Hegel Rost
Hi,
In an effort to downsize I'm thinking about integrated amps. I've read about Hegel but never heard any. I would use a pair of Polk 703 and a sub. The Rost looks about right. Anybody using Hegel with 703s?
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
    Tony M Posts: 11,681
    Never heard of the Co. until now.
  • bikerboy
    bikerboy Posts: 1,235
    Since I moved from two systems to one there's lots of stuff. Now have a tv, tivo and the hifi. The hifi is 11 components plus the modem and the wifi router. I need to play flac files, have a great dac with xlr outs,use a Sonora Ultrarender. Play fm radio, tv sound, vinyl. Would like to have fixed outputs for the House amp. The Rost can do all but fixed outs. Just thinking better WAF. I need to use 2 power conditioners plug everything in to ac! Its a lot.
    Bottlehead Eros
    CD: DIY Shigaclone
  • bikerboy
    Thanks DSkip for the ideas and advise. Got one of these on the way
    Tony bet you haven't heard about these guys . I hadn't
    http://lyngdorf.com/tdai-2170/
    Integrated 2.1 with room correction and dac. This one has all the optional boards hope it sounds as good as the bat combo
    Bottlehead Eros
    CD: DIY Shigaclone
    bikerboy wrote: »
    Looks like a fine Co. and Integrated design, inside and out!
  • bikerboy
    Ultrarendu into usb. TiVo, blue ray , tuner also into dac. Eros phono all connect. Three boxes for one .
    Bottlehead Eros
    CD: DIY Shigaclone
  • marvda1
    marvda1 Posts: 4,962
    disadvantage is if you have to send it in to repair 1 box, you send in all 3.
    Puritan PSM156
  • bikerboy
    True 🤞🤞
    Bottlehead Eros
    CD: DIY Shigaclone
  • bikerboy
    I'll start a new thread when I get it running
    Bottlehead Eros
    CD: DIY Shigaclone
  • bikerboy
    It is used.
    Bottlehead Eros
    CD: DIY Shigaclone
