Looking for Misc Audio Deals of the Day? Updated info here!
With that toe-in, it looks like the sweet spot would put you about 18" from the fireplace.
"How'd your feet get burned ?'
"Well, I was listening to tunes and ,,...."Sal Palooza -
Let's not forget their great choice of source: "OPPO BDP-205 deck, Roon Ready used in system as DAC and pre-amp (exceptional high fidelity sound)"
(emphasis mine)
While maybe not on par with the speakers & amps, the 205 is no slouch. -
Fair enough. Realized that after I posted it. But still, an OPPO wouldn't be my "go to" source if I had this kind of coin to throw around. Shrug.While maybe not on par with the speakers & amps, the 205 is no slouch.
This is a pretty good deal on some infinity reference speakers, listing says there are 4 of them for $200, but they’ve got polycells instead of the original emits
https://orlando.craigslist.org/ele/d/infinity-reference-three/6524924915.html -
Duhhh, he's using the wall as a heat sink.
This looks like a good deal for you Tejas polkies.
https://austin.craigslist.org/ele/d/krell-integrated-amplifier/6535354150.htmlPS Audio Stellar Gain Cell DAC/Preamp
Denon DVD 2910
Quad 12L Active Monitors
Marin Logan Dynamo 700W -
Marantz SA-15S1 - $700 Just a bit dusty!
https://sfbay.craigslist.org/sby/ele/d/marantz-sacd-sa-15s1-high-end/6540589785.html
Wow! Nothing wrong with that.
Although not the exact model, you get the picture.
https://orangecounty.craigslist.org/ele/d/marantz-reference-sa14-s1-cd/6482650944.html
@Clipdat You should grab it, mine won't go that low. -
How do these Marantz players compare to the Oppo offerings? Peace. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
I've never owned an Oppo, though I have heard them, and I'd say the Marantz is on the slightly warmer side. Detailed yet smooth. Pretty good dac. Mechanism is whisper quiet. I think you have to jump up considerably in price to better it. Even though I just got the PSA Directstream combo I doubt I'll sell my 14.
Audire Parlando Class-A Amplifier currently bid at $351 with under 5 hours to go.
Local pickup only in Orange County. (85 lbs.) No affiliation.
https://www.shopgoodwill.com/Item/50493699Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Is this the same exact model as yours? I thought this one looked newer/older.
Also, it's silver... boooo@Clipdat You should grab it, mine won't go that low.
You will never use the Marantz again after you set to the DirectStream Memory player... it is a couple orders of magnitude better than the Marantz.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I love my Audire Model 1, though someday I will have to part with it.
Audire is highly underrated stuff IMO for vintage. Nice warm tube-ish sound but still has nice muscle and detail. Parlando is 800lb gorilla by comparison, a dual mono in the same chassis amp and I think 100wpc of Class A power - she weighs close to 90lbs! It's a beast.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
The one in the OP is not, the black one pictured in my quote is the same as mine. Silver one in the OP is a 15. -
sa14-s1 looks better/newer. USB input on front, etc.The one in the OP is not, the black one pictured in my quote is the same as mine. Silver one in the OP is a 15.
It is, on their reference line the numbers work from higher to smaller in quality/features I believe.
Hard to tell from the pics, but looks like a Krell KSA-80 Amp and KSP-7B Pre for $750.
https://detroit.craigslist.org/okl/msg/d/krell-amplifier-and-equipment/6538130853.htmlBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I would be on this like flies on a cake!
Sent the guy an e-mail last night. No response yet. Sounds like a smokin deal!
Good luck to you sir! If you get a chance, plug em in and maybe even get an audition. They might be trying to unload a lightning struck dead set.
But I'd definitely go and see in person and try the above or at least smell the guts for that burnt smell. But still, GOOD LUCK Dave!
75lbs. of class A.
It's a potential hernia amp.
I wonder if the PRE has to have that external power supply?Most people just listen to music and watch movies. I EXPERIENCE them.
Marantz Quadradial Rig! 4 VU meters!
https://detroit.craigslist.org/mcb/ele/d/vintage-marantz-mtcerwin-vega/6540150860.html
"Needs to be picked up today!" Did you get it?
I like their Class-A cooling solution:
Eye candy to me! never heard one so i can't comment on it's sound quality!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Never got back to me. I'll attempt to reach out tomorrow. Good eyes @Clipdat didn't even notice the noise floor elevating fan in the background!
Another quad amp! Plus JW Davis Speakers.
https://detroit.craigslist.org/mcb/ele/d/sanyo-dcx3300ka-2-speekers/6510136688.htmlBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Finally got a hold of the guy with the Krells. Boom! It already sold!
I'll assume to you @verb, given the smiley face?
Probably.
