Basement Leak at Verb's House!
    msg Posts: 9,501
    Viking64 wrote: »
    If I ever went to Verb's house, I would probably take a leak in his basement. Just sayin'.
    Me too.
    Only I'd go on that same wall after it's fixed.
    And on any spare Monoprice Tube Integrateds.
  • verb
    verb Posts: 10,176
    msg wrote: »
    Viking64 wrote: »
    Me too.
    Well there is a bathroom down there, in case you're not used to indoor plumbing! :smile:
    msg Posts: 9,501
    It's just not as fun. Kinda like when you're camping, you know?
  • verb
    verb Posts: 10,176
    Exactly! Or at the edge of the property 200ft away! Gotta drain the vein! :smile:
    Viking64 Posts: 6,705
    Or like when you're in the towel section of Bed, Bath & Beyond and Led Zeppelin's "The Lemon Song" is playing over the PA and you made eye contact with that hot cashier on your way in and.....nevermind. :#
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    Remember to never buy towels at BBB! :smile:
    verb wrote: »
    You might want to think twice about that case of Mountain Dew I sent you while you are at it. :p
  • mdaudioguy
    mdaudioguy Posts: 5,165
    msg wrote: »
    Viking64 wrote: »
    Me too.
    I guess there was some objectionable language in the video I posted... Oops! But leaking on one of those amps might have the same effect as leaking on an electric fence. >:)
  • Jaybeez
    Jaybeez Posts: 748
    edited April 2018
    verb wrote: »
    la2vegas wrote: »
    Forget all that high tech mumbo jumbo. :D
    BTW @la2vegas how did you know I was of Dutch heritage? 1st generation American! Those Dutchies sure know all about water management! :smile:
    My wife is first generation as well. Juist ja!
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
    audioluvr Posts: 5,457
    verb wrote: »
    Oh. Crap. You too?
    msg Posts: 9,501
    You guys are about to get passed.
    On tha left haaand side, of course.
  • lightman1
    lightman1 Posts: 10,776
    msg wrote: »
    Wow! One of the most obscure references I've heard in a while! Gold star, Scott!
  • verb
    verb Posts: 10,176
    Day 2 and all is good. Dutchies prevail! :smile:
    verb wrote: »
    DUTCH METAL!!!
    https://www.youtube.com/watch?v=c7ZIoWEbRX8
    mhardy6647 Posts: 33,092
    Golden Earring were Dutch, weren't they?
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited April 2018
    In a past life I was a QC manager for dry cast and wet cast concrete product company and can say with certainty you are going to have to do some more work to remedy the issue.
    As mentioned hydraulic cement should be used such as damtite. Keep in mind all concrete is porous and that kind of water is going to find it’s way in other areas.
    That hole may be the most visible but I’m betting there are other cracks in the poured wall that are seeping at least. Also know that the water had already made it past the tar coating on the outside of the wall.
    There were similar issues with our home but were remedied prior to our purchase. The remedy included two yard drains to remove surface water around the house, which are marvelous btw. Also the perimeter of the home was dug and French drains were installed. While the ground was dug out a second drain from was installed under the foundation and plumbed to a second sump well with an two additional pumps, one on a battery backup.
    Been here two years and witnessed record breaking rainfall with local flooding, but our basement has stayed dry. We have bare 9ft poured walls in our basement so it’s easy to inspect, but I will say it’s incredible how much water pours in our sump wells during a periods of heavy rain. The pumps kick on every 30 seconds or so at those times to empty the wells.
    With your wall leaking like that you’re getting some serious water as we are and you should strongly consider those types of remedies. Good luck.
  • verb
    verb Posts: 10,176
    Yep agreed. The obvious source was the rebar hole. Another thing to worry about! :smile:
  • verb
    verb Posts: 10,176
    Ja, dat zijn ze!
    https://youtu.be/Sm1q1XoN_Qo
    Yes. Shocking Blue also. Their hit "Venus" sort of opened the doors for several Dutch bands of that era. Focus, Solution, Mouth and MacNeal, The George Baker Selection, Tee Set, and of course Golden Earring.
  • westmassguy
    westmassguy Posts: 6,850
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    Heck, I remember nearly all of them :)
    As a nearly pointless aside, back in the halcyon days of world-wide short wave
    broadcasts, I was a big fan of Radio Nederland. Had a bumper sticker from 'em on my Bronco 'n' everthing.
    Ironically, despite many trips to Europe in the ensuing decades, I have yet to visit
    the Netherlands. Would like to go sometime. Heck, one of my clients is even a Dutch biotech company -- but we've done our business by telecon. :|
    tonyb Posts: 32,908
    Having done many myself, this is good advice. Those plugs are nice you used, but they are a temporary solution. As long as water is still entering the hole from the outside, that hole will eventually become bigger, and the plug worthless.
    Getting the water away from the foundation is key, then fixing the known holes on the outside with hydraulic cement, letting it dry, and covering that with either tar or a rubber compound such as what they fix cement swimming pools with and you'll never have a leak again.
    If you do drain tile, make sure you have enough wash stone around the pipe to keep it from eventually clogging. If you do a French drain type of trench, make sure you put a fabric paper over the top to keep dirt and stone separated, and not get clogged up also. Good luck to you.
  • verb
    verb Posts: 10,176
    Last night we had horrendous rain. Water table up way high, as before. Verb's basement is dry! Yay!
    Clipdat Posts: 12,622
    How much do you think it's going to cost to fully "fix" the issue from the outside? $5k?
  • verb
    verb Posts: 10,176
    I just have to re-grade the areas of concern. That should take care of it. Idea is to get the water to flow away from the house.
    I have some gutter work to do as well.
    All DIY stuff :smile:
  • monepolk
    monepolk Posts: 1,141
    Yeah it's amazing how cleaning out a gutter will stop a basement water leak :smile:
    That's wonderful news, Dave! Now to get the poltergeist out of your attic. :p
  • verb
    verb Posts: 10,176
    I ain't going up there dude!
    verb wrote: »
    Dude! You're missing out! :p
    https://www.youtube.com/watch?v=ubYyofUBnec
  • verb
    verb Posts: 10,176
    Update - Last 24 hours we've had significant rainfall. As before, water table way up high, the river at the back of the property water level up to the top of the bank. First thing this morning I checked the repair, bone dry! :sunglasses:
