Post a picture... any picture
^^^Cable management is apparently overrated.
In the second pic, is there a story/explanation behind that turntable ?
I have Google on hot standby, so fire away.
Sal Palooza -
It looks to be a Garrard 401.
The arm on the left is a SME
the one on the back is one of these:
EXPERT LONDON N.2 1952 by silver_night 300b, on Flickr
These photos are (all) from Joseph Esmila's Tribute to "Sound Practices" Flikr group
Sound Practices was Joe Rosen's epochal magazine of the early 1990s that helped, in a big way, rekindle interest in SET amplifiers and high-sensitivity
(ahem, horn) loudspeakers in a big way -- particularly in the US. Interest in that stuff never quite went away in Asia.
https://www.flickr.com/groups/tribute_to_sound_practices/
1. Hydraulic actuator leak? Blown internal o-ring?
2. Engine oil cooler leaking? Could just be the filter seal.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Clutch slave cylinder leaking fluid for some reason. I've been told that it's "normal" for them to weep like this, which I don't really agree with. If you look closely you can see little brown bits. Like you said, I think some internal seal must've given out. I will need to get this addressed I think. Clutch still feels/engages fine though.
Yep, my oil cooler was leaking and made a huge mess. At first I assumed it was one of the orings or gaskets that had failed. I took it apart and noticed the center bolt that holds everything together was loose and there was actually a few mm of play between the top of the bolt head and the Mocal sandwich plate assembly. Not good. Apparently it loosened up over time or I inadvertently loosened it when I was doing my oil change and removing the oil filter.
I was pretty annoyed about the oil getting everywhere, but after I took it apart and put it back together while making sure to snug up that center bolt, I don't see anymore leak like there was.
I did notice a slight weeping of oil coming down from the seal between the Mocal plate and black aluminum adapter/spacer, but it's very slight so I think it might just be excess oil that I used to lube the oring/gasket before I assembled everything. At least that's what I hope.1. Hydraulic actuator leak? Blown internal o-ring?
Zooming in, the fork boot looks like it has grease around it... That could easily cause the weep if it got warm (the grease starts to separate and the thinner portions will wick).
I'm going in with Subaru... As that's a longitudinally mounted trans. -
Correct. It's a Scion FR-S, aka Subaru BRZ.
I don't recall this area ever weeping/leaking like this. I don't like it. Not one bit. I need to find a competent mechanic to take it to to fix it.Zooming in, the fork boot looks like it has grease around it... That could easily cause the weep if it got warm (the grease starts to separate and the thinner portions will wick).
Wipe off the excess and Hose it down with non-chlorinated brake clean first (then add just a touch of grease to the pushrod tip). If it's not the grease weeping, it'll show up again. If it was the grease weeping, the you've just taken care of the issue. Also, it might be time to flush the system as a regular maintenance item... -
Sounds like a royal pain in the **** that I'd rather pay someone to do, but thanks for the advice. It's in a kindof hard to get area. I had to lean over super far and contort myself just to get that photo of it. It would be tricky to work on that area with any sort of accuracy.
Car only has 25k miles on it, so I'm surprised to see anything abnormal on the clutch slave cylinder. That being said they are 25k HARD miles as I don't baby my car.Wipe off the excess and Hose it down with non-chlorinated brake clean first (then add just a touch of grease to the pushrod tip). If it's not the grease weeping, it'll show up again. If it was the grease weeping, the you've just taken care of the issue. Also, it might be time to flush the system as a regular maintenance item...
No, but I posted a video the other day that I thought you would like, not sure if you saw it:
https://www.youtube.com/watch?v=X3ndeXiZUeMAnymore...tests? lol
lol, I know that. Watch the video.Didn't see it...but just the text alone screams that's just plain WRONG! You should never use anything on your wheel studs...always keep em dry.
Never do that!
At the very most, a light coating of 3in1 or equivalent for rust prevention is all that's needed. Seen too many loose lugs, or over torqued lugs with stretched threads. Either way it's a bad idea. -
My grammar class...
Maybe they should take a grammar class lol -
mlistens03 wrote: »My grammar class...
Right after the copying class ? lolHT SYSTEM-
lsi 9's -
Picture of the LSis in my new setup. I redid everything, here is a picture of them from my listening position:
Seriously though, I am redoing my setup, and they are just here for the hour or so everything is in the state of moving. -
mlistens03 wrote: »...
I am empathetic.
I did a housecleaning upstairs one day. It was harrowing
022 by Mark Hardy, on Flickr -
Ha, that looks way harder than this. Here is what my rebuild is looking like so far.
I need a bigger room.
While I’m here, is it ok to use the high level inputs on my Velodyne CHT-10 and not use the outputs? I was going to hook it up like that for serious listening, but I don’t want the filter that is in the Velodyne to mess with the sound quality of the polks. -
That's funny stuff right there.
Instant slip n' slide
I want one!Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Looks like fun, but most likely one-and-done. Aircraft emergency slide I presume?
This one is for you John...
A 71 Dodge Demon for sale down the road from me.
https://www.facebook.com/marketplace/item/160918417953383
That's close to Lumberton. I wonder if Frank Booth ever owned that car?
He liked Mopars. -
From the airshow in Melbourne Fl this weekend
