Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers
1…457910…16
  • vcwatkins
    vcwatkins Posts: 1,992
    Wow, thanks to @pitdogg2 for putting this together! Pretty amazing.
    The 2016 total was 43 units (we had one member increase his purchase at the last moment). And considering that total, I expected it to take longer before reaching critical mass on another buy.
    I'll be sending out PM's to confirm numbers and request shipping data today.
    Cheers!
    Craig
    pitdogg2 Posts: 27,914
    vcwatkins wrote: »
    Cheers!
    Craig
    WOW 43 incredible I didn't think it was that high. I knew we had many that had multiples looks like Carton was correct.
    You da MAN Craig.
    edited January 2019
    OK here we go updated list as of 1/4/2019
    1. Erniejade
    2. pitdogg2
    3. La2vegas
    4. Gerres26
    5. Indyhawg
    6. StainOsteel2
    7. audioluvr
    8. Verb
    9. vcwatkins
    10. BC6
    11. Lightman1
    12. BlueBirdMusic
    13. ThomasD
    14. honestaquarian
    15. Eric Landman
    16. monepolk
    17. Manticore
    18. RobbyKY
    19. DNSPY007 in for 2
    20. daddyjt in for 2
    21. B-Man in for 2
    As it stands we are at 24 units
    POSSIBLY IN One more to 25 the best deal we can get.
    22. GlennDog
    23. gudnoyez
    24. Headrott come on Greg you know you want one :D
    25. FestYboy
  • erniejade
    erniejade Posts: 6,327
  • vcwatkins
    Clickable list to make admin easier.
    1. @erniejade
    2. @pitdogg2
    3. @la2vegas
    4. @Gerres26
    5. @indyhawg
    6. @stainless0steel2
    7. @audioluvr
    8. @verb
    9. @vcwatkins
    10. @BC6
    11. @lightman1
    12. @BlueBirdMusic
    13. @ThomasD
    14. @honestaquarian
    15. @Eric Landman
    16. @monepolk
    17. @Manticore
    18. @RobbyKY
    19. @DNSPY007 in for 2
    20. @daddyjt in for 2
    21. @B-Man in for 2
  • Gerres26
    Gerres26 Posts: 874
    I know it's a little early but does anyone have the dimensions of 1000va unit...trying to figure out if it'll fit in my 800va case or not
    edited January 2019
    Gerres26 wrote: »
    I guess one should ask what case you have?
    Pictures of yours may help.
    My 800va is in an aluminum case and has about an 1/2" of room around it. When I put the lid on it, it holds the transformer in place. There is no bolt to hold the torrid in mine.
    Where did your case come from?
    The 1000va is a bit bigger all around and it is possible if yours has excess room like inches all around.
    gudnoyez Posts: 8,229
    Will the new transformer fit in this case the dimensions are 11X11X4 if not where do you all plan on sourcing the cases for these?
  • vcwatkins
    I believe those are the same dimensions as my first 1000VA case. I'll check.
    Dunno if Larry has planned another run; but we have plenty of time to figure things out, in any case ;)
  • Gerres26
    Gerres26 Posts: 874
    Gerres26 wrote: »
    I'll measure it up tomorrow, i can't remember where I purchased online. It is a black cast aluminum enclosure...maybe Hammond brand...maybe :*
  • lightman1
    lightman1 Posts: 10,803
    I'm good for one case if you make another run, Larry.
  • lightman1
    Boogers! I started mucking up the thread... :'(
  • indyhawg
    indyhawg Posts: 1,683
    You probably have not even started drinking yet.
    txcoastal1 Posts: 13,520
    indyhawg wrote: »
    It's Friday, and I'm sure he started ehhhh say 3:17pm eastern
  • B-Man
    B-Man Posts: 13
    I tried to send my shipping info via reply to the email I received from Craig and it was bounced back as undeliverable ?
    Is there an email address we can send our shipping info to, as opposed to putting it here in an open forum ?
    lightman1 wrote: »
    YEA like that was a first....
    Larry your a champ man ;);)
    edited January 2019
  • daddyjt
    daddyjt Posts: 3,268
    B-Man wrote: »
    @B-Man I can send Craig your shipping info if you’d like. I think PMs are disabled for new members...?
    Shoot me an email...
    ― Aleksandr Solzhenitsyn
    B-Man wrote: »
    PM me B-Run I'll get it to Craig @vcwatkins
    B-Man...hello...B-run lives in Austin
  • B-Man
    B-Man Posts: 13
    daddyjt wrote: »
    B-Man wrote: »
    That's funny - new member... Thanks Mark !!
  • vcwatkins
    B-Man wrote: »
    Sorry about that B-Man. I'll PM my email.
    edited January 2019
  • lightman1
    edited January 2019
    :o Bad edit!
    edited January 2019
  • GospelTruth
    Ok, if this is still open and Larry is going to be making a run of the cases, I'll be in for one. Hopefully this is not yet closed. If you all think this will work wonders for a common ground amp with 3.1TL SDAs, I'll go with it.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
    PM @vcwatkins it is not too late.
  • FestYboy
    FestYboy Posts: 3,861
    When is the cutoff?
  • westmassguy
    westmassguy Posts: 6,849
    This is the case I use for the 800VA, as have others:
    http://www.hammondmfg.com/pdf/1550N.pdf
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • honestaquarian
    @GospelTruth I too have a pair of 3.1TL’s (and I’m using some Monitor 5jr’s for surround duty) and YES this sucker works wonders for them!!
    FestYboy wrote: »
    When is the cutoff?
    Dude very quick just get in already. @vcwatkins is going to call and do this quick like before you know it your bottom will be SOL
