2 ch pre with ht bypass
Willow
Willow Posts: 10,474
Help me understand this. I'd like to get better 2ch reproduction but I require to keep ht avr for connections to the TV. Without spending an arm and leg what and which brands should I look for?
TV room- B&W 703, SVS PB10 NSD, Marantz NR1607, Parasound 1500a, Pro-Ject Debut Carbon (Yellow) with Acrylic platter, Pro-Ject phono pre, MIT AVT 2 speaker cables, MIT AVT 1 and AVT 2 ICs, XLO Jumpers, Signal Dig Coax, Signal Cable Magic Power Cables x3, Samsung QN75Q7DR Qled 75" tv, Harmony 1100, Sony BDP-S6200, Marantz DV-4200 (as Transport), Cambridge Audio DAC Magic100, Monster 3600MKII, Nintendo Switch and Xbox 360 Family room Samsung 55JS7000 Android Mi Box3 and Apple TV, Polk Magnifi Max. - Pool /Gazebo Yamaha RX-A1010, Polk Patio 25x4, Rotel RDV 1045 (as CDP) MIT AVT3 ICs - Work - Spotify Premium, Neutron App or Amazon Music to my FiiO Kunlun into my Grado SR125e
    tonyb Posts: 32,449
    all depends, what price bracket are you looking in ?
  • Gerres26
    Gerres26 Posts: 803
    How much are you looking to spend? My Musical fidelity A5 integrated amp had ht bypass, as does my McCormack RLD-1 preamp. I believe the Parasound P5 also has this feature.
  • Willow
    Well how does it work? Could I still use my current avr and just buy a new pre? I don't have a budget in mind I'm just doing some leg work right now. I'd be looking used for sure.
  • rooftop59
    rooftop59 Posts: 7,315
    Do you have a separate amp or just the avr?
    Living Room 2.1: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Musical Fidelity A308; NAD M51 DAC; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
    Game Room HT: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology Power Monitor 700 x3; Definitive Technology StudioMonitor 350; Definitive Technology ProMonitor 800; Sub - HSU VTF-2 MK5
    Master Bedroom
  • Willow
    Separate amp
  • rooftop59
    What sources do you want to run through the pre?
    Master Bedroom
  • Willow
    My tt and cdp
    VR3 Posts: 25,084
    You don't exactly need ht bypass. You can run the pre outs to any input, you just have to pick a volume level to calibrate to and always select that input and volume when using the HT.
    Otherwise ht bypass simply disables the volume when selected as the input.
    - Not Tom
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
  • rooftop59
    edited January 2019
    So assuming you get a pre with enough inputs, instead of using the preouts from the AVR to go directly to your amp, you would go into the HT bypass analog input on the PRE. You would need another input for the turntable, and then if the PRE has a DAC, you could run the CDP into either an analog or digital input. Then run out of the pre into the amp.
    BUT, assuming you have enough HDMI inputs on your TV and an optical output from the TV, there is no reason for you to keep the AVR. Run your video sources into the tv, and then an optical cable out of the TV into either an external DAC or a pre with built in DAC. I have had several marantz AVRs are really like them, but their DACs can't touch even something like my old Arcam rDAC or the DACs in my peachtree, much less a nice dedicated DAC.
    So, you have a lot of options, but if you are going to go this route I would probably just sell the AVR. Then you don't need HT bypass and you have several options:
    1. buy a pre with no DAC and then buy an external DAC and use the parasound
    2. buy a pre with built in DAC and use the parasound
    3. buy an integrated amp with no DAC and buy an external DAC sell the parasound
    4. buy an integrated amp with DAC and sell the parasound
    @steveinaz has loved his benchmark DACs which can be used as a pre. I would oook into an option like that, and keep the parasound. He basically does what I am describing in the second paragraph...
    Master Bedroom
  • rooftop59
    VR3 wrote: »
    If you have a Non-techie spouse and especially young children, you DO need HT bypass in that scenario. Otherwise you will constantly hear screaming "the volume doesn't work!" or "how do you turn this s#!t down?!?"
    Master Bedroom
  • Willow
    edited January 2019
    I'm using an external dac and I have a 7 and 6 year old. I'd like to keep my avr. So I need to look for a 2ch pre with ht bypass....
  • rooftop59
    The Benchmark DAC2 will still fit the bill, but would render your DAC moot. You could buy it and sell the DAC I suppose...
    Honestly not sure how many pure pres with HT bypass are out there that aren't 4 digits??? Budget is key here...
    Master Bedroom
    VR3 Posts: 25,084
    Odyssey candela can be found used under 1k
    - Not Tom
    tonyb Posts: 32,449
    You don't necessarily need a pre with a HT by-pass function. Look for a line level pre amp, tubed preferably, without the volume control.
    For instance, my Joule LA-100 is a good example. Just run the front pre-outs from the avr to an input on the pre, pre's outputs to the amp and your golden. Have it hooked up like that myself and works fine.
  • rooftop59
    tonyb wrote: »
    Is it possible to take the avr out of the chain for pure two channel with that setup Tony?
    Master Bedroom
  • halo
    halo Posts: 5,612
    I was using the HT Bypass feature on my Cary when I was using the Marantz NR1403. So, the TV sources like Roku, Blu-ray, and Cable box were all connected via HDMI to the Marantz AVR. The HDMI output on the Marantz went into the HDMI 1 input on my TV. When I was using a center channel speaker, the Marantz drove the center channel speaker only (I didn't have surround speakers in the apartment, if I did the Marantz would drive those as well). The pre outs on the Marantz were connected to the Stereo/2-channel preamp's HT Bypass inputs. The Stereo/2-channel amp drove the main L & R speakers.
  • joecoulson
    joecoulson Posts: 4,944
    PS Audio Stellar Gain DAC Pre - works like a champ for EXACTLY what you are asking as I have the same type of setup
    Underwood HIFI had it for a stupid deal but you need to call them for it
    I am very happy with mine, changed the 2ch game completely
    tonyb Posts: 32,449
    rooftop59 wrote: »
    tonyb wrote: »
    Yes, that's exactly why you connect it that way. Your musical source is connected to the pre amp, not the receiver.
  • rooftop59
    tonyb wrote: »
    rooftop59 wrote: »
    tonyb wrote: »
    But don’t you have two different volume knobs competing? Like watching tv goes through the avr volume out to the pre and through it’s volume out to the speakers? My family could never figure that out lol...
    Master Bedroom
    tonyb Posts: 32,449
    rooftop59 wrote: »
    tonyb wrote: »
    rooftop59 wrote: »
    tonyb wrote: »
    The line level pre doesn't have a volume knob. You use the volume on your source component for music, the volume knob on the receiver for movies.
  • rooftop59
    tonyb wrote: »
    rooftop59 wrote: »
    tonyb wrote: »
    rooftop59 wrote: »
    tonyb wrote: »
    Ah I see...that’s the problem. Can’t use it with components with no volume control like the bryston or a record player...
    Master Bedroom
  • WLDock
    WLDock Posts: 2,966
    edited January 2019
    Tons of option in the new and used $500 -$1.5k range. However, if you want something new for cheap, the Parasound Zpre3 has a bypass and is $349.
    https://www.audioadvisor.com/prodinfo.asp?number=PAZPRE3
    Office | LG 29UB55 21:9 UltraWide | MacBook Pro | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
  • WLDock
    WLDock Posts: 2,966
    edited January 2019
  • Willow
    WLDock wrote: »
    This one Seems about right. Don't want to spend too much on it right now.
    tonyb Posts: 32,449
    tubes bro, ya need toooobs ! :)
    nooshinjohn Posts: 23,202
    Or a Pass Labs X1.. Last preamp you will ever buy. :p
    The Gear... Carver "Statement" Mono-blocks, Arcam AVR30, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules Polk audio AB800 "in-wall" surrounds.
    In retirement...TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Statement V2 cartridge and Origin Conqueror Mk3c tonearm, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII,
    “Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell
    “If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • WLDock
    WLDock Posts: 2,966
    Willow wrote: »
    WLDock wrote: »
    So, you do have a limited budget...I understand very well.
    Like tony said, Tubes would be cool but new is going to be tough. Used Jolida Fusion, Peachtree, etc. Here's a used Quicksilver Audio Line Stage tube pre for $575:
    https://www.usaudiomart.com/details/649467552-quicksilver-audio-line-stage-preamplifier/images/2017724/
    These have HT bypass option for $50 addl. new so maybe that used one has it or it can be sent in and added?
    http://quicksilveraudio.com/products/line-stage-preamp/
    DSkip wrote: »
    Pass does make some good preamps. Wish I liked his power amps more than I do.
    Everybody knows power amps are all the same. >:):p;)
  • joecoulson
    I’ll Pass on that argument
  • Willow
    WLDock wrote: »
    Willow wrote: »
    WLDock wrote: »
    Had I not had to drop almost 500 on repairs to a vehicle yesterday... was driving and heard a huge bang. Stepped on the gas and the rav sounded like a 16 year olds Honda civic. New exhaust, muffler and pipes and oil change. Trying to keep it for another 3 years while we pay for the rdx. Anyway thanks for all the info and perhaps I'll wait until tax refund time and splurge a bit more.
