Hey everyone
  • rooftop59
    rooftop59 Posts: 7,991
    edited September 2017
    jmeitz13 wrote: »
    that would be awesome!
    Oops, now I see that you got em. Good for you! That center is a beast. Do you have an amp to drive those speakers???
    Game Room 5.1.4:
    Bedroom 2.1
  • [Deleted User]
    Just a Yamaha 3020
  • rooftop59
    jmeitz13 wrote: »
    Just a Yamaha 3020
    Thats a great, powerful avr (for an avr), but those 707s would really benefit from external power. I had the 703s in a master bedroom, and they sounded good with a decent 125 wpc audiosource amp, but when I replaced it with a rotel rb-993 200 wpc amp, they really started singing! Tighter, better controlled and more authoritative bass, wider soundstage, everything just sounded better. Now if this is soley for HT, I think that you will be fine with the yamaha, but for music especially an amp would much a discernable difference...
    Game Room 5.1.4:
    Bedroom 2.1
  • [Deleted User]
    Strictly HT. Might be overkill or a mistake. As long as it's better than the current setup.
  • rpf65
    rpf65 Posts: 2,127
    No such thing as overkill on this forum. The mistake is asking for advice and not believing how much money you'll spend.
    Nice room and good buy on those speakers.
  • [Deleted User]
    rooftop59 wrote: »
    jmeitz13 wrote: »
    Just a Yamaha 3020
    I might bi amp the 3020 to the fronts and use my Dayton amp for the front and rear presence speakers
  • rooftop59
    What dayton amp?
    FYI bi-amping from an avr doesn't really do anything. As you increase the number of speakers you dramatically decrease the wpc rating (from a sound and vision review):
    Output at clipping (1 kHz into 8/4 ohms)
    1 channel driven: 194/275 W (22.9/24.4 dBW)
    5 channels driven (8 ohms): 69 W (18.4 dBW)
    7 channels driven (8 ohms): 63 W (18.0 dBW)
    Read more at https://www.soundandvision.com/content/yamaha-rx-a3020-av-receiver-page-4#gF58sWgBq1mFvmhk.99
    So, when you are driving 7 channels it helps very little to bi-amp. Get a solid two-channel amp like a parasound HCA-1200 or 1500 or a rotel rb-991 or equivalent and those 707s will sing for you!
    Game Room 5.1.4:
    Bedroom 2.1
    mhardy6647 Posts: 33,098
    jmeitz13 wrote: »
    Just a Yamaha 3020
    Not a CR-3020, I presume? :neutral:
    (not mine, sadly...)
  • [Deleted User]
    Now I have an issue. Since I am doing towers I have no idea where the subs are going to go. As my wall to the center piece is 26" and my subs are 24" wide. Originally was going to put the bookshelves on the sub. What to do.
  • rpf65
    rpf65 Posts: 2,127
    Move the giraffe and saber tooth out of the way. I think they'll fit.
  • [Deleted User]
    Not deep enough. Thought of removing it, but wife likes the look.
  • [Deleted User]
    Looks like I will cut holes in the wall as mount them on the front stand. I have 2ft or so behind the wall :). Doing Stereo Integrity 18s now as the UM18 got pushed further back.
  • jeremie
    jeremie Posts: 246
    Jstas wrote: »
    A bunch of old names were "banned" in the forum upgrade. I forget why, seems like something got botched to me but whatever. They weren't really banned, though. It was just how inactive accounts got handled.
    If you want your old account back, send a PM to @KennethSwauger and he can get you straightened out.
    Just got my id back. Thank you @KennethSwauger
    Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
    LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
  • jeremie
    jeremie Posts: 246
    Hate being in Mexico on vacation
  • jeremie
    jeremie Posts: 246
    Hate being in Mexico on vacation.
  • jeremie
    jeremie Posts: 246
  • jeremie
    jeremie Posts: 246
    I am simply amazed how well these 707 are, just timing off airplay on my 3020. Can’t wait to get an amp and calibrated. My 7 piece openbox set from adorama was all brand new in box, not a single scratch.
  • jeremie
    jeremie Posts: 246
    Progress is being made. Installed subs today and they make your throat rattle. Now to hook up the speakers, paint some baseboard and install acoustic panels I built. fzchm1zsfhpi.jpeg
  • cfrizz
    cfrizz Posts: 13,415
    What an awesome setup! Don't forget to change your signature.
    Toolfan66 Posts: 16,958
    Fantastic!!! Looks like my kinda fun!!!
  • jeremie
    jeremie Posts: 246
    rooftop59 wrote: »
    What dayton amp?
    Thoughts on a low hr used parasound 5125 for 900 vs a emotiva xpa 5 3rd gen for 1300
  • jeremie
    jeremie Posts: 246
    So here are some near complete pics. I had to build a platform for my rear speakers and my new motorized sofas are 42” tall in back and my stands are 24”. 7a3hjrm5c547.jpeg
  • warren
    warren Posts: 756
    It’s a work of art!!! Listen to the voices in print, the good ones anyway..
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • voltz
    voltz Posts: 5,384
    What he said :)
    pitdogg2 Posts: 24,633
  • NotaSuv
    NotaSuv Posts: 3,817
    Very nice...looks like a lot of work and planning went into your setup
  • scubalab
    scubalab Posts: 3,101
    That is one awesome looking HT Jeremie! Nice work.
  • jeremie
    jeremie Posts: 246
    Waiting for the emotiva to arrive today and get that mounted and fire it up.
