SDA not working in left speaker anymore
Hi Everyone,
Have a question for the collective wisdom of the group - I noticed today that the SDA driver and tweeter in my left speaker is no longer working. It's been working so I checked the cable connections and everything is secure and correct. Haven't moved the speakers and they haven't fallen or anything. Has anyone encountered this and if "yes" what did you do to fix it? I have a pair of the original SDA'2s:
They look like these:
http://forum.polkaudio.com/discussion/159791/picked-up-sda-2-custom-blade-blade-ideas
Thank you all for your help, I really appreciate it!
    Tony M Posts: 11,734
    Can you pull the interconnecting cable out and check it for continuity?
  • westmassguy
    westmassguy Posts: 6,850
    edited August 2018
    Tony M wrote: »
    This^^^^^
    On the 1st, 2nd, and 3rd generation SDAs, the plus + signal from the opposite speaker is sent over the Interconnect Cable, so both conductors carry signal. If the cable checks out, you'll have to pull the PR and have a look inside for anything amiss.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Thank you Tony, I really appreciate it! The great news is that I found the problem - I was running my receiver's signal through an old DBX route selector and ADC EQ. Both of them need their buttons cleaned. When I removed them everything was working again and I have my big soundstage back.
    F1nut Posts: 52,009
    Good, now throw those in the dumpster.
    Clipdat Posts: 13,100
    Agreed. Less is more. I'm all for getting unnecessary things out of the signal path.
    Or a can of De-Oxit should be ordered.
  • Did that to, cleaned up the EQ but the DBX box still needs some work as now there's no signal.
  • Found out that my interconnecting cable has a short in it at the connector. When I pull it up the SDA kicks in and when I allow it to lay on the floor it goes out in my left channel. Shouldn't be to hard to reconnect the connector. Has anyone removed and re-soldered their interconnect cable?
    pitdogg2 Posts: 27,340
    Connector on the speaker or cable itself? The blade/blade connector on the speaker can get wonkie. I had to get inside mine and squeeze the metal together for a tighter grip on the cable. If it's the cable then good luck. I'd build a new one and go with a neutrik connector on the cabinet as well.
    ( sorry man my mind is mush at the moment spelling could be off)
