Vintage Monitor and SDA Speaker Deals
1122123125127128244
  • Jaybeez
    Jaybeez Posts: 737
    la2vegas wrote: »
    Jaybeez wrote: »
    They're local, but I have a feeling that they'll be a lot more before the bidding ends.
    I jumped in as always wanted a set of SDAs. Currently the high bid. Hope I'm not bidding against a Polkie brother!
  • Jaybeez
    Jaybeez Posts: 737
    edited March 2018
    Far below that.
    I won't bid against a Polkie.
    They're all yours.
  • verb
    verb Posts: 10,176
    Jaybeez wrote: »
    Far below that.
    I won't bit against a Polkie.
    They're all yours.
    He has enough speakers! Time to share @la2vegas ! :smiley:
  • Jaybeez
    Jaybeez Posts: 737
    verb wrote: »
    Jaybeez wrote: »
    Far below that.
    They're all yours.
    Evidently not.
  • 250GTLusso
    250GTLusso Posts: 163
    @la2vegas , is that the guy in Penn Valley, CA?
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • FestYboy
    FestYboy Posts: 3,861
    la2vegas wrote: »
    Thanks, we'll see how things play out.
    In the meantime the guy in the Valley selling the CRS's reached out to me. He informed me that he would take 200 for them.
    What to do. :#
    You go and get them.
    Viking64 Posts: 6,646
    la2vegas wrote: »
    No, he's in North Hollywood.
    North Hollywood? You could go pick up the speakers and then head to The Troubadour to see The Mentors play. B)
  • 250GTLusso
    @la2vegas , ah, the rattle can black ones.
    HT
    2 Channel (Office)
    2 Channel (Garage)
    la2vegas wrote: »
    That huge crack in the veneer was too much for me to overcome. :(
    The almost perfectly describes a date I had back in the 80s.
  • FestYboy
    That's called shrinkage...
    Go ahead, run with it.
  • deronb1
    deronb1 Posts: 5,021
    Viking64 wrote: »
    la2vegas wrote: »
    Crack was big in the 80s
    edited March 2018
    FestYboy wrote: »
    Are you referring to that speaker or my date back in the 80s? :p
  • FestYboy
    Dare I say, both? :#
    I suspect the vinyl veneer was made with calendared material instead of cast. Cast wouldn't shrink like that, maybe 1-2% at most, especially given the environment it was intended for. Calendared, on the other hand, can reduce well beyond 25% given enough time and heat.
    audioluvr Posts: 5,420
    Fear not the crack, for it shall be filled...
  • FestYboy
    Not when I can get them for half that.
    Tony M Posts: 11,009
    Yea, 150.00.
    But if the rest is all right, maybe 200 then. I'd have to see more. But they are the desired one tweeter model, so...
    That strip on the front can be easily replaced with a real wooden one like some models have.
  • dkfreebird
    dkfreebird Posts: 1,180
    3.1tl's in Dallas/Ft.Worth.https://offerup.com/item/detail/445104674/?ref=Search
    This is the 3rd pair up for sale near here in the last week.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre
  • Legender
    Legender Posts: 478
    He's now posted those on CL... do those look original?
    https://dallas.craigslist.org/ftw/ele/d/polk-audio-model-srs-31tl/6536021142.html
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • dkfreebird
    edited March 2018
    They appear to be. There is another set for 1000 and a set for 500 in Granbury. The ones I posted are 5 minutes from me.
    Oppo 103
    Pangea PC
  • dkfreebird
    I inquired about the McCormack I spotted on the floor but it was a no go. :#
    Oppo 103
    Pangea PC
  • dkfreebird
    Oppo 103
    Pangea PC
  • Legender
    Legender Posts: 478
    My tweeters aren't that color in mine. Mine are all black. But my top and bottom plates are veneer and not black like his. And he's only got a picture of one.
  • Legender
    Legender Posts: 478
    dkfreebird wrote: »
    I saw that McCormack on the floor also. Too bad.
  • dkfreebird
    Legender wrote: »
    I have the walnut veneer on mine.
    Oppo 103
    Pangea PC
  • dkfreebird
    Have you pulled the tweeters to see if they are rdo’s?
    Oppo 103
    Pangea PC
    pitdogg2 Posts: 24,474
    dkfreebird wrote: »
    No need to pull just look for the foam ring around the dome. No foam RDO. foam SL3000.
    More than likely the RDO may not be marked as such. IIRC early versions had no markings.
    Some SL3000 had a blackish dome.
  • dkfreebird
    dkfreebird wrote: »
    Yep,forgot about that. :/
    Oppo 103
    Pangea PC
    They do have the rare Walnut caps though.
  • Rrusse11
    Rrusse11 Posts: 116
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
