11213151718202
    mhardy6647 Posts: 35,183
    ^^^ It's pretty.
    edited February 2019
    lightman1 wrote: »
    I can fix that problem
    or, perhaps
  • verb
    verb Posts: 10,176
    oops :p
    Does it have, perhaps, have selectable primary voltages on the PT?
    alternatively, a big ol' stepdown transformer (at least 300 VA, more would be better) should get the job done.
    Or, of course, the sender could just provide a model that was meant for the US market. :|
    Thanks for the insight Doc. So I checked, no dip switches or anything like that. But I found one discernible difference. The US market amp has a jumper, while the new one does not.
    Take a chance? Fabricate a jumper (easy) and plug it in? :smile: Well, I reached out again to the seller and he's gonna get back to SVS on Monday.
  • verb
    verb Posts: 10,176
    lightman1 wrote: »
    Or alternatively to the above, yes you can come over and put your fingers on the jumper leads, and we'll see what happens! :smile:
    verb wrote: »
    That's a negatory, good buddy!
    B)
    good, good.
  • steveinaz
    steveinaz Posts: 19,545
    I ROCKED some Head East like a BOSS.
    Head East... nice.
    Clipdat Posts: 13,100
    verb wrote: »
    Just wait and let SVS sort it out, they will make the situation right.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    verb wrote: »
    Thanks Drew! Well, it turns out it was the jumper! The seller reached out to SVS (they're open on Saturday!) and confirmed. So we met up once again, got the jumper, popped it in, and, she's alive! :smile: Running it now on the nearfield setup, see how it goes. So far, so good! :smile:
    And SVS is gonna mail the seller a label (apparently they use the same backplate) to display the correct voltage.
    Well, glad it was a quick fix!
    Tony M Posts: 11,679
    Dave, who discovered the little wire was missing from the new amp?
    That was some awesome detective visual scanning powers! I always ask people over my life when they mention something is broken..." did you take the cover off and look inside to see if you could see anything out of place?"
    I had a driver under my supervision once and he called me saying his truck is leaking fuel badly. I asked him if he knew where it was leaking from. He said under the cab. I asked him if he lifted the tilting cab up and looked. He said no. :s I knew exactly where the leak was 99.99% because I had that happen years before and I fixed it myself. It's just a design flaw on a fuel line. .50 hose replacement and 10 min. + time to go to an auto parts store. I would've even kept a spare hose under the seat if I knew it was a recurring problem but I didn't until that day.
    Anyway, I'm also glad somebody spotted that missing jumper and it was a fast and easy fix minus the 3rd trip to meet the guy. :D
  • joecoulson
    joecoulson Posts: 4,943
    Glad it is up and running for you Dave! How does it sound?
  • verb
    verb Posts: 10,176
    Tony M wrote: »
    Hi Tony. I noticed the voltage label on the back of the amp, and thought uh-oh, time to pause before I button it up.
    Professor @mhardy6647 suggested if there were any switches on the inside to flip it between the 2 voltages.
    When I was looking at the guts, I noticed the new amp did not have the jumper, that was the only difference that I could see. :smile:
    Thanks Dave.
    So you had the other old amp there with you to compare?
  • verb
    verb Posts: 10,176
    joecoulson wrote: »
    Hi Joe. Sounds great, rocking Juno Reactor right now in the office, but I gotta say, the baby SVS SB12+ digs a bit deeper! I'm gonna reserve my impression for a bit until the new amp breaks in. :smile:
  • verb
    verb Posts: 10,176
    Tony M wrote: »
    Thanks Dave.
    Yep. Gonna be a SB12+ vs. PB1000 smackdown! :smile:
    verb wrote: »
    Tony M wrote: »
    Thanks Dave.
    Can you play Olive's "Falling"? That is a reviewers song to test subs! ;):pB):D
    At 3:23 the bass digs deep!
    https://youtu.be/DyQGKeqWc9M
  • joecoulson
    I got a deeper teacher care of @Clipdat
  • dromunds
    dromunds Posts: 10,136
    “I love the smell of meters in the morning. Smells like .....” This baby went back in one system for awhile. Dennis Miller Mark II mods.
    nooshinjohn Posts: 25,973
    Dennis Miller mods amps? I thought he was a comedian.
  • cfrizz
    cfrizz Posts: 13,415
    Can you tell me what I spent the majority of yesterday doing?? :o8ofwzzzyu7ej.jpg
    everybody's a comedian.
    cfrizz wrote: »
    Plotting revenge for Jesse being allowed to return?
    cfrizz wrote: »
    Putting the Marantz on a shelf ? or...
    Changing the poles on your rack so the upper shelves will be level again?
  • cfrizz
    You got part of it Tony, what else?
    I can't find an older picture of your set-up so I'm puzzled.
    How about the OPPO player?
    or, the cassette deck on the bottom , maybe?
    You're including the TV and it's rack, so maybe there's something new there. Maybe the black piece on the bottom shelf under the TV? It doesn't look like any cable box I've ever seen.
    That center channel looks big. Maybe it is a larger one than the one you had before, if you had one before. :)
    pitdogg2 Posts: 27,197
    steveinaz wrote: »
    Recorded 25 minutes from my house in Pekin Illinois
  • steveinaz
    Classic CD (Flat as a pancake) that is actually very well recorded.
  • Willow
    Willow Posts: 11,246
    cfrizz wrote: »
    Cable management and toe in your speakers while listening to them?
