AudioQuest Cinnamon HDMI Cables vs. The Cheap Stuff - Review
DarqueKnight
DarqueKnight Posts: 6,765
Introduction
It's been a while since my last HDMI cable comparison, June 2009 to be exact. The result of that comparison was there was no perceived or measured audio or video performance difference between the Monster Cable ($130), Rocketfish ($85), Acoustic Research ($20), and Monoprice ($8) HDMI cables tested in my home theater system. That evaluation was done with a Hitachi 55" 720p plasma HDTV. A link to that review is at the end of this report.
This evaluation compared the performance of SecureOMax HDMI 2.0 cables ($9.99-3 feet, $12.99-6 feet) to AudioQuest Cinnamon HDMI 2.0 cables ($68.75-1 meter, $98.75-2 meters).
The Cinnamon cables provided a slight video and audio performance improvement with my Tivo DVR and a modest video and audio performance improvement with my Pioneer BDP-09FD blu-ray player. I am a longtime user of AudioQuest cables. My two channel system is wired with AudioQuest Sky Gen2 XLR interconnects and Everest speaker cables. However, in the case of these AudioQuest HDMI cables, the much higher prices did not justify the small performance improvements and they were returned.
This evaluation required a 3 foot/1 meter cable between the Tivo DVR and preamp/processor, and 6 foot/2 meter cables between the plasma TV and preamp/processor and blu-ray player and preamp/processor.
Cable Construction
The SecureOMax HDMI cables are made of oxygen-free bare copper and are triple-shielded for maximum performance and ultra low signal to noise ratio. Connectors are 24K gold-plated and soldering points are covered by a thick aluminium shell to achieve better shielding and lower signal to noise ratio.
AudioQuest Cinnamon HDMI cables are made of oxygen-free long grain copper solid core conductors with 1.25% silver plating, Solid High-Density Polyethylene Insulation, and precise winding geometry for noise cancellation.
Figure 1. AudioQuest Cinnamon on the left, SecureOMax on the right.
Both brands are heavily constructed. I preferred the ergonomics of the SecureOMax's larger connectors. They were much easier to handle when reaching behind my home theater system equipment cabinet to plug and unplug.
Audio And Video Comparisons
Pictures were taken with a Fuji Finepix S9000 digital camera with the lens 3 feet-5 inches from the TV screen. Identical exposure apertures and shutter times were used for each cable comparison of the same scene.
The Tivo DVR captures in figures 2 and 3 are a paused image of a sportscaster shot at f/6.4, 1/8 second at ISO 200. The AQ Cinnamon image has slightly better detail, although this was not perceptible to my eyes when looking at the TV from 12 feet away. If you download the higher resolution pictures attached at the end of this post and flip between them while viewing on a high definition display, you should be able see the differences between them.
The sportscaster's voice was noticeably more clear and resonant and bass sounds from other TV programs had a little more weight and growl.
Figure 2. Tivo DVR scene capture with SecureOMax HDMI cables.
Figure 3. Tivo DVR scene capture with AQ Cinnamon HDMI cables.
The Pioneer BDP-09FD blu-ray player captures in figures 4 and 5 are a paused image of the male protagonist's eye from "The Girl With The Dragon Tattoo" blu-ray. Both images were shot at f/3.6, 1/13 second at ISO 200. The AQ Cinnamon image has slightly better detail, which was not perceptible to my eyes when looking at the TV 12 feet away. The Cinnamon image also had moderately better contrast, which was perceptible to my eyes. If you download the higher resolution pictures attached at the end of this post and flip between them while viewing on a high definition display, you should be able see the differences between them. When I connected the Cinnamon cable, it was immediately obvious that the picture looked different and "better", which I perceived as better color rendition.
Dialog, and the "clink" of knife blades prior to the female protagonist cutting the bonds of the male protagonist, the "clop-clop-clop" of her footsteps as she runs down concrete steps chasing a serial rapist and serial murderer, and the rumble of motorcycle and truck engines as she chases after him were rendered with moderately more clarity, detail, rumble, growl, and tactile sensation coming through the armrest and seat.
Figure 4. Blu-ray scene capture with SecureOMax HDMI cables.
Figure 5. Blu-ray scene capture with AudioQuest Cinnamon HDMI cables.
The BDP-09FD blu-ray player has a very good analog output stage. Listening to CDs via the analog outputs provides a wider and deeper sound stage, more image weight, much better bass presentation, and more overall clarity and detail than via its HDMI output. A 2 meter Monster Cable Z100i interconnect was used between the BDP-09FD's analog outputs and the Yamaha CX-A5100 preamp/processor. I did trials comparing each HDMI cable to the sound from the analog output. The AQ Cinnamon HDMI cable came much, much closer to the stereophonic performance of the analog cables. However, I don't play music in the home theater system using the blu-ray player and CDs, I use a Bryston BDP-1 digital player and the CX-A5100's DAC to play Redbook, hi-rez, and DSD files, all of which sound better.
Summary
I would have kept the Cinnamons if they were half the price. I am not as inclined toward excessive diminishing returns in my video entertainment. In the future, when I am more dedicated to video than I am now, or, if I run across a good deal on some higher-end HDMI cables, I might indulge.
Associated Equipment
Pioneer Elite Kuro PRO-151FD 60" Plasma TV
Pioneer Elite BDP-09FD Blu-ray Player
Tivo HD XL Digital Video Recorder
Bryston BDP-1 digital player with external Samsung EVO 840 500 GB solid state drive.
Adcom GFA-5500 power amp (200 wpc 8 ohms)/Front Speakers
Adcom GFA-5500 power amp (200 wpc 8 ohms)/Center Channel Speaker
Adcom GFA-5500 power amp (200 wpc 8 ohms)/Surround Speakers
Polk Audio LSiM 706C Center Channel Speaker
Polk Audio LSiM 705 Front Speakers
Polk Audio LSiM 702 F/X Surround Speakers
SVS PB12 Ultra/2 Subwoofer
PS Audio P5 AC Regenerator
PS Audio P10 AC Regenerator
PS Audio AC-5 power cord for AC Regenerators
PS Audio Statement SC power cords for all electronics
Revelation Audio Labs Prophecy Cryo-Silver Digital Coaxial Cable
SecureOMax HDMI Cables
Monster Cable Z3 Reference Speaker Cables, Front, Right, Center
DSR Silverline (Out Of Wall) And Monster UL/CL3 (In-Wall) Speaker Cables, Surround
Blue Jeans LC-1 In-Wall Subwoofer Cable
Monster Cable Z200i Interconnects (Preamp to Power Amps)
Two PS Audio Soloist SE In-Wall Passive Power Conditioners
Two Dedicated 20 amp AC Circuits
Salamander Synergy Quad 30 Audio Cabinet
Dell Venue Pro 11 7140 Tablet Computer For System Control
Reference
2009 HDMI Cable Trials:
http://forum.polkaudio.com/discussion/84644/tweaking-home-theater-pt-3-the-pioneer-elite-bdp-09fd-blu-ray-player
Post edited by DarqueKnight on
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Great review, Ray, as always! Thanks for doing and documenting it. I've used many, many HDMI cables at all price ranges, but I've done very little studying and comparison of the difference, mainly because I perceived any differences to be very subtle, or virtually non-existent. Not saying it's not there, but for the great majority of people with consumer-grade equipment, HDMI cables probably don't matter.
  • Unknown
    edited June 2017
    tonyb Posts: 33,072
    I might agree with most comments on this. Personally I've seen little difference in HDMI cables....visually. The differences I've come across has all been reliability, handshake issues....which even within the same iteration of HDMI, can vary.
    That was before I got a 4k set. The visual differences now became a tad more apparent.....AND I have an AQ Cinnamon on it now. I guess what it boils down to is, the better the display, the more apparent these subtle differences become. Just like on the audio side, the better and more revealing your system is, the more apparent the subtle differences of a cable can be heard. Just my .02 on the subject.
  • Thorton
    Thorton Posts: 1,324
    Nice write-up Ray. +1 to what Tony says. The problem I had with less expensive cables (and I tried a few) was handshake issues especially between 1.4 and 2.0 devices. I switched to Cinnamon and so far (knock on wood) I've had no problems.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    txcoastal1 Posts: 13,513
    Biggest problem I have with HDMI's is poor construction, even with ones that look nice.
    I purchase 100+ HDMI's a year and seen to many fall apart
  • mantis
    mantis Posts: 17,467
    I did many shootouts with various HDMI cables over the years and have very similar results as DK did.
    Im my personal system I'm running a mix of Carbon mostly with a Cinnamon up to the Display( Pioneer Elite Kuro 60inch). I stopped at Carbon because I wasn't getting any more benefits.
    If you compare side by side the Cinnamon and Chocolate, I feel there is basically no difference at all.
    When you compare the Forest and Cinnamon it's basically the same thing. It's so close it doesn't warrant spending the extra money.
    Even the Carbon vs the Forest or even Pearl for that matter it's so small you have to ask yourself if the money your spending is worth it. Some say it is, others say no.
    As tonyb pointed out , the more important thing with HDMI cables is the quality of the cable in reliability, handshake issues etc.
    I think personally the best value in the Audioquest line is either the Forest or Cinnamon. The price point IMO is very reasonable for a high quality cable and in all my years I never saw a bad Audioquest cable. I can't say that for any other brand.
    I also like DK use all Audioquest cables. The reason is first and foremost before performance is reliability. I have some old Audioquest cables and a lot of newer ones.
    On the performance side, they are extremely consistent.
    I enjoy reading DK's views on everything he reviews. He is very thorough.
    Dan
  • mrloren
    mrloren Posts: 2,474
    Very nice review. great reading for a Saturday morning.
    I see to many people buying junk cables these day's. They get the Willy's or Fry's $3.99 generic cable and think a cable is a cable. "It's all digital right". NO.
    I always suggest the bottom anyone should go is Costco Wirelogic HDMI Cables @ $20 for two 2 meter cables. When I help people change from the generic to these the look on their face when they see for themselves that there is a big difference is priceless.
    The more you go up the chain on HDMI Cables the less benefit there is. Just stay away from the generic stuff.
    For me I went from some very old green cables which just said "AQuest" I picked up at a garage sale to all modern Audioquest HDMI thanks to @mantis for helping me decide on the correct cables for my gear.
    Oppo to AVR Cinnamon, Panasonic to AVR Forest all others are pearl in my HT. These new cables did make from small to big differences. The first night my wife watched a movie with me after the cable change she said it looks and sounds better. I think AQ Pearl is the best bang for the buck there is But it is just my opinion.
    Now I am researching RCA cables for my future AMP. AQ Evergree is looking like it will be my choice.
    Cheers
  • DarqueKnight
    mantis wrote: »
    Dan, thank you for your recent personal advice on AQ HDMI cables, and for the HDMI cable shootout you did a few years back. All that information was very helpful.
    I went back and forth between the Cinnamon and the SecureOMax cables many times. When I run across a product that offers significant diminishing returns, the clincher is "can I live without it?" I appreciated the extra bit of performance provided by the Cinnamons, but when I took them out, I didn't miss them. The Cinnamons weren't a lot of money, but in my video life I am not trying to get every last bit of performance that my budget will allow. That's why I still have an 8 year old plasma TV and an 8 year old blu-ray player. If a home theater component doesn't really impress me, it goes back.
  • DarqueKnight
    Thus a $10 - $20 well made cable is all that is needed.
    A more balanced and rational recommendation would be to say that a $10 - $20 well made cable is all that is needed for most peoples' HT systems.
    I have used generic and low priced HDMI cables for years with good results. Years ago I tried some higher priced, higher claimed performance HDMI cables and found that they didn't perform any better than an $8 cable. I didn't conclude that higher priced cables are a scam, and that people shouldn't "waste" money on them. I concluded that some examples of such cables didn't provide a performance benefit in my HT system. I didn't side eye people who claimed to hear and see performance improvements in their systems with these cables.
    After the most recent tests, I concluded that performance benefits were seen and heard, but they didn't personally justify the price asked. Perhaps after I upgrade my TV and associated electronics, or if I find the same cables at a much lower price, I would consider investing in them.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I went from mono price hdmi cables that kept failing. I splurged on pearls for my entire system, I was friggen blown away by the increase in video and audio performance for a budget cable. I have carbons now, and noticed only a slight performance increase.
    I use a carbon USB in my 2 channel rig and for the money boy is it good! I now use a diamond, which was a HUGE increase over the carbon, I'm blown away! Audioquest digital cables are fantastic.
    2 channel:
    Theater:
  • BlueFox
    BlueFox Posts: 15,251
    A few years ago there was an MIT cable demo program, and I was surprised at the improvement I saw with their HDMI over the Pangea I was using. I wasn't expecting that, but it was there. Of course, I am still using the Pangea with my Oppo 203 and 75" Sony 4K UHD TV. :)
    F1nut Posts: 51,799
    I tried the MIT HDMI cable before sending them around in the demo. I liked it so much I got some for myself.
  • FestYboy
    FestYboy Posts: 3,861
    How do y'all feel about the Dayton prospects from PE?
    F1nut Posts: 51,799
    Serviceable
  • BlueFox
    Jesse, what was that MIT model number? I want to upgrade the Pangea, and move the Pangea to the Xbox One.
    FestYboy wrote: »
    No first hand experience, but at least PC has a review section. When dealing with 15' or less there's some give and take. When using a projector and longer lengths it's gonna cost you a little more.
    My client has ordering systems in the deli/kitchen area, I've been using Tripplite, because I also use their splitters, racks, PDU's etc.
    Been happy so far
    F1nut Posts: 51,799
    edited June 2017
    BlueFox wrote: »
    Here you go, http://www.mitcables.com/available-in-stores/video-interconnects/hdmi-3d-digital-cable.html
  • BlueFox
    Thanks. I will get a 4 meter. I haven't bought anything since I got the Oppo, and am getting antsy to spend money. :)
  • FestYboy
    Serviceable
    So you're saying they're nowhere near AE's bottom line?
    F1nut Posts: 51,799
    No, I'm saying Dayton stuff in general will get the job done, but it could be done better.
  • FestYboy
    Gotcha. Then I can't complain about the price I paid for them (cheap, on clearance).
  • K_M
    K_M Posts: 1,632
    FestYboy wrote: »
    We have a few from Dayton, and for the price they seem well made and work.
