Vintage Monitor and SDA Speaker Deals
1…131132134136137…259
  • Unknown
    edited April 2018
  • FestYboy
    FestYboy Posts: 3,861
    edited April 2018
    Oh common, out with it! No need to pull punches here. ;)
  • Unknown
    edited April 2018
    Viking64 Posts: 7,824
    TL = True Love
    audioluvr Posts: 6,079
    Viking64 wrote: »
    TL = True Love
    What. No grammar correction??? Slipping...
    FestYboy wrote: »
    Oh common,
    erniejade wrote: »
    Thoes are not TL.
    audioluvr wrote: »
    Viking64 wrote: »
    TL = True Love
    FestYboy wrote: »
    Oh common,
    erniejade wrote: »
    Thoes are not TL.
    Swallow.
  • kmeek
    kmeek Posts: 225
    Well I got them. Now I didn't notice this until I got them home and have them right next to each other. They don't appear to be a matched set. I have the left and right speaker and they both appear to be TL's. The left speaker top and bottom caps are thicker than the right one and has more of a red hue to the oak where the right is more golden....
    Should I be concerned?
    They sound great and I did not notice the differences when they were in normal listening positionrvnd99mfb8kv.jpg
    Judging by the serial numbers, you have one TL and one non-TL, which may explain the height difference. Is the shorter one missing feet?
    edited April 2018
    It's also odd only one says "TL" with 5 us patents and not the other with only 2???
  • kmeek
    kmeek Posts: 225
    Viking64 wrote: »
    No the feet are on the shorter ones. It just appears the top and bottom oak panels are 1/4 inch shorter in thickness....
    Not too concerned about the minor appearance difference but I hope I don't have a TL and non-TL speaker.....
  • kmeek
    kmeek Posts: 225
    The guy said he bought them new in 91 as a close out from a stereo place here in Phoenix that was going out of business.....
    kmeek wrote: »
    The best way to be sure is to pull some of the drivers and look at the wiring harnesses and the crossovers themselves. There is a big difference as to how TL's and non-TL's are wired. At least with my 2.3's. I think the same principle applies to the 1.2's.
  • dkfreebird
    dkfreebird Posts: 1,189
    edited April 2018
    Pull the crossover plate out on the one that says 1.2 and see if it is has c or b printed on it..
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited April 2018
    kmeek wrote: »
    These look to have Larry's Rings, or at least Hurricane Nuts according to all the Hex Head Machine Screws, even the PR's.
    Have the X-Overs been updated as well?
    nooshinjohn Posts: 26,160
    Mine are TL, and start with 62xx serial numbers so you are good to go. This is the first I have heard to there being two different thicknesses in the end caps. Could be that Polk changed things on the fly, as they were known to do that back in the day. The other is that one of the two speakers had the caps replaced at some point.
    The good news is they are both TL's.... now let the mods and upgrades begin.
  • verb
    verb Posts: 10,176
    Congrats @kmeek ! Looks like a fun project! Those speakers are what I aspire to have someday! Have fun! :smile:
  • FestYboy
    Viking64 wrote: »
    TL = True Love
    Big difference in the 2.3 and 2.3tl as 2.3 used 3 different woofers.
    Not a big difference in the 1.2's are same woofers but different tweeters and slight difference in the xo.
    That makes sense. My 2.3TL's came from the factory with the instruction manual for the SDA SRS 1.2 and the SDA SRS 2.3.
    There was a loose, single-page addendum tucked inside the manual with the heading "Addendum to SRS 1.2tl and SRS 2.3tl Manual". The only difference shown in the diagram was the new layout of the 2.3TL drivers.
    The "Physical Specifications" for the 1.2TL were the same as the 1.2, save for the new tweeters. The 2.3TL listed the switch to 6 x MW6510, and of course, the new tweeters.
  • kmeek
    kmeek Posts: 225
    Thanks for the heads up. I can handle the minor cabinet differences. The cabinets are in excellent shape and I am stoked to finally get some SRS's let alone TL's...
  • krazypolk
    krazypolk Posts: 745
    edited April 2018
    While searching through Craigslist I saw an ad for some ls70's for 140 dollars. Not sure if they are the sound that I like but they sure look nice. Any thoughts?yza4dfn8ovp6.jpg
  • FestYboy
    I'd rock them in a heartbeat. I'd take a close look at the grill surrounds though and if there's damage, come in with a lower bid.
  • krazypolk
    Sorry but what are grill surrounds?
    Tony M Posts: 12,025
    edited April 2018
    The LS series had strange grills. Only the cloth portion was supposed to be removed.
    Millions(?) of LS speaker grills were damaged by us people trying to remove the grills like we were used too.
    BUT...those look like they were the old school style grills.
  • FestYboy
    If you look closely at the lower photo, you'll see small holes to the outside of the rubber grommets that hold the cloth grill. Those are to locate the plastic surround for said grill.
    I see them now.
    So they are probably broken.
    But for the money, I'd probably go look closely at them and see if the woofers move. ;)
  • FestYboy
    Not all of them, note how the grill on the table stands off and the holes are very dark indicating that at least some came out intact.
    At the very least they're worth a look and listen.
  • krazypolk
    While reading up on this model, it appears that the ls70's are the least desirable of this particular line. I saw a lot of praise for the ls90 and the smaller ls50. Why so?
    edited April 2018
    They have smaller woofers.
    I was rocking my LS90's today. :D:pB)
