Inexpesive speaker cables that would improve on Furez home mades
I need some better cables for my old Ushers, was looking at Canare are they any good?
    Clipdat Posts: 13,100
    I think @Joey_V had some Audioquest Type 4 for sale.
  • Jaybeez
    Jaybeez Posts: 748
    Pretty sure he's keeping those
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
    pitdogg2 Posts: 27,376
    afterburnt wrote: »
    I use Canare 4S11 I like it. It is nothing special but it works. Signal Cable ultra is two runs of 4s8 in a techflex jacket.
    You could hit up Joey he had some long runs of the Audioquest Type 4. well priced
  • marvda1
    marvda1 Posts: 4,963
    http://www.realitycables.com/
    while $310 for an 8 ft pair you can hold onto these up into the mega buck systems.
    these have been around for a long time, i still have mine.
    Puritan PSM156
    Autoplay music on their website makes sure I'll never order from them.
    marvda1 wrote: »
  • steveinaz
    steveinaz Posts: 19,546
    Also check Signal Cables offerings. Heck of a value.
    edited March 2018
    marvda1 wrote: »
    I'd second that suggestion. Though used you can find them for around 150 bucks for an 8ft pair.
    http://www.usaudiomart.com/details/649423903-gregg-straley-reality-cables-speaker-cables-7ft-red/
  • marvda1
    Clipdat wrote: »
    marvda1 wrote: »
    don't let that stop you from improving your system.
    Puritan PSM156
    Of course not. I already have some nice AQ Bedrock cables for my 2 channel setup.
    Been looking at Signal cable or Douglas Connection for some custom terminated cables for my computer rig.
    marvda1 wrote: »
  • vmaxer
    vmaxer Posts: 5,121
    edited March 2018
    mistake
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • DaveHo
    DaveHo Posts: 3,583
    Making speaker cables is easy. Figure out what the raw materials are on some of these suggestions & build your own. Raw material cost is probably less than half.
  • rpf65
    rpf65 Posts: 2,127
    afterburnt wrote: »
    What do you dislike about your current cables.
  • afterburnt
    afterburnt Posts: 7,892
    @rpf65 I want to biwire and get rid of the jumpers also the bananas I have aint so good.
  • delkal
    delkal Posts: 764
    DaveHo wrote: »
    If you decide to go this route just buy the wire first, hook it up directly, and try them out on your system. This is the best they will sound.
    If they are compatible then spend the money on good terminations.
  • afterburnt
    I was looking at BJC's with their fancy welds
  • rpf65
    rpf65 Posts: 2,127
    https://www.thecableco.com/cables/speaker-cables/4pr-biwire-speaker-cable-pair.html
    Pretty good and works well with a variety of equipment/speaker combinations.
    May also want to look into The Cable Company's lending library. Try different brands for minimal cost.
    gudnoyez Posts: 8,174
    Audio Advisor has a pretty good deal on Audioquest type 4 and type 8 in their spring clearance catalog. If you don't want to biwire.
