My SRS update
I will be as well.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
If these caps don't give me the sound I prefer il be grabbing the 4.4uf and 12uf sonicaps to install. Easy and cheap enough..worht a shot
Why did you remove the two bypass caps?
Also, what did you insulate with behind resistors and between caps?
The bypass caps are no longer needed with the improved film caps. The insulating material is simple double sided tape.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS -
I will be as well.
Did you ever replace the caps you mentioned? Just wondering if you did and the results? -
Life keeps getting in the way. I have not replaced them as yet. It is on a long to do list. I will report back after the replacement.Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
Ha! Like crashb4, life has a funny way of re-prioritizing the to-do list. I haven't been able to go beyond planning my sis upgrades, yet..
...SRS...
