Before chopping it:
Sound damping applied to the relays:
Caps in place:
Puff back in business:
It still works!
Before chopping it:
Caps in place:
Aaron
Enabler Extraordinaire
Interesting. In the early 90s, the Wima caps were pretty popular with the SE DHT crowd.
As to putting all the stuff together -- I mean, topless might be a good look for that Schiit, you know? Maybe even a bespoke case of some sort...?
Just Schiitballin' here, you know?
Seriously, thanks for sharing and for the phalanx of nice photos!
How are you fixed for 6SN7s for that bad boy (or girl, as the case may be)?
Oh,
Cool dragon!
Puff's been with me for a very long time, close to 40 years now. I believe "Korean glass" was given away as a prize when I was stationed at Clark Air Base in the PI. Couple times a year they would have a carnival on base. I won! Had a couple other pieces and I'm not sure where those went. Maybe broke and gone. Got a thing for dragons and light houses. I have no clue why.
I started my 6SN7 collection when I found you could adapt the 12AU7 socket. Ran them in the BH Crack and when I built the BAC I specifically socketed/wired it for 6SN7. I don't have many - maybe 10. I think what's in the Saga is an RCA black plate. Got any recommendations?Aaron
Enabler Extraordinaire -
Well, none of the hoidy-toidy ones here, but let me check stock
Actually, the Special Red 5692 is awfully cool... and you only need one.
http://www.itishifi.com/2018/07/rca-special-red-tubes.html -
Cool to see my old Saga going under the knife for some upgrades. Good stuff.
Try @mhardy6647's Sylvania chrome dome in it, that's the one I used the most and thought it sounded good. -
I under exaggerated...
I dug up a dozen and a half with what Dave brought over from @Clipdat. I've got a VT-231! Let's roll that one in and stage up the Sylvania Chrome Dome.
No 5692's....might need to go shopping.Aaron
Got that one off eBay but never tried it out! -
Yeah, 6SN7s are sort of like coat hangers. Put 'em in a dark place, wait a while, and they seem to multiply!
That looks like a bountiful bevy of twin triodes to sample
Speaking of 6SN7s -- and I offer this strictly as is and FWIW(!!!)
You'll see why.
http://audiokarma.org/forums/index.php?threads/the-best-6sn7-is-actually-a-pair-of-6j5-gt-6j5-g-l-63.853445/
The natural history of the 6SN7 (which, in fact, culminates with the 12AU7*, essentially a 6SN7, kinda-sorta, in a miniature package) is pretty interesting, and pretty much covers the 'mainstream' commercial history of audio.
Coupla good reads on the topic (in case you're not familiar with them already):
http://vinylsavor.blogspot.com/2014/02/tube-of-month-6sn7.html
http://www.fourwater.com/files/hist6sn7.txt
OK, I'm gonna stop now, before I confuse myself even further
_______________
* or 6CG7 or 6FQ7 or 12BH7, or whatever
Caveat heater voltage and heater current
http://db.audioasylum.com/mhtml/m.html?forum=tubes&n=239653&highlight=6SN7+,+12au7+,6cg7&search_url=/cgi/search.mpl
https://www.diyaudio.com/forums/tubes-valves/278786-tried-12au7-6sn7-adapter.html
https://bottlehead.com/smf/index.php?topic=1144.0 -
oh , and of course, there's the Loktal base 7N7, which (AFAIK) really, truly is a 6SN7 in a slightly different package
http://vinylsavor.blogspot.com/2015/02/tube-of-month-7n7.html
Nice, Aaron.
Was the sound damping just because it was loud and clicky? I thought that was your favorite.
Are the caps bound to the board, like, with hot glue, gum, or a Charleston Chew? Beefy caps, and matching! I was wondering whether the cover would go back on.
That's an interesting transformer. We were talking about that. I've never really seen any that looked like they had separated sections like that, but maybe that's common and just been hidden beneath the cover material in other designs.
What are those six other caps for, and did you ever get your phone connected?
Between this and the recent Asgard from Drew, I'm really becoming interested in the Schiit line. I even learned how to spell it correktlee yesterday. Curious about their Multi-chipped DACs.
I disabled signatures. -
Ah needs me ah adrapter thingy...fer them thar 6J5's...
Problem is it has to clear the hole in the chassis but if that doesn't work I can use it in the BAC.Aaron
Maybe Larry or someone could be contracted to machine that out for you?I disabled signatures.
The clicky's are kinda neat at first but with 10 cents worth of sound damping I've cured my aggravation. Had the chassis open...had the sound damping right there...mostly a no brainer. (which I'm fully qualified for)
New caps got some foam sticky tape applied to them. My "standard" to keep things from moving around yet not hard to remove if needed. Hot glue also works but that stuff can be challenging to remove at times.
The six are very nice Nichicon caps and I'd bet they are power supply filter caps.
My only guess on that transformer is it's...ok...I give...it's interesting.
I think that jack is for tech support so...
I plugged in my phone:
and asked for BR549. I think I got:
She's very knowledgeable!
The wheels are spinning...albeit very slowly due to the frigin cold but that's better than normal...
I need a octal socket extender. Methinks I can handle that.Aaron
two words, Benjamin.
Tin.
Snips.
great... I just ordered an octer slocket tender...
I found socket savers that appear to be what I want. They also have socket extenders for testing but they are not keyed on the top side. I suppose I could grind off that annoying nub...
Aaron
Always love to see your projects! Nice work
I have been a fan of the 6SL7 and 6SN7 Sylvania "chrome domes" for a long time. I use a pair of 1950's JAN CHS 6SL7 WGT's (long base, black plate, sq getter) in an integrated amp along with a quad of 50's RCA gray glass 6V6 power tubes. 14 wpc. Puts you right in the front row, the clarity and soundstage is breathtaking with the right material. Immediacy and effortless w/o ever being strident......one of my favorites for sure!
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Nice work, but relays should not be acoustically coupled. Get your razor blade out, quit half arseing.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »Nice work, but relays should not be acoustically coupled. Get your razor blade out, quit half arseing.
YESSIR...IMMEDIATELY SIR!!
Not...that case is a royal pain. Because it's sound damping maybe I did inadvertently uncouple them?Aaron
I'm just envious of your ambition. Got any round tuits to share? Open bench space?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
You know you’re welcome here anytime? Announced or not I’ve gots lots of brilliant
ideas!
Could use a good opinion on where to go next with the Dave Buffalo dac and a second set of hands...Aaron
Ah jeez... meeting of the minds, tubes, hot metal, beer, tools and all that...
What could happen?
This. This could happen.
Save me a spot!
What could happen?
Save me a spot!
Beer is a great diagnostic aid. If you're wrong, it doesn't matter.
ideas!
That BIII is a great DAC.
I gotta go pick up my 1C's this weekend. I mean Ed's. But soon....like a bad penny, I'll turn up.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Lol. And he needs to shoe horn some shunt regulation in there some how.SCompRacer wrote: »... quit half arseing.
Aaron's been known to build 'outside the box.'
@ALL212 are you using an aftermarket power cord with the Saga?
Yessir. Wireworld ... blue, whatever blue is in wireworldAaron
