My SRS update
13»
  • crashb4
    crashb4 Posts: 222
    I will be as well.
    Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
  • sansuibutch
    If these caps don't give me the sound I prefer il be grabbing the 4.4uf and 12uf sonicaps to install. Easy and cheap enough..worht a shot
  • y_w8
    y_w8 Posts: 13
    Why did you remove the two bypass caps?
  • y_w8
    y_w8 Posts: 13
    Also, what did you insulate with behind resistors and between caps?
  • crashb4
    crashb4 Posts: 222
    y_w8 wrote: »
    The bypass caps are no longer needed with the improved film caps. The insulating material is simple double sided tape.
  • sansuibutch
    sansuibutch Posts: 200
    crashb4 wrote: »
    I will be as well.
    Did you ever replace the caps you mentioned? Just wondering if you did and the results?
  • crashb4
    crashb4 Posts: 222
    Life keeps getting in the way. I have not replaced them as yet. It is on a long to do list. I will report back after the replacement.
  • y_w8
    y_w8 Posts: 13
    Ha! Like crashb4, life has a funny way of re-prioritizing the to-do list. I haven't been able to go beyond planning my sis upgrades, yet..
  • y_w8
    y_w8 Posts: 13
    ...SRS...
