Magnifi Max SR sound delay
henninge
Anyone else having issues where there is a significant delay in the sound coming through the sound bar?
An example is, if I rewind Netflix on my tv, Netflix video will play, but the audio doesn't come through for about 5 secs.
Sound is coming to the soundbar from the tv via optical. And I have the Max's hdmt out, going into tvs HDMI 1 with arc
Thoughts or suggestions?
Best Answers
It's a delay of between 5-8 seconds when switching sources.
Also noticing now that occasionally sound stops when switching sources. I need to reboot the source, the bar, or fiddle with things to get the sound back on -
KennethSwauger wrote: »I would suggest calling Polk at 1-800-377-7655 for some advice.
I did - got a replacement sound bar. Still minor issues. But, the minor issues are still unacceptable imo
Answers
I would suggest trying different outputs from your sources, trying different inputs, see if that works. Other than that though, I have no clue, sorry.
Micah -
In have definitely tried different inouts and outputs. There definitely seems to be a 4-5 second delay in the sound bar play a sound when a video started playing
I have the same issue with my new MagniFi Mini using HDMI ARC input! Hey Polk, please help!
