SDA-CRS/CRS+ Something Different
    You'd want to keep that monster away from the tweeter inductor.
    Was afraid of that. Would have been nice to have all be right there accessable by 4 screws.
    Remote mount it with faston leads to the board like Polk used.
  • Like Jesse says, you want the SuperQ as far away as possible. Difficult in the CRS cabinet though, since you don't want it near the woofer magnets either.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    I'm changing out the factory inductor leads also to 16g OFC with a little extra length.
    I noticed there is an "R" and a "P" on the board. Does it matter which way they are connected to factory inductor inputs?
    No
    edited January 2018
    This is the 2nd set of factory CRS+ crossovers I've found and removed these bypass caps. Why the 1000 at 50%?
  • Probably all they had on hand at the time. It's how things worked at Polk back then.
  • Cap tolerance must have come a long way since then.
