Club Polk Perception
15681011
  • BlueFox
    BlueFox Posts: 15,251
    I can live with my 1200 watts. Sounds good to me.
  • megasat16
    megasat16 Posts: 3,521
    edited August 2017
    Like Mr. Bob Carver; VTL, Manley, and probably a small handful others have made tubes power amps that are over 500W output.
    Unlike Bob Carver; these amps usually weight a good fraction of a TON and requires 2-3 guys to lift and place them.
    What I am saying is that VTL, Manley amps above 500W weights about 200-300lbs per channel while Bob amps weight about 100lb combined (55lb for Power Amp Chassis and 45lbs for the Power Supply Chassis) per channel. Bob claims his amp can do 700W RMS at 8 ohms and 900W music and speech.
    When it comes to tube amps, the quality (primary inductance really) of output iron determines the lower end frequency response. In Universal terms, it usually requires heavier and chunkier output transformers for better low frequency response even in push pull circuits. Bob claims his amps can do 2Hz-85KHz with -3dB bandwidth. It's rather interesting because the output iron once again needs lots of inductance (Bigger and Heavier iron) even for the 20Hz response for a mere 35W PushPull amps if you are referencing to the United Transformer Corp Linear Standard transformers.
    I don't know how Bob end up with his transformer design but I don't see any real changes in Transformer designs or efficiency in the last 60 years. They all use the same formulae, and the same kind of core (EI, C or Double C or Toroid) structure and same kind of lamination types and sizes. There are now better core materials for better frequency response and tonal quality but none of that makes any considerable increase in the low end response or power handling efficiency. Enameled wires and sizes for winding transformers are the same as well.
    Referencing to UTC Linear Standard design, 20W P-P iron weights about 7lbs and 35W P-P iron weights about 15lbs. The power transformer for continuous duty to supply a 150W amp could weights in at 30lbs or more. Heck, it will even weight about 20-30lbs filament transformer to light up the 20 KT88 bottles because each KT-88 filament consumes 1.6amp at 6.3V. It takes about 10W for each KT88 bottle to light up so it takes about 200W alone to light up the 20 x KT88/6550 tubes. Unless bob decides to wire the 6550 tubes in series and plug them straight into a wall socket, a 200W (6.3V x 40amp) transformer probably weights about 20-30lbs on it's own. Well, there needs to have a plate transformer to supply B+ and bias and various transformers to power the input and driver tubes.
    Unless Bob decides to use switching type transformers, I don't see how a 45lb power supply chassis to supply 700W RMS out of 20 x 6550/KT88.
    I know all these questions are better addressed with Bob but I also know I will just get some smart answers that is beyond a comprehension for the like of me. I am still a fan and had probably about tens of Bob's amps at one time. And I still owe two pairs of Carver ALS so just saying out loud for what's in my mind with silver seven 700.
    My 8Watts 845/211 SET amp in three chassis weights nearly 150lbs. It sucks about 250W from the wall output to pump 2 x 8W RMS to the 100dB+ speakers. It's not very pleasing to the wife when the electric bill is coming due every month. I don't want to think about the electricity draw from a pair of Silver 7 700s.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    treitz3 Posts: 19,952
    Bob uses math and ingenuity to design his transformers and winds them himself.
    mhardy6647 Posts: 34,930
    DSkip wrote: »
    John, when would one need 700 watts of tube power?
    I'm not being argumentative there - I really would like to know where you think this application is needed.
    That isn't to say its a bad design or Bob doesn't know what he is doing (obviously he does), but when I see that kind of number I think its more to do with sticker-shock as opposed to ingenuity in design.
    Bob Carver is a firm believer in the concept that clean reproduction of some transient sounds requires huge reserves of instantaneous power. I agree. The more dynamics, particularly bass dynamics, you are trying to reproduce, the more power required.
    The quote below is from page 5 of the 1982 Carver catalog:
    "Once, Bob Carver visited a famous sound researcher who was attempting to recreate the "snip" of an ordinary pair of scissors. Between the microphone and the speakers he had installed TWENTY-FOUR 200-watt amplifiers. Yet when viewed on an oscilloscope it was apparent that the final tip of that instantaneous transient was being distorted. Believe it or not, he needed more power!"
    The "famous sound researcher" was Dick Burwen. You can read about his home audio system, which uses 17 200-watt solid state QSC SRA 1222 studio amplifiers, here:
    http://www.burwenaudio.com/Sound_System.html
    and here:
    http://www.burwenaudio.com/images/Audio_April_1995.pdf
    Yup, you beat me to it. Mr. Burwen, last I knew, is still at it, too.
    Admirable man.
    (He's on LinkedIn, too! -- apropos of nothing)
    Still rockin' 3-ish wpc here. Fortunately, I listen to very few scissors recordings.
    But Patty Larkin's in the room with me this morning as I sip my third (ahem) coffee of the day.
    Don't tell Mrs. H ;)
    pitdogg2 Posts: 26,958
    treitz3 wrote: »
    That and iirc made of different steel that others. I've seen pictures of him in heavy duty gloves winding them up one at a time.
  • megasat16
    edited August 2017
    I am pretty sure everyone winding transformers needs to use a precise number of core lams and wire size and turns ratio to end up with the desire transformer. The formulae for transformer winder has been around before my time and will probably the same for the next few generations. If Bob were to come up with a new transformer winding scheme, a noble prize wouldn't be that far fetched at all.
    I became interested in the transformers since I started building SET amps and they requires 2x - 3x the size of the push-pull type transformers for a good frequency response. The guys who can wind a good Single Ended output transformers are far few and less than that of the counterparts (i.e. Push-Pull output transformers winders).
    Anyway, I think Bob should publish the spec on the power draw for these Silver 7 700s and the -1dB bandwidth.
    3dB down at 20Hz in 700W means the output power is actually only 350W at 20Hz but could be 700W at 40Hz. But if it's 1dB down at 20Hz at 700W RMS, the silver seven 700s could well be the end game amp.
  • Unknown
    edited August 2017
  • The audio rags might be more interested in "Quantity" (of advertisers) over "Quality" (of gear).
    Not true in all cases, to be sure, but it's there.
  • megasat16
    Bob and audio rags has a little history. Carver fans knew it well.
  • Unknown
    edited August 2017
  • megasat16
    edited August 2017
    Yep2 wrote: »
    megasat16 wrote: »
    Unreal specs.
    Distortion & driver control could be a contributing factor?
    Im just guessing here?
    Nothing like that at all. Stereophile lost a bet with Bob. Bob knows his stuff and the guy is a Genius! And it's worth noting carver gears are decent for the price it commends at one time. Now, I think he is just getting the best of his fame.
    I saw how Bob's winding his own transformers and all. He had it all figured out from unwinding the old trafo from the 40s and 50s and come up with his own design.
  • BlueFox
    I remember seeing ads for his amps in Sterophile or Absolute Sound a few years back. That was before he went with Emotiva.
    Bob and Stu did come up with something new in his transformers. I just do not recall what it was.
  • lightman1
    lightman1 Posts: 10,796
    Shut up, Ken....
    Fargin canuck....
    B)
    edited August 2017
    Humor is good but don't temp him. He'll even proceed it by a , "Hey y'all, watch this!".
    We did an interview with Bob years ago where he had touched on all of the information you would ever want to know about why he winded his own transformers, what the mathmatical difference was with his winding and how he winded them. It's out there in internet land somewhere if you are really that interested.
    Bob didn't do jack for Emotiva BF. Emotiva basically wanted Sunfire's rights and Bob got paid royally for them, they split quickly and Bob started his 5th audio company, Bob Carver Corp. Bob Carver, LLC is what Emotiva owns IIRC.
    edited August 2017
    treitz3 wrote: »
    Humor is good.
    Believe they also wanted him to build some tube stuff for them also...yes he showed them the bird and split
    EndersShadow Posts: 17,687
    edited August 2017
    @treitz3
    Isn't this when you guys asked him about his thoughts on Emotiva :wink:
    RIP TNRABBIT! I miss seeing you post and chatting about going active every once in a while
    Here is also a pic of bob doing his thang! I'm a big fan
    @treitz3
    Agree gone too soon
    RIP
    edited August 2017
    That was about the same time frame, yes. That photo was taken at Carverfest and who you see there is Robert R. and Bob Carver with a PS unit for one of DaveS's Silver 7's.
    Agreed with Gary. The photo you provided with the knife has actually been made into a "cartoon" T-shirt of Bob, the knife and the amp in Gary's (TNRabbit) honor. For those of you who don't know, he was the one who had the avatar of the bunny with the pancake on his head and was taken from this world way to soon in an unexpected motorcycle accident. He was a dedicated Bob Carver fan and well regarded by any and all who knew him. A true friend to all, enemy to none.
    Back to Bob, he told me at the time that he was done with board rooms and corporate shenanigan's. He wanted to go back to doing what he truly enjoyed. Going back to his roots building tube amps. That's where he stated his true passion lay.
    edited August 2017
    Yep2 wrote: »
    treitz3 wrote: »
    Humor is good.
    yep he showed them the bird and split
    Please dont mention my name Ivan!
    Bwaha! :D
    My bad Paul ...
    Fixed it B)
  • kharp1
    kharp1 Posts: 3,453
    treitz3 wrote: »
    And "here, hold my beer."
    kharp1 wrote: »
    treitz3 wrote: »
    And that is when all the fun begins....
    Stand back
  • Unknown
    edited August 2017
    Yep2 wrote: »
    kharp1 wrote: »
    treitz3 wrote: »
    You forgot... "WATCH THIS" first ! :D
    Nope it was referenced in the Tom quote in kerrys post
    txcoastal1 Posts: 13,500
    Tom, you got any pics of you sitting in Bob's lap telling him what you want for Xmas ;)
