Do power cables make a difference?
12467…14
  • Upstatemax
    Upstatemax Posts: 2,862
    When was the last time you listened to the sound stage of a space heater?
    Every morning.
    When I take a grumper.
    My master bathroom can get chilly.
    FestYboy wrote: »
    @ Aside from the cable's power capacity, is there any value that would help determine what the cable may or may not do with an existing rig? Something objective?
    Your due diligence in doing your own research. Reviews...maybe people who have used the same brand on similar gear as yours. There is no cut and dry way of telling what your asking, which means trial and error come into play.
    ....and really, isn't all of audio a trial and error thing ? We can make the best guess, narrow down the field in any audio product, but in the end it always comes down to trial and error.
    That's why I'm a big fan of buying used, cables or gear. Not only do you save coin on the front end, if you don't like something it's way easier to recoup all if not most your money selling it.
  • Jimbo18
    Jimbo18 Posts: 2,351
    When I got the Pioneer Elite SC-63 receiver, I bought a $50 Pangea power cable for it. Not sure it makes it difference or not, but it's not much more money and it can't hurt.
    I kind of feel like "everything matters" but for a HT system, it matters less and I am not enough of a critical listener to what to spend significant money on a power cable. But something better than stock, that doesn't cost much, doesn't seem like a bad idea.
  • FestYboy
    FestYboy Posts: 3,861
    Ok so maybe the better question is: why isn't there some standard or value that can be assigned to cables?
  • FestYboy
    I understand the patent end of things, but afaik, every power cord or IC has an in and an out. I'm wondering why no one has taken a known "signal", put it through the cable and measured the difference, and we're then able to correlate that difference to a sonic signature.
    I get that there will be a change based on the other equipment within the rig, but it'd be a start?
    mhardy6647 Posts: 35,550
    FestYboy wrote: »
    Oh it's been done -- but generally by resources with, shall we say, skin in the game.
    That gets the other side in a tizzy... and the predictable hilarity ensues.
    I think that it's safe to say that the magic, if there is some in better power cords,
    generally lies in a realm outside of L, C and R. That doesn't mean it's not
    real -- but it probably does mean it's hard to quantify or even evaluate in an objective manner.
    That's OK, IMO -- per my open ears and mind comment 'way earlier in this thread.
  • mpitogo
    mpitogo Posts: 523
    edited April 2018
    Thank you all, maybe I will look into it further and experiment but not to the extent @Joey_V with the AQ Dragon cables. Three of those @13.2K is slightly more than my LR 2.0 setup. My thoughts are more inline with @maxfrompa. I’ve upgraded all circuit paths leading to the outlet, wire service to the house, the mains panel and breakers and outlets, the most costly part in wall wire is untouched but meets code so it’s OK in my mind.
    I was thinking of looking with a scope to see the noise before and after my voltage regulator. The regulator reads typically 125v but dips to 124/123 when my LR 2.0 system is running. The regulator has an 8’ cord to the outlet the rest have a short run. Upgrade the regulator, preamp and power amp? Move the OE power amp (thick cable) to the oppo cd player. The TT drive is hard wired, I would have to desolder the mains and install an IEC receptacle or not since it is not in the signal path.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • vcwatkins
    vcwatkins Posts: 1,992
    mpitogo wrote: »
    Measure with your ears.
  • afterburnt
    afterburnt Posts: 7,892
    Measure once cut twice.
    Impetigo, I am curious why you upgraded everything in the house but you are dubious about power cables?
    Sincerely
    Daktari
  • mpitogo
    mpitogo Posts: 523
    current is current and I=V/R
    Well, yes, for DC, V/R = I
    But for AC "R" isn't R per se, it's Z
    And Z (impedance) has three components.
    • (DC) resistance (R)
    • inductive reactance (L)
    • capacitive reactance (C)
    And those latter two depend on frequency.
    Now, I'll grant you that frequency is more or less fixed when we're talkin' about AC mains (60 Hz in the US and Canada, give or take) -- but there's more to even Ohm's law than meets the eye.
  • FestYboy
    Found this interesting (from the same linked thread above): http://www.conradhoffman.com/Low_Level_ICs.htm
    More food for thought (or fuel for fire depending).
  • kharp1
    kharp1 Posts: 3,453
    FestYboy wrote: »
    Two different pieces of equipment on a test bench can give you the exact same signal on test equipment, yet, sound dramatically different.
    kharp1 wrote: »
    FestYboy wrote: »
    Thus HH Scott's Chief Engineer D.R. von Recklingshausen's famous line:
    "If it measures good and sounds bad, -- it is bad. If it sounds good and measures bad, -- you've measured the wrong thing."
    http://hhscott.com/vonrecklinghausen.htm
    original source: The Absolute Sound magazine, vol. 12, no. 50
    "While no one person is ever responsible for a major new technology, Daniel von Recklinghausen, Scott's chief engineer, was certainly a major force in the development and popularization of FM radio. von Recklinghausen, unlike his contemporaries, still has designs that are in the forefront of current state-of-the-art audio technology. The EMlT tweeter, which can be found in some of the finest systems in the world was designed by von Recklinghausen. KLH first marketed it as the DVR tweeter.
    von Recklinghausen was, and is, a rare breed of audio engineer -- one who uses his ears and has an open mind. A quote from a Boston Audio Society meeting best illustrates his philosophy:
    This is the kind of dedication to sound quality that is only found today among High End manufacturers. For von Recklinghausen the sound of music was the reference."
  • FestYboy
    kharp1 wrote: »
    FestYboy wrote: »
    Ok, then that begs the question: what is different? I'm trying to get to the bottom of this as objectively as possible while ruffling as few feathers as possible.
  • Nightfall
    Nightfall Posts: 10,083
    FestYboy wrote: »
    kharp1 wrote: »
    FestYboy wrote: »
    Maybe not everything can be measured, or we haven't figured out what we need to measure or how to measure it.
    The ear, brain, and the way they interact is extremely complex.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • kharp1
    kharp1 Posts: 3,453
    edited April 2018
    I could probably assemble an amp (if I wasn't lazy) using the cheapest parts possible and measure one watt and have that one watt look pretty good on the bench. Put it under load and turn it up and it collapses on itself. EVERYTHING in the chain makes a difference. Even the chair you sit in while listening.
  • jdjohn
    jdjohn Posts: 3,437
    mpitogo wrote: »
    I swapped out RCA cables between my preamp and amp for balanced audio cables in the LR 2.0. The difference is incremental but the RCA was’t bad, if anything there is better noise rejection.
    Every upgrade is incremental, but they add up.
  • teekay0007
    teekay0007 Posts: 2,288
    kharp1 wrote: »
    Yeah, I think there's a thread around here somewhere with pics of the favorite listening chairs of CP members.
    I'd opine - take that, Hardy! - that an all important link in that chain also is that of a snuggling puppy or purring key cat in your lap during said listening session. B)
  • mpitogo
    mpitogo Posts: 523
    @kharp1 thinking amp camp?
    @jdjohn AQ Mackenzie 1M replaced Monolith 3” RCA IC.
  • kharp1
    kharp1 Posts: 3,453
    Amp camp is low power, but good power. If you have efficient speakers go for it.
  • afterburnt
    Amp camp is not like Band camp for tweakers?
    FestYboy wrote: »
    kharp1 wrote: »
    FestYboy wrote: »
    Your asking the impossible. By that I mean your asking for everyones subjectivity to be more aligned. Audio is too subjective to place things in black and white boxes.
    Like asking for specs to tell you how a speaker will sound. It may give you some parameters as to it's abilities, but certainly won't tell how it will sound to your ears, in your system, in your home.
    Cables are no different. Which is why trial and error play a huge roll in the industry. Measurements don't correlate into sound signatures, they can be used to help define how it will interact with pieces it's connected to.
    The crux of the matter, when it comes to cables, is that some want a guarantee that by spending x amount of dollars that they will hear positive improvements. There are no guarantees in audio. You can spend 3 times as much and hear worse sound, price doesn't always dictate good sound.
    That's why we have audio forums, to share experiences. What works well with what, to narrow the field and lesson the chances of dropping coin on a turkey. More so, it's a journey of learning with an open mind.
    For instance, if I was to dive into the DIY arena of audio and start building my own dacs, one might assume caps wouldn't matter aside from their values. However I would tap those with experience building dacs, like Rich, before dropping coin on caps to see what works well and sounds better given the same or similar values.
    In other words, the way to move forward in this hobby is to keep an open mind, tap the wealth of knowledge we have here collectively, and experiment a bit with trial and error. That's part of the fun, part of the journey, part of what makes all us audio forum nutjobs like family.
    treitz3 Posts: 20,348
    Well here's one thing that we can all agree on concerning power cords making a difference. Without them, no sound will come out of your speakers.
    *wipes brow* Phew, at least we got that one cleared up. Getting to sleep should be a tad easier now that we have cleared this up. You are welcome.
    Dang it Tom, you had to go ruin the party by injecting common sense stuff. :) I was hoping to hit 20 pages, just cause we can.
    Power cords don't keep me up at night anyway.....but those flashing displays, must be aliens trying to communicate while I'm trying to fall asleep. Little suckers are chatter boxes I tell ya. ;)
    edited April 2018
    tonyb wrote: »
    And we still have a VCR flashing 12:00! Will an upgraded power cord stop that?
  • kharp1
    kharp1 Posts: 3,453
    tonyb wrote: »
    FestYboy wrote: »
    kharp1 wrote: »
    FestYboy wrote: »
    That's just about a "sticky" quality post, pretty much wraps it all up.
  • mikeyb128
    mikeyb128 Posts: 2,885
    tonyb wrote: »
    No, but it might keep time better :lol:
    2 channel:
    Theater:
  • FestYboy
    I can totally appreciate @tonyb 's post, and I get it (to a point). But it also shows that the work hasn't been done yet, an I mean work by there isn't an established correlation between cable sonic signature (or any component for that matter) and how it sounds. Blind testing with a sizeable test group to establish a commonality would be required, then breaking it all down to find that "thing" that establishes the difference.
    I'll be ok with that up until it's time for me to make a purchase, then the objectivist in me is gonna have an issue. (My problem, not being imposed on anyone else).
