Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers
    pitdogg2 Posts: 24,575
    Get in on this one and don't look back.
  • vcwatkins
    vcwatkins Posts: 1,993
    I guess I'd be in for one as well. I'd like to upgrade the 800VA I have on my 4.1tl's.
    I'll contact A-L to request a quote.
    Is this really happening?!
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • erniejade
    erniejade Posts: 6,315
    vcwatkins wrote: »
    I think so!!
    edited December 2018
    Yes Craig it is do your magic my friend.
    You've been instrumental in the past for this couldn't do it without you or Neil that is the reality to be perfectly honest.
    verb wrote: »
    verb wrote: »
    GlennDog wrote: »
    Im sure @verb will be down ... IF he can pull his arse away from the roulette table!
    Lol! Haven't left yet, but yes, I'm in. What are we buying? :wink:
    1000va torrid making a dreadnought.
    Get your read on
    https://forum.polkaudio.com/discussion/175325/group-buy-16-dreadnought-avel-lindberg-1000va-isolation-transformers#latest
    Yep. I double checked and the mods David @westmassguy did for my 1C project (yes the parts are still in the boxes) has the provisions for a Dreadnaught.
    Are your big boys just SRS or are they 1.2?
    SRS NO GO 1.2 would be a go for this as well.
  • verb
    verb Posts: 10,176
    Gen1 SRS :cry:
    oh well done the road you never know. You end up with the 1.2 1.2TL's you will be set very well with this tranny.
    The last go around there was about 20-25 IIRC. I do not expect anywhere near this time but all who are on the fence should go for it. How many folks over the time you have been here came in asking for one? more than a handful so they do sell if not needed. Still some are now buying seconds and thirds so the pool of people is not nearly as big and it is a pretty good expense but wholly worth every penny.
  • verb
    verb Posts: 10,176
    I'm still in for one. Future upgrade ya know! :smile:
    nooshinjohn Posts: 25,098
    If you can't use it for your SRS, perhaps it could be useful infixing the junk electrical system in the C8.
  • honestaquarian
    I'm THINKING about getting a second one depending on what the prices look like now and how many come on board for a discount.
  • verb
    verb Posts: 10,176
    Forgive me, but I'm a Dreadnaught newbie, among other things. Help me understand the connections of a Dreadnaught to the SDA system (block diagram). I'm not running monoblocks at this time.
    For my 1C project, after a second, I mean third look, I don't believe my modded 1C terminal cups have the provisions for it. I believe it requires an additional pair of connections (either speaker terminal or neutrik) correct?
    I've read alot about them here on CP, and it sounds very exciting. The last batch run thread was cool! I felt the excitement among those who participated.
    So, for this run, I'm in! :smile:
  • verb
    verb Posts: 10,176
    DO EET! Or you may have to wait a few years just like last time! :smile:
    Just do it Carlton. Pretty sure it will not be as good of a deal in comparison to the last but you know as well as I do it's money well spent.
  • honestaquarian
    My wallet is cussing me out right now, because it's kinda empty until I get my tax refund in Late January or early February. So if this goes on as long as the last one did, I might just be able to jump in on this one. I'm afraid to commit right now, because I don't want to and then find out I can't do it.
    The last one WAS fun wasn't it????
  • honestaquarian
    honestaquarian Posts: 3,186
    I'll tellya what. Let's wait until Sketchy Craig gets some numbers back from Avel-Lindburg. I am hoping and praying Trump' tariffs do not cause the price to go up too much!
    As far as I know we are in the beginning stages. Yes my thought is to go through January. Face it most just dropped coin for Xmas and we all are not going to die if we don't have one by the end of January not to mention I'd believe most are very understanding thst the more we get the better price we could get.
  • Gerres26
    Gerres26 Posts: 863
    I hope this continues to gain steam, I wonder if the 1000va will fit in my existing 800va enclosure.
    Gerres26 wrote: »
    Usually not the 1000va is taller and wider.
  • monepolk
    monepolk Posts: 1,141
    I'm following just in case B)
    monepolk wrote: »
    Just in case?
  • monepolk
    Yeah in case I need a second one.
    Oh you do you do :p
  • BC6
    BC6 Posts: 109
    Double checking... I thought I read in another thread that you could use this with common ground amps, but I can't find the thread. There's a lot of them. If it will work with my integrated amp, then I'm in.
    2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
    HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV.
  • honestaquarian
    BC6 wrote: »
    @BC6 You can use this with common ground as well as non common ground amps
  • BC6
    BC6 Posts: 109
    Awesome! Thanks. Then I'm in.
    BC6 wrote: »
    Yep i use a 800va on my Carver TFM45
  • honestaquarian
    lightman1 wrote: »
    In.
    Russ you gonna keep it a Doug's house along with the SDA-1C's that I sold you about fifteen years ago?? :p
    If my counting is correct and everybody follows through with their commitment we have 12 now. IMPRESSIVE!!!
    10 is the minimum so in less than 12hrs. BOOM
    Keep it up fellas.
    When i can get to a computer and bigger screen than my 3" phone screen I'll list the names we have
    Thanks guys lets make this happen
