PSW111 Repair!!!!
Greetings,
I have a PSW111 subwoofer which is damaged. A few months ago I went to a Technician here in Venezuela to try to fix a buzzing noise it has. As it turns out he gave me back the Subwoofer with missing components on the internal PCBs and I want to send it to a Certified Repair Center in USA to try to save it. Any suggestions will be appreciated.
Best Regards
  • rooftop59
    rooftop59 Posts: 8,120
    @KennethSwauger should be able to help.
    How old is the sub, did you buy it from an authorized dealer and do you have the receipt?
    Game Room 5.1.4:
    Bedroom 2.1
  • FestYboy
    FestYboy Posts: 3,861
    Might not matter since it was damaged further by an unauthorized "repair" facility.
  • Hi guys, I bought it on Crutchfield, yes I have the receipt and It is out of warranty, that's why I tried first here to save it before sending it back to USA, which is more expensive.
  • stevep
    stevep Posts: 363
    I don't know what Polk charges directly but you can buy a new Amp board for about $100 to replace yours. The Speaker Exchange in Tampa, FL would likely ship to Latin America.
