joecoulson wrote: »Man what a great looking listening room.
Kudos [/quotemhardy6647 wrote: »Mike Reeter wrote: »Spiked the 2.3TL's, replaced a defective driver and listened to the immediate improvements via some killer Vinyl, been a Great Day
dang, that's a pretty room.
Thank you, I spend a lotta time in there. One of the few rewards for being old
Took delivery of a pair of brand new black KEF Q150 bookshelf speakers. It's pretty cold outside so I'm letting them acclimate overnight.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
I'm hoping to get a pair in the coming weeks as well.
Be sure to tell us what you think! -
Love your roomMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I took the Joule-Electra out to pop the cover and inventory the power supply caps. The left channel has been cutting out periodically and I’ve been told that these are likely the culprit. No obvious culprit. Now I need to source the appropriate replacement caps. I think I will not touch those in the gain stage at this time. It’s back in the rack and sounds like it always has.
Bummer dude. What are you running as a spare?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
No spare. It works fine when it works. If the left channel cuts out, turning off and on again cures it. This used to happen about once every 10-15 hours, but is now about every other CD or so. If I need to get a spare, I’m thinking Schiit.
mlistens03 wrote: »
I set the speakers up today. They're on 31" Trans Decco speaker stands and the back of the speaker cabinets are 2' from the front wall. Listening at moderate dB levels (63 avg with up to a 75 dB peak) the sound is very satisfying. I was actually thinking of you while listening some classic rock (stuff from the 70's) and I've been pleasantly surprised by these entry level KEF speakers. Some of the songs I'm familiar with cast a very wide soundstage during certain parts of the songs, well outside the speakers. Pretty cool.
I do not find the sweet spot to be as wide as many people claim. There is a point in between the two speakers where everything snaps into focus and that's where I keep my head positioned while listening. These are really only going to give you what's in the recording. I don't notice any coloration to the sound.
I plan to pair a sub with these (if not two) to shore up the bottom end. Since bass isn't a huge concern for you, they may be what you want as-is.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Made some home brew acoustic panels. Easier done than I expected. Hope to finish tomorrow. Gettin' happier by the day!
Unless you are on a tight budget, I would politely suggest to not go with a Schiit preamp. It will be nowhere near the performance level that you are accustomed to with your Joule. -
Thanks, @Clipdat. I honestly don’t think that I’ll need a spare. I’m not planning to send it out unless it stumps both me and a friend who’s been repairing tube equipment for some years as a sideline. He suggested replacement of all caps on the power supply side. None of these look bad, but they are all 25+ years old. I’m hoping to find exact replacements and either put them in myself or have him do it.
Not intending to derail this thread, but have you heard either of the Schiit preamps? -
Minor tweak for better cable management. Gold plated RCA right angle adapters. For the Bottlehead amp, whose RCA terminals point straight up!
I ordered some right angle adapters. @verb thanks for the inspiration. -
Tom......helping Club Polk members spend their hard earned money!
Carry on Polkster's...
Shut up Tom.....
Oh, you are just jealous. Go pee in a bush or somethin' ya' goat lovin' redneck.
Said with the utmost of respect, of course...
Yes, I used to own the Saga. -
Going to give these resistors a try in the 2.3TL.
Two Path Audio .5 ohm 10W
Four 22.5 ohm Vishay 50W wire wound.
The speakers sound good, but mainly just curious.
Ok I'll bite. Whats the extra lead for in the .5 ohms?
My next will be Duelands -
They are there to confuse the crap out of the bomb squad when they need to figure out which wire to cut.
Well worked fer me
From what I've gathered, the extra lead doesn't need to be attached, but offers added shielding from interference.
According to the manufacturer....
""......for ultimate mechanical stability and the shielding advantages it's putted into the copper tube and flooded with the best quality resin. The use of copper tubing allows to drain interferences and this is why we used the third long leadout. It's connected only to the casing, having no contact with the signal transmitted by the resistor. The third leadout should be joined to the ground or "-" speaker input."
I did not connect the lead, I will let it play for a few days then connect to one of the input "-" terminals.
I've gone round robin with some different resistors for the last month. I had a set of Duelund CAST, of course the mills 12W, tried a Mundorf Supreme .5 ohm, Mundorf MoX.
The mills are smooth, but paired with the Clarity CMR, I thought the Duelund CAST was more transparent but the Duelund's seem to have a slight brightness to them, can also get a little edgy on the higher notes.
The Mundorf Supreme .5 ohm paired with the CAST 22.5 still was a tad bright. I even tried a .56 ohm Mills 12W and that seemed to tame the brightness a little paired with the 22.5 CAST. Even then there was still something amiss, and it was starting to lead me down a possible preamp upgrade.
Granted this is with my gear so YMMV.
With the .5 ohm Path and the 22.5 Vishays....seems a bit of magic has happened. The tweeter network is much smoother and what seems to be a bit more transparent albeit very well controlled. Even with no time on them, I'm liking them right out of the gate. The lower end of the high pass is very smooth, I was going to clean up the work table but ended up listening to this setup for almost 2 hrs.
The highs don't get out of control, very smooth and natural. There's a bit of added midrange smoothness and I don't know where it came from...perhaps the highs aren't as coloring as before, not sure, but it's a very nice blend.
I'll give them a few days but so far it's the best combination of resistors I've tried. -
I'm a fan of that style of wire sound resistor, I've used the mills mrc50 in place of duelund many times
Good to experiment!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Built another amp stand today!
I like it -- a good notch above my amp stand aesthetics and construction values
DSC_0630 by Mark Hardy, on Flickr -
Oh, I pulled the hk770 out and hooked up a Yamaha CR2020 in what may be a last ditch attempt to wake up the rather dynamically torpid (albeit pleasant) ELACs.
Ok I want two of these please delivered for pickup at AXPONA. Thank You Dave. -
Easy peasy Joe!
Legs are prefab, and have threads on the bottom for spikes eventually. The tops are pre-cut butcher block. I chose 1.5" thick oak. Just gotta attach the legs with screws, and done!
Good deal. I’ll have my truck with me so that sounds great. Thanks man
Timber Nation is a good source for specific sizes, wood types, and even stained blocks2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Just hooked this up yesterday. Waiting for my 10.5" reels to arrive. Played some 7" 2-track 7.5 ips tapes and like what I'm hearing so far.
