Need to put together a decent compact system for my daughter.
afterburnt
She will only need to play from USB sources and not much else. I don't have a lot to spend so what do yooz suggest?
Maybe need to go with something that will accommodate movies with a Play Station 3, I think.
I mean, like, one of those teeny-weeny Class "D" amps with a DAC might be ideal, yes?
They are Legion; here's but one example (I know nothing about this stuff).
https://www.parts-express.com/smsl-q5-pro-stereo-amplifier-usb-optical-coaxial-dac-with-subwoofer-output-2x40w--230-210
Do you want to go cheap or good on the loudspeakers?
If (really) cheap, these aren't terrible. In fact, the treble's pretty darned good.
https://www.parts-express.com/dayton-audio-b652-air-6-1-2-2-way-bookshelf-speaker-with-amt-tweeter-pair--300-651
DSC_0611 (2) by Mark Hardy, on Flickr
EDIT:
FWIW, over at hifihaven, "we" have a forum for decent, modern entry level hifi:
http://www.hifihaven.org/index.php?forums/the-doorway.22/
Might be worth perusal in the context of this thread(?).
A4L has a few systems that are reasonable.
mhardy6647 wrote: »I mean, like, one of those teeny-weeny Class "D" amps with a DAC might be ideal, yes?
EDIT:
That doohicky has the right features.
I was thinking about these: Pioneer SP-BS22-LR Andrew Jones Designed Bookshelf Loudspeakers $99
Or these: ELAC Debut B4 Bookshelf Speaker $124
Thoughts? -
afterburnt wrote: »mhardy6647 wrote: »I mean, like, one of those teeny-weeny Class "D" amps with a DAC might be ideal, yes?
EDIT:
Thoughts?
I came within seconds of acquiring a used pair of those Pioneers at a townwide yard sale in nearby Cornish Flat, NH a year or two ago. They're likewise not bad little loudspeakers.
I haven't heard the ELACs, but I have heard good things about them from people whose ears I trust.
That's the best I can do, I'm afeared.
This looks good for $150 if you can run everything through the PS3
Yamaha R-S202BL Stereo Receiver -
First off don't think you need to have everything at once. Get a older AVR that has HDMI ($30-$50 range), pick up some older polkies RTi 4/6s or even a pair of T15 add a 6"/8" sub and old center for a nice little 3.1 setup for under 200 bucks total
https://www.ebay.com/itm/Denon-AVR-590-5-1-A-V-Digital-HDMI-Receiver-excellent-condition/132854897581?epid=73380869&hash=item1eeec4dbad:g:ZcUAAOSw-pNb6zr4:rk:30:pf:0
https://www.ebay.com/itm/Polk-TSx220B-Cherry-Bookshelf-Speakers-Pair/173633264454?epid=218500157&hash=item286d595b46:g:GnMAAOSw2gNb1ICV:rk:54:pf:0
https://www.ebay.com/itm/Yamaha-YST-SW010-Powered-Subwoofer/173637167946?epid=94262480&hash=item286d94eb4a:g:rdcAAOSwLSZb6b-J:sc:FedExHomeDelivery!92407!US!-1:rk:38:pf:0Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Optimus LS30's Rear Surrounds Optimus LS30's Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Fluance Signature Tower Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX103 Squeezebox Touch Polkaudio R50 Towers Polkaudio CS 10 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Polk audio RTi 6 fronts, Rears Dayton B652 Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
If you can find a set cheap enough, the Monitor Audio Radius r90HDs are really good, and tiny. You’d need a sub though.
The earlier versions are supposed to be almost as good, and the later versions are supposed to be better.
Older AVR to power it, like Recoveryone said. The Monitors sound really great on my Yamaha RX-v665.
Good luck on your hunt. -
@mlistens03 did think about a sub. Wonder how those speakers that I mentioned do without a sub?
afterburnt wrote: »mlistens03 did think about a sub. Wonder how those speakers that I mentioned do without a sub?
I think they’d do good with a sub, better than they would on their own. But the ones you mentioned earlier are larger and probably have better low end response, so you may get away without one. The Monitors I mentioned pretty much won’t do anything under 75 hz. -
You could also just go through some of the stuff you already own, and give that to her.
Black Friday Polk Command Bar $199. It’s pretty compact and easy to setup.
- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Good price on these. Just ordered a set for myself.
https://hifiheaven.net/shop/Products/Speakers/Bookshelf-On-Wall-Speakers/Klipsch-R-15M-monitor-speakers?sort=p.price&order=ASCOh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
or active/passive speakers???
https://hifiheaven.net/shop/AktiMate-Micro-Red-2-way-Active-Speaker-System-with-iPod-Dock
@rpf65 only spare stuff I have are amps
@jeremymarcinko are those good with music?
afterburnt wrote: »@jeremymarcinko are those good with music?
I would say no, better for HT. (IMHO)Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears -
The reference series speakers are decent for music and a pretty good speaker given the ultra budget application here.
However my purchase was just refunded so these may not be available.
It seems there may be an similar alternative the R51m on amazon for a few bucks more.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
How bout a Woosbourne?
Woodbourne? Yes, that would fit the bill perfectly.
Polk Audio Woodbourne
Available used it will fit the budget and connectivity requirements nicely.
Check it out, only $180.49! https://ebay.com/p/Polk-Woodbourne-Wireless-Speakers/217389882?iid=263667788637&chn=ps
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
I love my deepblue2, It's not portable ie capable of running on batteries but I do travel with it and use at the ranch
Use for music, video games, sound bar etc
Peachtree deepblue3
https://www.worldwidestereo.com/products/peachtree-audio-deepblue3-bluetooth-3-way-speaker-system-deepblue3?sku=170282&CAWELAID=120216570000087655&gclid=CjwKCAiAlb_fBRBHEiwAzMeEdtbPh6mqW8zeqtBXuHQbgTjGCqirdsLFMnvHfvLSFmNvzWZDw27kcxoCokUQAvD_BwE
For the same price and connectivity you can go with a traditional pair of
Peachtree Audio M25 2-Way Powered Speakers
https://www.worldwidestereo.com/products/peachtree-audio-m25-2-way-powered-speakers-pair?sku=170264&CAWELAID=120216570000087121&gclid=CjwKCAiAlb_fBRBHEiwAzMeEdj9hrLnY7XKZfJ_WXXt5iK3fUXjuGjCcpImhcxfbnNQVB3GybcDnZxoCKRcQAvD_BwE
Thanks for the input, I have made my decision. I am filled with anticipation to see how this is gonna work out. I am also filled with consternation knowing that I will have to go to here mom's house to set it up. If I had the money I would send her raggedy azz to the spa for the day.
Not all that compact https://usa.yamaha.com/products/audio_visual/hifi_components/r-n303/index.html
https://www.elac.com/product/b6-2/?r=us
And about $150 over budget
I am glad that I kept looking, got some decent price s. -
afterburnt wrote: »Thanks for the input, I have made my decision. I am filled with anticipation to see how this is gonna work out. I am also filled with consternation knowing that I will have to go to here mom's house to set it up. If I had the money I would send her raggedy azz to the spa for the day.
So, what did you decide?Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
@haloafterburnt wrote: »Not all that compact https://usa.yamaha.com/products/audio_visual/hifi_components/r-n303/index.html
I am also remodeling her room to accommodate this stuff lol.
Anyone interested the above Elac's are a buck fifty for some strange reason. The smaller ones are $100 more.
@afterburnt - very nice
If the Elac speakers don’t float the boat, the Polk Signature Series is a very good alternativeAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Yeah, they are indeed. I wasn't going to mention that on the Polk Forums but I just ordered a pair. Couldn't resist at that price
@halo I should have looked at them, I have heard good reviews here but the upgrade path would probably be a better receiver etc. This should get her through college and then I expect her to buy me a graduation present. Have you heard the S20, the more or less equivalent of the B6.2?
500 bones for that HSU taint bad!
