SDA-CRS/CRS+ Something Different
You'd want to keep that monster away from the tweeter inductor.
Was afraid of that. Would have been nice to have all be right there accessable by 4 screws.Don't take experimental gene therapies from known eugenicists.
Remote mount it with faston leads to the board like Polk used.
Like Jesse says, you want the SuperQ as far away as possible. Difficult in the CRS cabinet though, since you don't want it near the woofer magnets either.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I'm changing out the factory inductor leads also to 16g OFC with a little extra length.
I noticed there is an "R" and a "P" on the board. Does it matter which way they are connected to factory inductor inputs?Don't take experimental gene therapies from known eugenicists. -
No
This is the 2nd set of factory CRS+ crossovers I've found and removed these bypass caps. Why the 1000 at 50%?
Probably all they had on hand at the time. It's how things worked at Polk back then.
Cap tolerance must have come a long way since then.Don't take experimental gene therapies from known eugenicists.
