Post a picture... any picture
12682692712732741153
  • OleBoot
    OleBoot Posts: 3,135
    As seen on teh internetz.
    Ok, this is from spring, not fall, but still...
    Wonder how the Druids did it without Land Rovers?
    Viking64 Posts: 7,596
    OleBoot wrote: »
    Tony M Posts: 11,676
    edited November 2018
    That right there is a great picture!!! :D
    Poster material.
  • OleBoot
    Alien 1: "Lets pile up some big stones in a circle on this little planet, and pop back a 1,000 years later and have a laugh at how they think these morons did this"
    Alien 2: "Yeah, then we'll leak the formula for acid and they'll probably dance naked round them. Ark, Ark, Ark."
    mhardy6647 Posts: 35,161
    I/we got rid of so much old office furniture like that from my parents' house (mostly castoffs from my grad school and other places that my father or I had connections with).
  • OleBoot wrote: »
    The Druids could do it specifically because they did NOT have Land Rovers. ;)
  • OleBoot
    OleBoot wrote: »
    You mean they had Jeeps?
  • joecoulson
    joecoulson Posts: 4,943
    Battlestation
    Great work john
    Looks right out of Mad Men
    Except for the tv of course
    Clipdat Posts: 13,100
    Crooked male RCA tips on an Audioquest Carbon digital coaxial cable. Expected better build quality than this on a freaking $200 cable. Kinda ridiculous.
  • FestYboy
    FestYboy Posts: 3,861
    Looks like the stranger built them... :#
    pitdogg2 Posts: 27,180
    Clipdat wrote: »
    They're excited....stick'em in D hole
    I tried them out, it was a super tight fit and felt like it was putting unnecessary stress on the female jack itself as well as possibly the plastic insulator inside the jack. Didn't feel good.
    This cable's fitment was unlike any of the other Audioquest RCA cables that I own which are fairly easy on/off, yet reassuringly snug. This didn't feel right and I had to exert higher than normal pressure to plug and unplug it.
    I've reached out to the authorized retailer where I purchased the cable and we'll see what they say. I bought them earlier this year though, so there's not really any incentive for them to do anything for me at this point. So, I will most likely have to reach out to Audioquest next.
    This is unacceptable for a $200 cable, imo.
    OleBoot wrote: »
    OleBoot wrote: »
    Broncos, ol' son. Broncos. Real Broncos.
    They got 'em from aliens -- but that's another story.
    14803393032_89de782588_b.jpgbronchusspiffed by Mark Hardy, on Flickr
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Do they straighten out if you push on it? If not, agreed they would put a lot of radial stress on the female jack. Could lead to problems over the long haul.
  • verb
    verb Posts: 10,176
    Thinking about this, you may be able to bend em back so they are straight. Take the collars off, let's see what they look like under the hood!
    verb wrote: »
    They don't straighten out when you push on them. Thought about unscrewing the barrels and trying to see if that would shed light on the situation. But honestly, it shouldn't be my burden to try to fix an obvious quality/manufacturing issue on a $200 cable that should have never left the factory in this condition.
    That burden is on the retailer or the manufacturer. Fortunately the retailer has stepped up and offered to swap out the cable with a new one for me. Great, although I'm guessing I'm on the hook for return shipping, which is a bit of a gray area when a product is arguably defective and not as advertised.
  • verb
    verb Posts: 10,176
    Yeah, for sure. Good that the seller will swap em out for you.
    Just had mine fixed, looked worse than yours. My fault though, caught my foot on it while moving stuff around and yanked my AZ Matrix 2's ripping apart one locking rca sleeve and bent the pin substantially.
    Robert over at AZ fixed it for a measly 30 bucks. Nice guy....if you can get past the accent. :)
    F1nut Posts: 51,895
    EndersShadow Posts: 17,715
    Is this a new Koolaid commercial Jesse?
  • Hermitism
    Hermitism Posts: 4,329
    Drew, you should pair those crooked RCA cables with your crooked power cables and your crooked audio rack. If anyone gives you crap about nothing being straight, just tell them they are supposed to close their eyes when listening to music. Now all you need are some unlevel leaning speakers.
  • motorhead43026
    motorhead43026 Posts: 4,019
    A bloody wave, we all are going to die.
    – Kevin Alfred Strom
    Hermitism wrote: »
    Or just say its your audio enthusiast take on abstract art or cubism.......
    Hermitism wrote: »
    Now that there is funny...lmao !!
    Kinda wondering now, if Drew walks a bit crooked himself. Maybe his house looks like the old Batman movies, a level floor is nowhere to be seen.
  • Hermitism
    You should buy these, Drew! Make a real go of it!
