Looking for Misc Audio Deals of the Day? Updated info here!
1…210211213215216…359
    Clipdat Posts: 13,104
    A bevy of Polk speakers for only $50: https://sfbay.craigslist.org/sby/ele/d/polk-audio-speaker-system/6535252300.html
    2x RT i28
    2x T15
    1x Cs245i - Center speaker
    It must be posted, for the atrocious room placement and setup:
    https://sfbay.craigslist.org/pen/ele/d/wilson-audio-pass-labs-and/6538625538.html
  • FestYboy
    FestYboy Posts: 3,861
    I can't imagine that the power cord is stock... And if it is, wow.
    Perfect example of more money than sense. To buy those speakers and amps and then put them like that, in that sized untreated room. Crazy.
    FestYboy wrote: »
    Certainly looks like a stock cord:
    Let's not forget their great choice of source: "OPPO BDP-205 deck, Roon Ready used in system as DAC and pre-amp (exceptional high fidelity sound)"
    (emphasis mine)
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    With that toe-in, it looks like the sweet spot would put you about 18" from the fireplace.
    "How'd your feet get burned ?'
    "Well, I was listening to tunes and ,,...."
  • DaveHo
    DaveHo Posts: 3,584
    Clipdat wrote: »
    (emphasis mine)
    While maybe not on par with the speakers & amps, the 205 is no slouch.
    Fair enough. Realized that after I posted it. But still, an OPPO wouldn't be my "go to" source if I had this kind of coin to throw around. Shrug.
    DaveHo wrote: »
  • mlistens03
    mlistens03 Posts: 2,767
    This is a pretty good deal on some infinity reference speakers, listing says there are 4 of them for $200, but they’ve got polycells instead of the original emits :disappointed:
    https://orlando.craigslist.org/ele/d/infinity-reference-three/6524924915.html
  • kharp1
    kharp1 Posts: 3,453
    Duhhh, he's using the wall as a heat sink.
  • aiconn
    aiconn Posts: 277
    This looks like a good deal for you Tejas polkies.
    https://austin.craigslist.org/ele/d/krell-integrated-amplifier/6535354150.html
    PS Audio Stellar Gain Cell DAC/Preamp
    Denon DVD 2910
    Quad 12L Active Monitors
    Marin Logan Dynamo 700W
  • kharp1
    kharp1 Posts: 3,453
    la2vegas wrote: »
    Wow! Nothing wrong with that. :)
    Although not the exact model, you get the picture.fjxkrddsiq6e.jpghttps://orangecounty.craigslist.org/ele/d/marantz-reference-sa14-s1-cd/6482650944.html
    @Clipdat You should grab it, mine won't go that low.
  • Dabutcher
    Dabutcher Posts: 2,637
    How do these Marantz players compare to the Oppo offerings? Peace. D
  • kharp1
    kharp1 Posts: 3,453
    I've never owned an Oppo, though I have heard them, and I'd say the Marantz is on the slightly warmer side. Detailed yet smooth. Pretty good dac. Mechanism is whisper quiet. I think you have to jump up considerably in price to better it. Even though I just got the PSA Directstream combo I doubt I'll sell my 14.
  • CGTIII
    CGTIII Posts: 1,274
    edited March 2018
    Audire Parlando Class-A Amplifier currently bid at $351 with under 5 hours to go.
    Local pickup only in Orange County. (85 lbs.) No affiliation.
    https://www.shopgoodwill.com/Item/50493699
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    Is this the same exact model as yours? I thought this one looked newer/older.
    Also, it's silver... boooo
    kharp1 wrote: »
  • MrBuhl
    MrBuhl Posts: 2,419
    I love my Audire Model 1, though someday I will have to part with it.
    Audire is highly underrated stuff IMO for vintage. Nice warm tube-ish sound but still has nice muscle and detail. Parlando is 800lb gorilla by comparison, a dual mono in the same chassis amp and I think 100wpc of Class A power - she weighs close to 90lbs! It's a beast.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • kharp1
    kharp1 Posts: 3,453
    Clipdat wrote: »
    kharp1 wrote: »
    The one in the OP is not, the black one pictured in my quote is the same as mine. Silver one in the OP is a 15.
    sa14-s1 looks better/newer. USB input on front, etc.
    kharp1 wrote: »
  • kharp1
    kharp1 Posts: 3,453
    It is, on their reference line the numbers work from higher to smaller in quality/features I believe.
  • verb
    verb Posts: 10,176
    edited March 2018
    Hard to tell from the pics, but looks like a Krell KSA-80 Amp and KSP-7B Pre for $750.
    https://detroit.craigslist.org/okl/msg/d/krell-amplifier-and-equipment/6538130853.html
    Tony M Posts: 12,016
    edited March 2018
    verb wrote: »
    I would be on this like flies on a cake! :oB)
    edited March 2018
    Here's a Krell Pre like in the ad on Ebay... :o:sB)
    http://www.ebay.com/itm/like/253398247391
  • verb
    verb Posts: 10,176
    Sent the guy an e-mail last night. No response yet. Sounds like a smokin deal! :smile:
    edited March 2018
    Good luck to you sir! If you get a chance, plug em in and maybe even get an audition. They might be trying to unload a lightning struck dead set. :s But I'd definitely go and see in person and try the above or at least smell the guts for that burnt smell. But still, GOOD LUCK Dave!
    75lbs. of class A. :oB)
    It's a potential hernia amp. :#
    I wonder if the PRE has to have that external power supply?
  • verb
    verb Posts: 10,176
    "Needs to be picked up today!" Did you get it?
    I like their Class-A cooling solution:
    verb wrote: »
