134689202
  • Mike Reeter
    Mike Reeter Posts: 4,315
    joecoulson wrote: »
    Man what a great looking listening room.
    Kudos [/quote
    Spiked the 2.3TL's, replaced a defective driver and listened to the immediate improvements via some killer Vinyl, been a Great Day ;)
    dang, that's a pretty room.
    Thank you, I spend a lotta time in there. One of the few rewards for being old ;)
  • halo
    halo Posts: 5,618
    Took delivery of a pair of brand new black KEF Q150 bookshelf speakers. It's pretty cold outside so I'm letting them acclimate overnight.
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
  • mlistens03
    mlistens03 Posts: 2,767
    halo wrote: »
    I'm hoping to get a pair in the coming weeks as well. :)
    Be sure to tell us what you think!
  • machone
    machone Posts: 1,561
    Love your room
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • maxward
    maxward Posts: 1,710
    I took the Joule-Electra out to pop the cover and inventory the power supply caps. The left channel has been cutting out periodically and I’ve been told that these are likely the culprit. No obvious culprit. Now I need to source the appropriate replacement caps. I think I will not touch those in the gain stage at this time. It’s back in the rack and sounds like it always has.
  • verb
    verb Posts: 10,176
    maxward wrote: »
    Bummer dude. What are you running as a spare?
  • maxward
    No spare. It works fine when it works. If the left channel cuts out, turning off and on again cures it. This used to happen about once every 10-15 hours, but is now about every other CD or so. If I need to get a spare, I’m thinking Schiit.
  • halo
    halo Posts: 5,618
    mlistens03 wrote: »
    halo wrote: »
    I set the speakers up today. They're on 31" Trans Decco speaker stands and the back of the speaker cabinets are 2' from the front wall. Listening at moderate dB levels (63 avg with up to a 75 dB peak) the sound is very satisfying. I was actually thinking of you while listening some classic rock (stuff from the 70's) and I've been pleasantly surprised by these entry level KEF speakers. Some of the songs I'm familiar with cast a very wide soundstage during certain parts of the songs, well outside the speakers. Pretty cool.
    I do not find the sweet spot to be as wide as many people claim. There is a point in between the two speakers where everything snaps into focus and that's where I keep my head positioned while listening. These are really only going to give you what's in the recording. I don't notice any coloration to the sound.
    I plan to pair a sub with these (if not two) to shore up the bottom end. Since bass isn't a huge concern for you, they may be what you want as-is.
  • Dr_Wu
    Dr_Wu Posts: 356
    Made some home brew acoustic panels. Easier done than I expected. Hope to finish tomorrow. Gettin' happier by the day!
    Clipdat Posts: 13,100
    maxward wrote: »
    Unless you are on a tight budget, I would politely suggest to not go with a Schiit preamp. It will be nowhere near the performance level that you are accustomed to with your Joule.
  • maxward
    Thanks, @Clipdat. I honestly don’t think that I’ll need a spare. I’m not planning to send it out unless it stumps both me and a friend who’s been repairing tube equipment for some years as a sideline. He suggested replacement of all caps on the power supply side. None of these look bad, but they are all 25+ years old. I’m hoping to find exact replacements and either put them in myself or have him do it.
    Not intending to derail this thread, but have you heard either of the Schiit preamps?
  • indyhawg
    indyhawg Posts: 1,673
    verb wrote: »
    Minor tweak for better cable management. Gold plated RCA right angle adapters. For the Bottlehead amp, whose RCA terminals point straight up! :smile:
    I ordered some right angle adapters. @verb thanks for the inspiration.
    treitz3 Posts: 20,069
    Tom......helping Club Polk members spend their hard earned money!
    Carry on Polkster's...
  • lightman1
    lightman1 Posts: 10,797
    Shut up Tom.....
    Oh, you are just jealous. Go pee in a bush or somethin' ya' goat lovin' redneck.
    Said with the utmost of respect, of course...
    maxward wrote: »
    Yes, I used to own the Saga.
  • gmcman
    gmcman Posts: 1,858
    Going to give these resistors a try in the 2.3TL.
    Two Path Audio .5 ohm 10W
    Four 22.5 ohm Vishay 50W wire wound.
    The speakers sound good, but mainly just curious.
    pitdogg2 Posts: 27,199
    edited January 2019
    gmcman wrote: »
    Ok I'll bite. Whats the extra lead for in the .5 ohms?
    My next will be Duelands
    nooshinjohn Posts: 25,973
    edited January 2019
    gmcman wrote: »
    They are there to confuse the crap out of the bomb squad when they need to figure out which wire to cut.
    Well worked fer me :p
  • gmcman
    gmcman Posts: 1,858
    edited January 2019
    From what I've gathered, the extra lead doesn't need to be attached, but offers added shielding from interference.
    According to the manufacturer....
    ""......for ultimate mechanical stability and the shielding advantages it's putted into the copper tube and flooded with the best quality resin. The use of copper tubing allows to drain interferences and this is why we used the third long leadout. It's connected only to the casing, having no contact with the signal transmitted by the resistor. The third leadout should be joined to the ground or "-" speaker input."
    I did not connect the lead, I will let it play for a few days then connect to one of the input "-" terminals.
    I've gone round robin with some different resistors for the last month. I had a set of Duelund CAST, of course the mills 12W, tried a Mundorf Supreme .5 ohm, Mundorf MoX.
    The mills are smooth, but paired with the Clarity CMR, I thought the Duelund CAST was more transparent but the Duelund's seem to have a slight brightness to them, can also get a little edgy on the higher notes.
    The Mundorf Supreme .5 ohm paired with the CAST 22.5 still was a tad bright. I even tried a .56 ohm Mills 12W and that seemed to tame the brightness a little paired with the 22.5 CAST. Even then there was still something amiss, and it was starting to lead me down a possible preamp upgrade.
    Granted this is with my gear so YMMV.
    With the .5 ohm Path and the 22.5 Vishays....seems a bit of magic has happened. The tweeter network is much smoother and what seems to be a bit more transparent albeit very well controlled. Even with no time on them, I'm liking them right out of the gate. The lower end of the high pass is very smooth, I was going to clean up the work table but ended up listening to this setup for almost 2 hrs.
    The highs don't get out of control, very smooth and natural. There's a bit of added midrange smoothness and I don't know where it came from...perhaps the highs aren't as coloring as before, not sure, but it's a very nice blend.
    I'll give them a few days but so far it's the best combination of resistors I've tried.
    VR3 Posts: 29,520
    I'm a fan of that style of wire sound resistor, I've used the mills mrc50 in place of duelund many times
    Good to experiment!
    mhardy6647 Posts: 35,184
    I like it -- a good notch above my amp stand aesthetics and construction values :)
    25596703847_f34edc1222_h.jpgDSC_0630 by Mark Hardy, on Flickr
    Oh, I pulled the hk770 out and hooked up a Yamaha CR2020 in what may be a last ditch attempt to wake up the rather dynamically torpid (albeit pleasant) ELACs.
  • joecoulson
    joecoulson Posts: 4,943
    verb wrote: »
    Built another amp stand today!
    Ok I want two of these please delivered for pickup at AXPONA. Thank You Dave.
  • verb
    verb Posts: 10,176
    Easy peasy Joe! :smile: Legs are prefab, and have threads on the bottom for spikes eventually. The tops are pre-cut butcher block. I chose 1.5" thick oak. Just gotta attach the legs with screws, and done! :smile:
  • joecoulson
    Good deal. I’ll have my truck with me so that sounds great. Thanks man :p
    txcoastal1 Posts: 13,518
    Timber Nation is a good source for specific sizes, wood types, and even stained blocks
  • Jetmaker737
    Jetmaker737 Posts: 1,123
    Just hooked this up yesterday. Waiting for my 10.5" reels to arrive. Played some 7" 2-track 7.5 ips tapes and like what I'm hearing so far.
