Hegel Rost
bikerboy
Hi,
In an effort to downsize I'm thinking about integrated amps. I've read about Hegel but never heard any. I would use a pair of Polk 703 and a sub. The Rost looks about right. Anybody using Hegel with 703s?
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Bottlehead Eros
CD: DIY Shigaclone
Never heard of the Co. until now.
Since I moved from two systems to one there's lots of stuff. Now have a tv, tivo and the hifi. The hifi is 11 components plus the modem and the wifi router. I need to play flac files, have a great dac with xlr outs,use a Sonora Ultrarender. Play fm radio, tv sound, vinyl. Would like to have fixed outputs for the House amp. The Rost can do all but fixed outs. Just thinking better WAF. I need to use 2 power conditioners plug everything in to ac! Its a lot.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
Thanks DSkip for the ideas and advise. Got one of these on the way
Tony bet you haven't heard about these guys . I hadn't
http://lyngdorf.com/tdai-2170/
Integrated 2.1 with room correction and dac. This one has all the optional boards hope it sounds as good as the bat comboMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Looks like a fine Co. and Integrated design, inside and out!Most people just listen to music and watch movies. I EXPERIENCE them.
Ultrarendu into usb. TiVo, blue ray , tuner also into dac. Eros phono all connect. Three boxes for one .Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
disadvantage is if you have to send it in to repair 1 box, you send in all 3.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
True 🤞🤞Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
I'll start a new thread when I get it runningMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
It is used.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
