DSW Pro 440wi Power cord wiggles loose
My Polk DSW Pro 440wi power cord gets loose often shutting the subwoofer off. Guess I will have to tape it on somehow. More elegant solution?
Answers
  • ken brydson
    ken brydson Posts: 9,063
    jklangen99 wrote: »
    Spread out the prongs...
  • gimpod
    gimpod Posts: 1,793
    Yes, one idea hard wire it.
  • verb
    verb Posts: 10,176
    jklangen99 wrote: »
    It's a friction fit, so a layer of electrical tape around the plug should do the trick. Elegance is preserved if you use black tape of course! :smile:
  • verb
    verb Posts: 10,176
    Oh, and welcome to CP! :smile:
  • jklangen99
    So the black tape fixed the perceived problem of the power staying on. I say perceived because of the following. I am now seeing the unit go into standby mode in the Auto mode. It stays on in the On mode. I have the crossover set at 90Hz on the Yamaha 475 AV receiver. I have Polk TL350 5 speaker satellite / center. I can't detect the sub listening to a TV audio source. I could the other day listening to a dvd after wiggling the power cord. Of course, the setup is over 5 years old bought in 2013.
  • monepolk
    monepolk Posts: 1,154
    I have found that dialogue heavy content may not have enough bass to keep my DSW 550 on when in the auto mode.
