Dreadnought Case Interest Check...
So with the Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers I figured I would start a new thread to see who is all going to be wanting one, and see if it's going to be worth running them, I will do my best to keep the same cost as the last runs, but aluminum has gone up since the tariffs as well as Black Anodizing that I would use for the side panels..
My thought is if cost becomes an issue, and to keep cost down we could cut out the Black Anodizing for the side panels and just Powder Coat them a Smooth Black, and keep the case a Texture Black, that way we still have the contrast with the two colors, let me know your thoughts on this, if everyone is okay with this it shouldn't be a problem on cost as I can have the powder done in house, and cut out the outside process..
The cost on the last run's was $100 shipped...
Reminder: If you already have one of my cases, they fit both the 800va and the 1000va, so if you are just upgrading to the 1000va there is no need to buy another case if you don't want to...
«13
    pitdogg2 Posts: 27,122
    edited January 2019
    Count me in Larry.
    Thanks for your time and expertise
    I'm good with the powder coat to keep cost down as well.
  • BC6
    BC6 Posts: 109
    I'm in. Thanks!
    2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
    HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV.
  • Manticore
    Manticore Posts: 408
    Count me in also. Black Anodized sounds great!! Either way in.
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • ThomasD
    ThomasD Posts: 260
    @Toolfan66
    Your tentative cost of $100 is more than fair and not a concern to me. If a pair of qualifying SDA's present themselves, the positioning of the 'Dreadnought' in my system would be in a visually dominating location and basically 'on display'. I'd probably be looking at having the case engraved and some custom grey anodizing to more closely match my 'Carver' gear. Is just the natural, un-textured aluminum finish an option? Thanks
    Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
  • Gerres26
    Gerres26 Posts: 874
    Larry, do you have any pics of the last run you did? Anodized does sound nice but not if it runs the cost up too high.
  • RobbyKY
    RobbyKY Posts: 117
    The black anodizing on the end panels from the last run is a beautiful contrast to the powder coat on the body. Hard to capture black on black with a simple iPhone. And yes, I've not gotten around to sourcing out some decent knobs for the spikes yet...
    I would consider a grey version if you could match the old Carver gear like ThomasD suggested as this next unit will operate with a set of Carver M-4.0t amps but I'm perfectly happy with whatever the group direction is. Of course, Bob couldn't match colors himself between production runs so picking which version of "Carver Grey" would be a monumental task without a specific sample I would think?? My current dreadnought operates with a set of TFM-55's that are black and I bought a new black faceplate for the C-1 preamp off the 'bay to be all matchy/matchy.
    Put me down for one (1) case this go-round please!!
    Robby
    Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
    Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
    Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
    Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
    Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
    Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
    HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB
  • lightman1
    lightman1 Posts: 10,797
    In for one case. Thanks Larry!
    audioluvr Posts: 5,956
    I'm in for a plain one.
  • As long as I got in on the transformer buy, I'm in for one of these.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • daddyjt
    daddyjt Posts: 3,103
    In for one (1) please. I have one of your other (silver sides) cases, and it is top notch. I am not concerned about finish/color on this one.
    ― Aleksandr Solzhenitsyn
    RobbyKY wrote: »
    Robby
    Let it be known that the outrigger feet are NOT included
  • ThomasD
    ThomasD Posts: 260
    What?! That may be a deal breaker!! ;);)
  • RobbyKY
    RobbyKY Posts: 117
    Nope, those are 80/20 "10 Series" 4199 pivot arm parts. I use a lot of their stuff and had these laying around. The small ones are about $5 each but they show out of stock on Amazon lately. Just bought some direct so still in production.
    You can find them here:
    https://8020.net/shop/4199.html[/url]
    They also come in black but I liked the contrast:
    https://8020.net/shop/4199-black.html
    Robby
    gudnoyez Posts: 8,166
    I made the cut so yes Larry put me down for one, I'm pretty sure the one on my800va is one of yours fine workmanship indeed. I'm down for one of these from the new run . Thanks
  • verb
    verb Posts: 10,176
    I’m in! Thanks Larry for doing this!
  • Gerres26
    Gerres26 Posts: 874
    Much nicer than my Hammond version...I'm in for one please!
  • Hey what happened to the last thread from this morning?
    Anyway I’m in for one
  • indyhawg
    indyhawg Posts: 1,672
    Larry--Count me in.
  • ThomasD
    ThomasD Posts: 260
    Am I correct in assuming that these 1 KVA torrids don’t generate any appreciable heat when used in this SDA IC configuration? I see no venting on the cabinets so no ventilation issues?
    Never any heat
  • gmcman
    gmcman Posts: 1,851
    I'm in for one case.
    Thank you again Larry.
  • erniejade
    erniejade Posts: 6,321
    I'm in please
  • Put me down for a case please.
    I plan to terminate my cable directly inside the box without fancy terminals. Already have an updated heavy gauge cable with speakon terminals.
    One less link in the chain.
    Any downside I’m missing besides the bling factor?
  • verb
    verb Posts: 10,176
    So Larry @Toolfan66 getting my read on about the whole dreadnaught thing, and found this:
    https://forum.polkaudio.com/discussion/166261/finally-neutrik-dreadnought-etc
    Gotta admit, those red panels look great, not to mention the other bling mods you made! Wow! :smiley:
    Is this group buy only black panels this time? :blush:
  • monepolk
    monepolk Posts: 1,154
    Put me down for 1!
  • ThomasD
    ThomasD Posts: 260
    verb wrote: »
    verb wrote: »
    @Toolfan66 I for one would sure consider paying an up charge for a different anodizing option. B)
  • B-Man
    B-Man Posts: 13
    Larry - thanks for your generosity. Please put me down for 2.
    edited January 2019
    The box is essentially an RF shield (with bling). How you terminate is your choice but think of a boat with holes in it during a storm... Essentially you could install it in one of your speakers for that invisible effect but where is the "cool" in that?
    Post edited by audioluvr on
    nooshinjohn Posts: 25,935
    edited January 2019
    audioluvr wrote: »
    This is a bad idea.
