Tandberg TL 5010 Speakers
Got a pair of these local and really dig the cabinet and design. Crossover PCB is superb for the year these were manufactured (around 1971 - 1974). This is going to be a winter project with new capacitors, new seals for the drivers, new mounting hardware, possibly new binding posts and a lite sand and shine for the cabinets.
Ongoing thread, and here are a few pictures:
  • Not mine, but here is a pic of the speakers with grill removed:
  • Nice. Looks like a fun project
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
  • mhardy6647mhardy6647 Posts: 20,526
    Not something one sees every day -- probably not even in Norway at this late date ;)
    In case the OP's not aware of it, there is a website with a smattering of Tandberg literature & catalogs (not all in English, not surprisingly).
    http://www.kallhovde.com/Njord Noatun's Vintage Audio Resources.html
    the specific link for Tandberg stuff is:
    http://sportsbil.com/tandberg/
    found 'em in 71-72 (Norwegian) catalog:
    http://sportsbil.com/tandberg/1971-72-cat.pdf
  • Dang. Stuff like that is not available around here.
    How do they sound now? Really nice pickup!
    Studio 2 equipment;
    Yamaha a-s2100 Amp, CD-2100 CD player, T-S500 tuner
    Loudspeakers: Harbeth p3esr, Polk RT7
    Cables: Aural Harmony Sonnet Interconnect II, WireWorld Equinox 7 speaker,
    Black Cat silverstar 75 ohm digital, Signal Digital Power Cord, PS Audio Perfect Wave AC-3,
    Pangea SE14, Voltz supplied interconnects
    Optional: Arcam DV88 DVD/CD (HDCD) player, Polk SDS-400 speakers
    edited September 2017
    I have no life ;)
    De nada.
  • The tanbergs I've seen are TEAK cabs, beautiful wood. Never had my ears on them but would like too. Nice find!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Scandinavian loudspeakers, by and large, very niceto listen to, IME/IMO.
    -- am I stereotyping? :blush:
    They are beautiful cabinets.
  • Thanks for the information mhardy!
  • Viking64Viking64 Posts: 3,724
    A friend of mine bought some Jamo speakers back in 1984. They sounded good, but my baseline at the time was, shall we say, "relatively low". :p They were the type that had what looked like louvers over the tweeter.
  • Word to the wise! If doing any sanding on teak wood wear a filter mask as teak dust can make you very sick. Learned this in the boat building busines as a young teen building yachts. There is an OIL in them that is somewhat poisonous.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Great information! Thanks!
  • corticocortico Posts: 470
    Tandberg made excellent receivers as well. The drivers on this speakers look phenomenal, the crossovers look really clean too. I would test the components before replacing anything... you may find that their still under spec.
    Parasound HC/A 2200II < PL/D 2000 < DA/C 1100HD < CD/C1500
    Cambridge Audio phono pre
    Pioneer PL530 turntable, Shure M97XE cartridge
    Belden ICs
    MIT T2 speaker cables
    Polk Audio LS70
    "If it measures good and sounds bad, it is bad"
  • Hmmm,
    Frequency Response: 35Hz to 22kHz
    Power Handling: 45W (max continuous)
    Crossover Frequency: 700, 2000Hz
    Impedance: 4Ω-8Ω
    Xover 700hz,2000hz
    I'd replace the resistors at least with some Mills...
    Better inductors too if the old are not hand wound...
    The Xover diagram is at hifiengine.
    Studio 2 equipment;
    FWIW the only thing I'd be looking (hard) at are those capacitors. I cannot tell what they are based on the photo. If (????) they're NP electrolytics, that's what I'd change.
    They may well not be -- but I ain't sure.
    PS are all y'all cool with the protective used of the light bulb? ;)
    I mean, it's a valid thing that's been done in many loudspeaker designs -- but it seems a little... inelegant, doesn't it?
  • mhardy6647 wrote: »
    Those tin cans should all be checked. The lamps were used quite often by many manufacturers. They do exactly what they're supposed to. If you have a ported system, being driven hard, you will frequently see them glow.
    Not sure how they affect the audio signal. They could be replaced with a resistor, but you give up protection. In my opinion, much less intrusive than Polyswitches. I usually replace them with new, equivalent "Festoon" lamps.
    Den:
    Oh, there's no doubt that using a light bulb in series (like the so-called "dim bulb tester") does what it's supposed to do. I'm just not sure how audibly unobtrusively it does it.
  • pitdogg2pitdogg2 Posts: 12,282
    It could add a certain "brightness" to the treble?
    hahaahahaah
    I know WATT you mean. Or were you just trying to make LIGHT of the situation? EDISON the phone. I'll ask his opinion. Although maybe he will just LAMPoon it as you did. SOCKET to me, Ed.
    And we get all this banter for free!
    Lordy, I love this place!
  • la2vegasla2vegas Posts: 3,194
    It's free for now. It might be $400 a year in the not too distant future.
    2.3TL, 3.1TL, SRS 2, SDA 2B, SDA II,SDA 1C, 7B, 7C, 7 series 2, 10B, 5JR+, 5JR, 5A, 4.5, 4, RTA 11TL, RTA 8TL, RTA 8T, LSI9 Ebony, LSI7 EBONY, LSI7 CHERRY, LSIC, RTI A7, RTI A3, CSI A4, CSI A6, F/XI A4, RTI4. That's all for now.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,822
    In days of yore Polk made an on-wall type speaker that used the same tweeter protection device. Sometimes owners would telephone us asking about the light they could see blinking at them from the speaker.
    Anyone remember a British speaker that used a small light to help with speaker positioning?
    "They thought we were too loud, but shoot, I had four army blankets folded over my amp, and the volume level was on 2. I'm used to playin' on 10!" S.R.V.
    I'm thinking the top modules on the KEF 105, but Google's not backin' me up on that :/
    PS If any of youse guyses happens to have a surplus pair of KEF 105s collectin' dust... shoot me a PM ;)
    Heh -- I think I was very close :)
    One-oh-five... point two.
    source: http://www.kef.com/uploads/files/en/museum_pdf/70s/Reference_Series_Model_105_2_r.pdf
    You are correct, the listener turned the upper section until they could see the small light in each speaker. The light had a very narrow dispersion so it would "blink" on. Great sounding speakers! There was a pair on CL a few months ago near DC that looked in great shape.
    Yeah, I always liked 'em.
Howdy, Stranger!
