Post a picture... any picture
12482492512532541153
  • mrbiron
    mrbiron Posts: 5,721
    Step #1 - Wake up at 1:30am, head to Cape Cod. Climb on boat and steam out for 1.5 hours.
    Step #2 - Help catch 150lb bluefin tuna
    Step #3 - Eat
  • joecoulson
    joecoulson Posts: 4,943
    Best set of pics so far. Awesome catch and that’s some good food!!
  • Malbec
    Malbec Posts: 558
    Beautiful. Calm seas By the looks of it.
    EndersShadow Posts: 17,715
    mrbiron wrote: »
    Step #3 - Eat
    Nope... step 3 is.... SELL IT ON THE MARKET for 12$ a lb! I've watched Wicked Tuna!
  • verb
    verb Posts: 10,176
    mlistens03 wrote: »
    Wow, I didn't know that! Very interesting. I guess I should've thought about what they would've done before SS amplifiers were invented.
    Thanks for sharing!
    Real quick question, did they ever use shock absorbers for housing the tubes, so they didn't get damaged by being bounced around every which way?
    My 59 Bel Air had a AM Radio with tubes in it. In fact, the owners manual had a table in it that gave estimated radio warm up times depending on the ambient temperature outside.
    I've since replaced it with a facsimile digital AM/FM/AUX input radio. And I use the AUX input for a BT dongle! I'm ashamed. :smile:
    Tony M Posts: 11,679
    edited August 2018
    Radio warm-up time...LOL.
    That might've been "HIGH TECH" in those days, huh? ;)
    And FM wasn't invented yet? :o
    I too felt bad yanking my cassette deck out of my 95 Camry so I could play Cds in the dash. I have a CD changer in the trunk but I like at reach control and CDs in the arm rest conveniences.
  • delkal
    delkal Posts: 764
    Nice tuna............Whatever you do don't throw away the belly meat when you are cleaning it. That is the most prized part for sushi in Japan and goes for hundreds of dollars a pound. I had a friend who used to fish for tuna and he threw away thousands (tens?) of dollars worth before he knew better.
    And since you like Ahi try Alton Browns method. You cook it over a chimney charcoal grill starter. Its scary the first time you try it but it makes the best Ahi I ever had.
    https://foodnetwork.com/recipes/alton-brown/chimney-tuna-loin-recipe-1911894
    mhardy6647 Posts: 35,181
    FM as we know it dates back to the 1940s, thanks to Col. Armstrong.
    My parents' '55 Buick Special (convertible!) had a tube AM radio (of course). I remember that it could be turned on and played even if the car weren't "turned on" (i.e., no key required). I determined that empirically as a lad :p
    They had that car well into the 1970s... it was seriously cool.
    Buicks back then were COOL! I had a 65 Starfire that was "a real GEM". White leather interior. Modern radio. I installed an 8-track player. :)
    Tony M wrote: »
    Cool car man, which engine did it have ? I kinda miss those styles from the 60's, every brand had a few winners.
  • CGTIII
    CGTIII Posts: 1,245
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • mlistens03
    mlistens03 Posts: 2,767
    :o what happened there!
    mlistens03 wrote: »
    Injuns...lol.
    Looks like a bunch of curb feelers to me. :)
    CGTIII wrote: »
    At first glance, I thought they were tie-downs. :(
    That's an unfortunate occurrence for a beautiful Comanche. Nice planes they were.
    I will mention, at this juncture, that Piper's planes were often saddled ;) with Native American names -- and Piper did, at one time, make a plane called the Piper Arrow.
  • Appears to me that it must have flown a little too low over a Conservation Area during Archery Day.
    Yep. That's the only possible explanation.
    edited August 2018
    tonyb wrote: »
    Tony M wrote: »
    I was lucky enough to have bought an Oldsmobile Dealers personal Olds. It was very special with LOTS of options.
    It had the coveted 455 and I believe a 400 turbo transmission. Maybe a 350 turbo. That was the most powerful car I've ever owned. It had the most beautiful interior also. White leather and black carpet and dash and console.
    The exhaust came out of the chrome trim on the bottom of the rear quarter panels. The trim was about 8" tall and ran the whole distance of the car.
    I laid down a hundred ft. burnout one time and it was that length only because I let off the pedal to save some tire tread for later normal use. I always thought I could blow a tire with that kind of power the 455 produced.
    I have ALWAYS missed that car!
    I also thought, if I won a lottery, I'd search out another 65 Starfire but I haven't seen one quite like mine on the web.
    My Uncle had this 65ish Buick Wildcat. A White car with a red interior. Chrome everywhere. It was a jaw dropper of a beautiful car!
    pitdogg2 Posts: 27,192
    mlistens03 wrote: »
    Clipdat wrote: »
    Would they need them? I thought tubes were designed to be used in missiles, etc.
    WHAT!?! I didn't know that!
    I guess I always thought of them as fragile things. The kind of thing that would crack with only minor impact.
    Such a young pup.....
    Clipdat wrote: »
    Interesting, seems to imply that a different "hardened" glass was used in the Bendix tubes.
    Yes it was. Everything in the Bendix/Mu 6900 was built for excessive G forces and extreme environment
    I've since gone (back) to higher-mu voltage amplifier tubes (6SL7 -- for which the amp was designed!), and, unfortunately, I don't have a pair of "Special Red" 5961s to use in it! :(
    Hey Doc keep an eye on eBay in the last two weeks I've seen pairs of NOS 5691/6sl7's go for far less than they should. Less than 100 for the pairs.
    Have you ever tried any 6bx7 or 6bl7 tubes? Brent Jesse turned me on to them according to him they are a much better match to most 6sn7 circuits than the 5692. According to him the 5692 can run too low and that is how they tend to last longer than stock 6sn7. I know in my buffer you can tell the 5692 IS lower. On my preamp Carver C16 i use the external processor circuit so it's easy to compare by the press of a button. The 5692 volume is much lower than 6sn7 tubes yet the 6bl7 tubes are higher than 6sn7. Brent hooked me up with a great set of 6BL7gta triple mica Sylvania tubes made in 1950 for a song.
  • mlistens03
    mlistens03 wrote: »
    Clipdat wrote: »
    Still gotta lot to learn...
    Clipdat Posts: 13,100
    Occasionally I see one of these driving around my neighborhood:
  • halo
    halo Posts: 5,618
    edited August 2018
    Subaru Outback / Legacy with factory installed McIntosh stereo:
    Not available in North America :(
    HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 10E
    HT: Samsung 75QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10
    No fingerprints! :)
  • CGTIII
    CGTIII Posts: 1,245
    edited August 2018
    Tony M wrote: »
    tonyb wrote: »
    Tony M wrote: »
    That's what I was wondering, very sweet. Man, I wish I still had some of those cars, built like tanks too. You would total out a car today if you hit one with one of those beasts, maybe get a dent on your bumper. Closest I ever came to the Starfire was a Delmont 88 and a Buick Riviera GS, a 425 and 455 in 'em too. Used to just bury the old camero's with the 327's 350's and 400's.
  • CGTIII
    CGTIII Posts: 1,245
    My Uncle had this 65ish Buick Wildcat. A White car with a red interior. Chrome everywhere. It was a jaw dropper of a beautiful car![/quote]
    That's what I was wondering, very sweet. Man, I wish I still had some of those cars, built like tanks too. You would total out a car today if you hit one with one of those beasts, maybe get a dent on your bumper. Closest I ever came to the Starfire was a Delmont 88 and a Buick Riviera GS, a 425 and 455 in 'em too. Used to just bury the old camero's with the 327's 350's and 400's.[/quote]
    I just went to the web and I see all kinds of picks now that show the exhaust coming out of the rear quarter panels of Starfires. I loved it in the wintertime. You could see the steam coming out real well. I sure miss that car. I like it painted white or black. Black looks like a better choice though. Mine was maroon... :(
