The Tale Of 3 Tweeters
1356
    F1nut Posts: 51,845
    Ok, but you are wrong.
    xschop Posts: 5,209
    Whether frame or dome, some of the 194s have resonance issue/s. Confirmed by other member complaints/feedback as well. The 10B crossover was recapped as well as the CRS+ crossover.
  • [Deleted User]
    [Deleted User] Posts: 7,626
    "So saying anything at all that might actually get through to the OP that he does not have TL speakers even though he is using the wrong tweets, no matter how thick headed the individual might be, is off limits and he should be allowed to live with his delusion, and to try and convince others here that he is correct in his false belief?"
    No, that's not what I said. This forum requires participants to act in a civil manner to other members. You can't call them "fools" or "morons" either directly or in quotes from other people. If you do the post will be either edited or removed. If someone posts something that you don't agree with, fine state your disagreement in a reasonable manner. If they choose to disregard your sage wisdom or temper it with their particular experience, fine let it go. In the big scheme of things having the right or wrong tweeter (according to you) in a pair of +25 year old speakers isn't much of a crime.
    I can tell you from direct experience neither Matt Polk nor Stu Lumsden would want uncharitable treatment of anyone concerning their designs.
    Viking64 Posts: 7,573
    SoundMann1 wrote: »
    Fair enough, but the "fool" part was meant as constructive criticism.
    F1nut Posts: 51,845
    SoundMann1 wrote: »
    You should be BANNED!
    You'll be gone LONG before I am.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    SoundMann1 wrote: »
    So you are saying that Polk was wrong for labeling the RTA 8 with the SL2500 TriLaminate tweeter a TL?
    Polk wasn't "wrong" for labeling the RTA 8TL, as a Tri-Laminate speaker. But the labeling choice is curious considering that the other speakers with the "TL" designation use the SL3000 tweeter: SDA SRS 1.2TL, SDA SRS 2.3TL, SDA SRS 3.1TL, RTA 11TL, RTA15TL. There is also the official "TL" modification for the 1989 version SDA CRS+ which specified the SL3000 tweeter, along with the addition of a 5.8 uF capacitor. Note that Polk didn't just pop in an SL3000 into the CRS+ and call it a TL speaker. The Polk schematic for the CRS+ TL modification can be found here:
    https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26710.pdf
    It is interesting to note that speakers in the Monitor Series II line, which also used the SL2500 tweeter, were not designated as "TL" models. This would lead one to think that there is more to a "TL" designated speaker than just the addition of a Tri-Laminate tweeter. There must have been something special about the RTA 8TL's crossover and SL2500 tweeter combination that warranted the "TL" designation. It would be great if @KennethSwauger would ask Stu Lumsden why the RTA 8TL carried the "TL" designation, although it did not use the SL3000 tweeter.
    I am guessing that Polk originally planned to modify the RTA 8T to use the SL3000, but couldn't make it work. They were probably able to modify the RTA 8T's crossover enough to get it close to the theoretical level it would have had with the SL3000, hence the "TL" designation.
    Before we get carried away with the prestige of Tri-Laminate techology, we should note that, in strict technical terms, Polk could have named any of their speakers with a "TL" designation because all Polk speakers used drivers that used Tri-Laminate techonology:
    Figure 1. Description of 6-1/2" Trilaminate driver from 1990 brochure on the SDA SRS TL series.
    Figure 2. Description of 6-1/2" Trilaminate driver from 1987 comprehensive brochure on Polk speakers.
    The capture below from the 1990 SDA SRS TL series brochure makes it clear that the "TL" designation refers to the SL3000 Tri-Laminate tweeter that was, at the time, exclusive to the 1989-1990 vintage SDA SRS series:
    Figure 3. Explanation of "TL" designation from 1990 SDA SRS series brochure.
    Here is a link to the entire 1990 SDA SRS TL series brochure:
    https://polksda.com/pdfs/SRSTLBrochure1990.pdf
    SoundMann1 wrote: »
    TL tweeters make TL speakers!
    No. TL Tweeters do not make TL speakers any more than a Ferrari engine makes a Corvette a Ferrari. You have to consider the total system in which a component is used.
    SoundMann1 wrote: »
    That's exactly what you are doing when you use run-of-the-mill SEAS/RDO textile dome tweeters, and pretend that you have TL-modified speakers, let alone pretend that they are an upgrade of the actual TriLaminate models!
    Now you are impugning the honesty and integrity of Polk's engineering department by implying that they were lying when they said the RD0 series tweeters are upgrades from the SL series tweeters. While some people have expressed a preference for the original SL tweeters, most, myself included, much prefer the sound performance of the RD0 tweeters.
  • mlistens03
    mlistens03 Posts: 2,767
    SoundMann1 wrote: »
    SoundMann1 wrote: »
    SoundMann1 wrote: »
    I thought I was reading a Doc Hardy post :lol:
  • tonyp063
    tonyp063 Posts: 1,133
    edited July 2018
    Pay particular attention when you see a DarqueKnight post @mlistens03 Micah.
    You will learn things.
    Post edited by tonyp063 on
  • lightman1
    lightman1 Posts: 10,797
    mlistens03 wrote: »
    SoundMann1 wrote: »
    SoundMann1 wrote: »
    SoundMann1 wrote: »
    They can run neck and neck on extended verbage posting...
    txcoastal1 Posts: 13,514
    But they speak from experience ;)
    Toolfan66 Posts: 18,099
    edited July 2018
    I have been banned for less than calling someone a fool, and a moron, you should consider yourself lucky you are still here now. I think Ken is giving you the benefit of the doubt that you are here for the right reasons. Everyone here is doing nothing but trying to help you understand the facts of the TL process...
    Ken, I think we have reached 30 year old speakers!! B)
    Edit: you did post +25 year old speakers.. LOL!!
    Soundmann1 are you a Whoopie Goldberg fan?
    nooshinjohn Posts: 25,934
    SoundMann1 wrote: »
    Already circling the drain here. I put him on ignore.
    edited July 2018
    If they choose to disregard your sage wisdom or temper it with their particular experience, fine let it go. In the big scheme of things having the right or wrong tweeter (according to you)in a pair of +25 year old speakers isn't much of a crime.
    I also tend to think they would want a Polk employee, (such as yourself) to step in and offer the OP the correct information, even if they are a 25 year old speaker. Nobody here wants to give the OP a hard time, but it would be really nice to have Polk’s representive to the forum step in and support the members in cases like this rather than look the other way while bad information is being spread.
    That’s just my two cents.
  • [Deleted User]
    Fair enough, I'll ask Stu about the "TL" designation. He may be awhile before he answers.
    F1nut Posts: 51,845
    xschop wrote: »
    The resonance reported by some was an issue isolated to a certain batch of RD0194 tweeters. That issue is far different than the alleged ringing heard by only one individual.
    The tale of 3 Tweakers..
  • BlueFox
    BlueFox Posts: 15,250
    SoundMann1 wrote: »
    Well I know I'll take the word of long time knowledgeable members 9 days a week and twice on Sunday over that of a confused newbie.
    I am an inventor and engineer who has been involved with the audio industry for 40 years!
    I am hardly a confused newbie!
    Have you upgraded your speaker cables? As an engineer involved in audio you must know how critical cables are to achieving good sound.
    Tale of tweaker 2
    Tale of tweaker 1
    I've brought this point up before regarding the information in the TL brochure saying that the drivers were also tri-laminate and I was told that it was a marketing error or something like that. And that it was only the tweeters that were tri-laminate.
    Stu Lumsden just posted in another thread, so maybe he can clear this up. :)
    Viking64 wrote: »
    Where is this thread??
  • [Deleted User]
    Here's my Q&A with Stu:
    Q: The question has come up on the forum has been raised, "what makes a TL speaker?" Is it called that because it has a trilaminate tweeter or more an overall TL design encompassing a TL tweeter and a TL specific crossover?
    In other words, if I take an older Monitor speaker and replace the stock tweeter with a TL tweeter (because I like the sound of the TL tweeter more than the stock) and not change the crossover can I now call it a TL speaker?
    A:Well, yes you can replace the tweeter and call it a TL but the best thing to do would be to slightly modify the crossover to fit the tweeter to whatever speaker you are updating – assuming that there is no spec for that change.
    I hope this is helpful.
    F1nut Posts: 51,845
    Key words,
