AVR Needed
kevhed72
Something decent with HMDI in and out.... plus audio and video RCA connections in and out. Im trying to set up a system for my sun and my integrated wont cut it. Thanks!
Not an offer to sale any of ours, but we have had great luck with Yamaha brand in particular.
From one entry level one about 5 years old and up to an Aventage Series also.
Both have very decent sound with the Aventage being slightly better and for sure more RCA outputs and so on.
Personal fan of the Yamaha Aventage Series, but also check out Marantz and Denon. Also nice to have preouts should you want to add external amp later. Check out https://www.accessories4less.com/ .Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
Good idea on thw pre outs...then I can give him my amp and rationalize the Butler amp I always wanted. Purchases are always easier to justify when your children somehow benefit
What is funny, we insisted on the pre-outs with the Aventage receiver, but have not used them at all yet!
I think the internal amp is really decent sounding on ours,as far as clean and neutral sound, but if one needed really high power for each channel, for sure separates might benefit at times. -
Well I cheaped out on the pre outs since there was an open box Yamaha RX V385 and I am a sucker for open box deals. So here's the current setup w a pair of Boston Acoustics A70 speakers. Here got a Pangea stand for Christmas since the old stand was scaring us. Here is a pic:
The Best Buy expereince was what you would expect, which was annoying. They were carrying the newest 4K Rocketfish banana plugs for 40 bucks, which were sweet looking I would have taken a pic but just wanted to get out of there.
Ditto on Yamaha. I’m a huge fan. I had a AVR I bought as a demo at Best Buy for $250. I don’t remember the model number. It was a work horse, had a ton of inputs, and sounded great. I gave it away but wish I hadn’t. I’d use it for a basement setup if I still had it. Now I have the 11.2 channel CX-A5100 pre/pro and MX-A5000 amp. Sounds amazing.2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV. -
For future reference, Costco has the Yamaha TSR-7850 7.2-Channel Network AV Receiver for $489 currently. It was priced at $399 during the holidays. Member only price.
https://www.costco.com/Yamaha-TSR-7850-7.2-Channel-Network-AV-Receiver.product.100456240.html"Sometimes you have to look to the past to understand where you are going in the future"
Harry / Marietta GA -
After reading several comments bashing AVR's, we got one for a 2nd system that was mostly video, handful of years back.
It was not a revelation in great sound exactly, but completely listenable, clean and neutral, and simply far better than the anti AVR comments would lead us to believe.
Maybe Yamaha has a better sound that some AVR's, but have not owned every brand or iteration to really make that comment stick, but they do sound quite nice! -
For the most part.... anti-AVR comments are usually reserved for when users say they favor music over HT. What else would would you use for an admittedly "mostly video" application? -
I use my Yamaha RX- A1030 for both HT and music, not the best for music I will admit but very good overall I would buy it again.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
mdaudioguy wrote: »Ditto on Yamaha. I’m a huge fan. I had a AVR I bought as a demo at Best Buy for $250. I don’t remember the model number. It was a work horse, had a ton of inputs, and sounded great. I gave it away but wish I hadn’t. I’d use it for a basement setup if I still had it. Now I have the 11.2 channel CX-A5100 pre/pro and MX-A5000 amp. Sounds amazing.
Boat anchor? Just throwing ideas out there2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »mdaudioguy wrote: »Ditto on Yamaha. I’m a huge fan. I had a AVR I bought as a demo at Best Buy for $250. I don’t remember the model number. It was a work horse, had a ton of inputs, and sounded great. I gave it away but wish I hadn’t. I’d use it for a basement setup if I still had it. Now I have the 11.2 channel CX-A5100 pre/pro and MX-A5000 amp. Sounds amazing.
There are some AVRs that could probably anchor a small boat. Not many, but some. Of course, once you figure out if they're adequate as boat anchors, they're probably not much good as AVRs anymore... That's the conundrum. -
There is nothing wrong with using an AVR for AV............In fact I haven't yet figured out how to do it without one.
What are the "high fidelity" options instead of using an AVR? I assume you can get three audiophile amps for the front, center and rear speakers........but what do you use for the surround sound decoding? Specifically for the pro logic decoding when listening to TV shows? What kind of audiophile grade AV preamp do you use?
And how many remotes does it take to switch the channels /inputs? -
The boat anchor comment was a joke
And yes you need a processor i.e. pc or AVR for movie decoding2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
ayre had a 6 channel av power amp, (discontinued) that was base 3 channel at $8.5k and you could add the other three channels at $1200 per channel. it makes a great two channel amp when configured that way. it has three power suplies.
https://www.youtube.com/watch?v=Ov7UcJau5TUAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
We have done audio/video using complete separates, and liked the sound a lot, but found the convenience and usability factors (if one is truly honest) to be lacking.
Add in the fact that you simply have so much stuff (physically) sitting there and connected, it does not create the most sleek or visual look.
Not to mention remotes or Lack of remotes with separates.
Also the lack of sub crossover and adjustments from the seating area takes a toll on adjustability.
We were totally against an AVR originally, but had owned many stereo receivers, and separates but not until using an AVR did we discover the flexibility and control it offers.
I have a couple of AVRS-Yamaha and Pioneer Elite I'm selling to raise some cash. I'm the original owner of both. PM for details.
It's called a HT pre/pro. Anthem or Cary, Krell, Classe, even Outlaw makes a decent one that sounds good. You'd be surprised at the 2 channel sound from the higher end pre/pro's.
Also, there's injecting a pre-amp into the mix for 2 channel between the AVR and amp. You connect the music sources to the pre amp instead of the AVR. That way the AVR never gets turned on for music.HT SYSTEM-
lsi 9's -
I've got 2 AVRs for sale in the FS thread that might be of interest.
I have a Marantz NR1403 that I'm not using. Pre-outs for the main L + R. Darn nice little receiver.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Sure looks like the OP already acquired an AVR folks...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer
