^^^ It's pretty.
mhardy6647 wrote: »oops
Does it have, perhaps, have selectable primary voltages on the PT?
alternatively, a big ol' stepdown transformer (at least 300 VA, more would be better) should get the job done.
Or, of course, the sender could just provide a model that was meant for the US market.
Thanks for the insight Doc. So I checked, no dip switches or anything like that. But I found one discernible difference. The US market amp has a jumper, while the new one does not.
Take a chance? Fabricate a jumper (easy) and plug it in?
Well, I reached out again to the seller and he's gonna get back to SVS on Monday.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I can fix that problem
Or alternatively to the above, yes you can come over and put your fingers on the jumper leads, and we'll see what happens!
That's a negatory, good buddy!...
good, good.
I ROCKED some Head East like a BOSS.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Head East... nice.
Just wait and let SVS sort it out, they will make the situation right. -
Thanks Drew! Well, it turns out it was the jumper! The seller reached out to SVS (they're open on Saturday!) and confirmed. So we met up once again, got the jumper, popped it in, and, she's alive!
Running it now on the nearfield setup, see how it goes. So far, so good!
And SVS is gonna mail the seller a label (apparently they use the same backplate) to display the correct voltage.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Well, glad it was a quick fix!
Dave, who discovered the little wire was missing from the new amp?
That was some awesome detective visual scanning powers! I always ask people over my life when they mention something is broken..." did you take the cover off and look inside to see if you could see anything out of place?"
I had a driver under my supervision once and he called me saying his truck is leaking fuel badly. I asked him if he knew where it was leaking from. He said under the cab. I asked him if he lifted the tilting cab up and looked. He said no.
I knew exactly where the leak was 99.99% because I had that happen years before and I fixed it myself. It's just a design flaw on a fuel line. .50 hose replacement and 10 min. + time to go to an auto parts store. I would've even kept a spare hose under the seat if I knew it was a recurring problem but I didn't until that day.
Anyway, I'm also glad somebody spotted that missing jumper and it was a fast and easy fix minus the 3rd trip to meet the guy.
Glad it is up and running for you Dave! How does it sound?
Hi Tony. I noticed the voltage label on the back of the amp, and thought uh-oh, time to pause before I button it up.
Professor @mhardy6647 suggested if there were any switches on the inside to flip it between the 2 voltages.
When I was looking at the guts, I noticed the new amp did not have the jumper, that was the only difference that I could see.
Thanks Dave.
So you had the other old amp there with you to compare?Most people just listen to music and watch movies. I EXPERIENCE them.
joecoulson wrote: »Glad it is up and running for you Dave! How does it sound?
Hi Joe. Sounds great, rocking Juno Reactor right now in the office, but I gotta say, the baby SVS SB12+ digs a bit deeper! I'm gonna reserve my impression for a bit until the new amp breaks in.
Thanks Dave.
Yep. Gonna be a SB12+ vs. PB1000 smackdown!
Can you play Olive's "Falling"? That is a reviewers song to test subs!
At 3:23 the bass digs deep!
https://youtu.be/DyQGKeqWc9M Most people just listen to music and watch movies. I EXPERIENCE them.
“I love the smell of meters in the morning. Smells like .....” This baby went back in one system for awhile. Dennis Miller Mark II mods.
Dennis Miller mods amps? I thought he was a comedian.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Bwahahaha
Can you tell me what I spent the majority of yesterday doing??
Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
nooshinjohn wrote: »Dennis Miller mods amps? I thought he was a comedian.
everybody's a comedian. -
Plotting revenge for Jesse being allowed to return?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Putting the Marantz on a shelf ? or...
Changing the poles on your rack so the upper shelves will be level again?Most people just listen to music and watch movies. I EXPERIENCE them.
You got part of it Tony, what else?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I can't find an older picture of your set-up so I'm puzzled.
How about the OPPO player?
or, the cassette deck on the bottom , maybe?
You're including the TV and it's rack, so maybe there's something new there. Maybe the black piece on the bottom shelf under the TV? It doesn't look like any cable box I've ever seen.
That center channel looks big. Maybe it is a larger one than the one you had before, if you had one before.
Recorded 25 minutes from my house in Pekin Illinois -
Classic CD (Flat as a pancake) that is actually very well recorded.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Cable management and toe in your speakers while listening to them?
