Inexpesive speaker cables that would improve on Furez home mades
afterburnt
I need some better cables for my old Ushers, was looking at Canare are they any good?
I think @Joey_V had some Audioquest Type 4 for sale.
Pretty sure he's keeping those2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
afterburnt wrote: »I need some better cables for my old Ushers, was looking at Canare are they any good?
I use Canare 4S11 I like it. It is nothing special but it works. Signal Cable ultra is two runs of 4s8 in a techflex jacket.
You could hit up Joey he had some long runs of the Audioquest Type 4. well priced -
http://www.realitycables.com/
while $310 for an 8 ft pair you can hold onto these up into the mega buck systems.
these have been around for a long time, i still have mine.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
Autoplay music on their website makes sure I'll never order from them.http://www.realitycables.com/
Also check Signal Cables offerings. Heck of a value.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
I'd second that suggestion. Though used you can find them for around 150 bucks for an 8ft pair.
http://www.usaudiomart.com/details/649423903-gregg-straley-reality-cables-speaker-cables-7ft-red/HT SYSTEM-
lsi 9's -
don't let that stop you from improving your system.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Of course not. I already have some nice AQ Bedrock cables for my 2 channel setup.
Been looking at Signal cable or Douglas Connection for some custom terminated cables for my computer rig.don't let that stop you from improving your system.
mistake
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Making speaker cables is easy. Figure out what the raw materials are on some of these suggestions & build your own. Raw material cost is probably less than half.
What do you dislike about your current cables. -
@rpf65 I want to biwire and get rid of the jumpers also the bananas I have aint so good.
If you decide to go this route just buy the wire first, hook it up directly, and try them out on your system. This is the best they will sound.
If they are compatible then spend the money on good terminations. -
I was looking at BJC's with their fancy welds
https://www.thecableco.com/cables/speaker-cables/4pr-biwire-speaker-cable-pair.html
Pretty good and works well with a variety of equipment/speaker combinations.
May also want to look into The Cable Company's lending library. Try different brands for minimal cost. -
Audio Advisor has a pretty good deal on Audioquest type 4 and type 8 in their spring clearance catalog. If you don't want to biwire.Home Theater
