Listening DB levels and others
joecoulson
So I was curious about listening levels from all you out there. Most of not all of you have the ability to download a free app for your phones to get a rudimentary reading. I downloaded DB meter pro for $10 but there are many free ones out there.
I found the following readings from my setup interesting.
Without source: room noise without anything playing. Mine was 35db. I assume some of this is appliances, a fish tank, outside noise etc.
source material at listening level that I use 75% of the time:
3m from speakers (seating ) 75db avg with Rufus Du Sol- Solace on vinyl. Not too much low or high. Good amount of middle transients
1m from speakers same source 80db avg
6” from mid/tweet same source 92db avg
Pre amp is set at 44 of 100
I understand there are many factors affecting these numbers and I’m sure the much more intelligent crowd will tell me why these numbers are not accurate, but it’s a good baseline I think for comparison.
IE @clipdat typically listens to about 5db lower than me, but curious what other noise he might not have that maybe makes it more equal that from the outset.
I've found smartphone apps are inaccurate due to built in compression at the mic- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I don’t doubt that, but if all smartphones do it, the readings from others (if all use smartphones for readings) should be comparable no?
Sure but the data is pointless as you cooks be actually at 100 dB versus 85- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Not that far off:
And just to add, this was a curiosity thing on how loud everyone listens at mostly. Not a debate on the accuracy of cell phone microphones which I know are not truly accurate.
I downloaded Decibel X. A couple weeks later, I saw a Radio Shack meter at a garage sale and passed on it. Wish I hadn’t. Well, my quiet room is also about 33-35 dB. I usually listen (to mainly jazz) at average levels of 75-77 dB, with peaks around 82-85 dB. The smartphone was about 8.5 feet from the plane of the speakers.
I never measure what I hear, as I can't listen to measurements. I set the Db level to the most realistic volume possible. I mean, you don't listen to a piano or a violin at 120 Db. Likewise, you don't listen to an Iron Maiden Rock concert at 65Db.
I'll add to Trey's experience. Phones are for the most part, useless when it comes to audio. Not every time but even a broken clock gets the time right once or twice a day.
Cool! Very similar measurements ( albeit inaccurate like @VR3 mentioned )
Seems like 35db is very quiet to me. You too? -
And Trey please don’t misunderstand, I thoroughly respect the amount of knowledge you and others have in this hobby, this was only a very amateur exercise for fun only.
I would imagine in the normal ranges (85 and below) it may be within a certain % of a standard SPL meter (now granted, the Ratshack meter is inaccurate as well), back when we used that to graph the response of a room, there was a spreadsheet floating around the account for its issues but that is a different story.
I think where you will really see the differences are at extreme volumes - if you have recorded a live concert, you will hear what I am saying - the end recording for a live concert on a telephone is very very flat (and distorted) because the phone mic is designed to crush the recording.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I do miss the Ratshack. We only have Frys near us now and they are lackluster.
The 33-35 dB is as quiet as it can be. Nothing running in the house and no yard maintenance people within earshot. Me holding my breath as I read the meter.
I bought Decibel X Pro and calibrated it using an actual SPL meter. I had to increase the app +10db to get it to match the meter. Phone is Galaxy S8.
This is no dig at Android, but I did read this:
Android-based apps lacked the features and functionalities found in iOS apps. This is likely due to the iOS advanced audio capabilities compared to other platforms, the open ecosystem of the Android platform, and having so many different Android device manufacturers using different suppliers and components. -
And Drew, where are your readings huh?!?
I listen at around 80db and my room can read as low as 23db.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Wow. 23 is dead quiet. That’s killer.
That’s where the whole “first watt” theory would play perfectly no? -
I like to listen late at night (or very early morning) so I probably have a very low background noise level. As I mentioned in another thread, while at Magico and listening to a comparison of the S5 and S7 in their dedicated, dead quiet listening room I said their S5s sounded just like mine. And mine are in the living room.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I have always found my system sounds best around 1 to 3am...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ditto.
I think there are two factors favoring late night listening. First, the ambient noise level is very low. Second, most of the neighbors electrical noise creating gear is turned off, so the incoming power is much cleaner.Lumin X1 file player, Westminster Labs interconnect cable
joecoulson wrote: »And Drew, where are your readings huh?!?
First track:
10ft = 68db
3ft = 68db
6" = 73db
Second track:
10ft = 70db
3ft = 71db
6" = 76db -
Wish I could listen at decent levels at night. Alas we live in a ranch home and I have two kids.
Strange those 3ft and 10ft readings are so close. Wonder if it’s the height they are mounted at?
I enjoy listening at night as well. Whatever it is the system and sound feels more complete. Actually listening to it right now, Billie Holiday record I got. Sounds very nice.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
My room is at 34.9 at 530am. I have not been able to check listening levels yet.
Still floored that @machone can get into the low 20’s for background noise. That’s dead quiet.
Our loft apartment has a pretty "open" floor plan. With everything off, except the Molekule air purifier, we're at 46 dB. With the cat's water fountain, the space heater, the humidifier, and the refrigerator all running in the background, we're at 57 dB.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
As for the dB levels when listening to music, I'm usually at ~75-78 dB peaks; Probably just under 70 or at 70 dB average when listening to music.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
joecoulson wrote: »Wish I could listen at decent levels at night. Alas we live in a ranch home and I have two kids.
Simple...buy them earmuffs for Christmas, kill 2 birds with one stone and crank it up.HT SYSTEM-
