The Tale Of 3 Tweeters
I can, but I've got better things to do, so you'll be waiting a very long time. How about you prove they are different. Prove to us that you're an engineer and not the blowhard you've shown us here. Go ahead, do it!
As for the dome materials, they are NOT the same. Your first clue should have been the fact they don't even look the same. The SL3000 was primarily silver colored. The SL2500 is black.Political Correctness'.........defined
President of Club Polk -
SoundMann1 wrote: »
Maybe so, but I get it right the first time. You aren't so lucky.
So, are you going to prove to us the ferrofuild is different or are you going to continue side stepping, deflecting and generally getting everything wrong? I'm betting you'll do the latter.Political Correctness'.........defined
Post edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
SoundMann1 wrote: »
You are delusional. The facts prove you wrong, yet you continue to ignore them. Not very engineer like. Of course, you aren't one to begin with.
Please keep digging, I find someone like you quite amusing. Sort of like toying with a cat by dragging a string on the ground and leading them head first into a wall.Political Correctness'.........defined
SoundMann1 wrote: »So, are you going to prove to us the ferrofuild is different or are you going to continue side stepping, deflecting and generally getting everything wrong? I'm betting you'll do the latter.
Wrong again! The SL3000 is clearly advertised as having a special low viscosity ferrofluid!
The SL2500 behaves like a tweeter with conventional ferrofluid!
From Polk literature......The voice coil, wound around an aluminum voice coil former, is cooled by an exotic ULV (ultra-low viscocity) magnetic fluid. This material, which has a viscocity close to that of water, enables the SL2500 to exceed normal listening levels without loss of performance or reliability.
Funny watching you run head first into that wall again and again and again and.......
In England, the game known in America as "Clue" is called "Cluedo".
The most entertaining thread in quite a while."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
SoundMann1 wrote: »From Polk literature......The voice coil, wound around an aluminum voice coil former, is cooled by an exotic ULV (ultra-low viscocity) magnetic fluid. This material, which has a viscocity close to that of water, enables the SL2500 to exceed normal listening levels without loss of performance or reliability.
Since you have yet to post anything of verifiable value, you will have to prove that the above quote exists concerning the tweeter in question!
The quote F1nut referenced is from page 3 of a brochure on the Monitor 2 series speakers. You can read the brochure in its entirety here:
https://us.v-cdn.net/5021930/uploads/attachments/4/7/5/0/2/39195.pdf
Quoting more extensively from the Monitor 2 Series brochure:
"Featured in the Monitor 4.6, 5jr+, 5, 7, 10 and 12, the SL 2500 tweeter makes a major contribution to the improved performance of the Monitor Series 2. Sharing much of the technology of the incomparable SL 3000 tweeter used in the Polk Flagship SRS series, the SL 2500 is a highly refined refined, technically advanced driver.
The voice coil, wound around an aluminum voice coil former, is cooled by an exotic ULV (ultra low viscosity) magnetic fluid. This material, which has a viscosity close to that of water, enables the SL 2500 to exceed normal listening levels without loss of performance or reliability."
I find it odd that the term "Tri-Laminate" is conspicuously absent from the brochure's description of the SL2500 tweeter, even though it says the SL2500 shares much of the SL3000's technology. The only place the term "trilaminate" is used in the brochure is on page 5, when giving a description of the midbass driver:
"Polk's high performance 6 1/2" midbass driver is used in each Monitor Series 2 Loudspeaker. Its proprietary trilaminate polymer diaphram structure offers excellent transient response and near absence of midrange coloration."
The defining technical aspect of the SL3000 tweeter is it's Tri-Laminate dome structure. I find it odd that Polk would mention that the SL2500 and SL3000 use the same ULV cooling fluid, but neglected to mention that the SL2500 and SL3000 also shared the same Tri-Laminate dome structure...if indeed they did
On which credible source did you base this comment?:
"The SL2500 behaves like a tweeter with conventional ferrofluid!"
Further, on which credible source do you base your belief that the SL 2500 is a TL tweeter?
At this point, I don't know whether the SL 2500 is a TL tweeter or not. That is why I requested clarification from Polk.
Proud and loyal citizen of the Digital Domain and Solid State Country! -
SoundMann1 wrote: »txcoastal1 wrote: »Soundman
If you ever sell those speakers please disclose your modifications and this thread
I would add the zobel capacitor before then.
The 5.8uf shunt cap creates a Contour Network, not a Zobel.Home Theater/2 Channel:
dhsspeakerservice.com/ -
SoundMann1 wrote: »DarqueKnight wrote: »The marketing brochure for the RTA TL series (RTA 15TL, RTA 11TL, and RTA 8TL) raves about the SL3000 Tri-Laminate tweeter used in the RTA 15TL and RTA 11TL, but says nothing about the SL2500 tweeter used in the RTA 8TL. Polk was obviously proud of its Tri-Laminate tweeter technology, so why the silent treatment about the SL2500 tweeter?
If the SL2500 is not a Tri-Laminate tweeter, what about the RTA 8TL makes it a TL series speaker?
All you have to do is to compare the 2 tweeters side-by-side to see that the diaphragms are indeed the same composite.
I surmise that the only real difference is the type of Ferrofluid they use.
You were certainly and unequivocally wrong about the SL2500 and SL3000 using different types of ferrofluid.
I do not have an SL2500 to compare side-by-side to an SL3000. Have you done a hands on side-by-side visual comparison of the SL2500 and SL3000?
The cover page of the Monitor 2 series brochure shows a closeup of the Monitor 12 Series 2's SL2500 tweeter. That tweeter does not have the glossy metallic appearance of the SL3000's dome. It has the "matte-finish" and woven textile structure similar to the appearance of the silk domes of the RD0 series tweeters. However, that woven structure might be a reflection of the fabric ring surrounding the dome.
I have found some other pictures of the SL2500 from various sources on the Internet, but I can't say for certain that the SL2500's dome looks just like the SL3000's.
I love a good mystery.
I just want to know when the magnet falls apart.Don't take experimental gene therapies from known eugenicists.
BlueBirdMusic wrote: »The most entertaining thread in quite a while.
All it lacks is a sidebar black paint discussion.
If I was Soundmann1, I'd just drop it because you have been pwned. They brought the facts and you brought the hot aire. What types of products do you engineer? I'd prefer to avoid those products. If it was this easy to debunk your claims, I don't want to use anything you've engineered.
SoundMann1 wrote: »If I was Soundmann1, I'd just drop it because you have been pwned. They brought the facts and you brought the hot aire. What types of products do you engineer? I'd prefer to avoid those products. If it was this easy to debunk your claims, I don't want to use anything you've engineered.
Shut your filthy, lying mouth!
Someone's testy this morning. Don't let the facts get in the way of the delusions.
That is completely uncalled for!! ANY credibility you may of had just was flushed with that comment.
Feel free to edit your post but my quote of your post will live on and show your true self!Post edited by [Deleted User] on -
