SDA upgrade thread 2
Well it's here and I've had it for years. So I'm using it -
It DOES tamp down ringing
If you're going to do something at least do it right. I know you've seen plenty of mod threads here, so no excuses.Political Correctness'.........defined
President of Club Polk -
Wahhhh -
Trey is still waiting for some components from Great Britain.
Can't wait to hear what the finished product sounds like from @VR3 -
I'll just keep slugging away until then. More glue to do
What size are the bolts, plates and washers that hold the dreadnought transformer in place?
Can someone PLEASE tell me what size the bolt is that holds the dreadnought transformer to the case? I need to get one before they start shipping in a couple of weeks. Also the plate that goes on top of it.
There's a list on page 10 of the buy thread with everything you need.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Thanks @dkfreebird !
You know honestaquarian, when get all of the mods completely finished, and you've got the Dreadnought in place and everything starts to break in, you better have a good supply of Toilet Tissue handy...just sayin
Well Tito is on call :'(
5/16"-18 x 3-1/2" ASTM F593 18-8 Stainless Steel Tap Bolt
SKU: 71185 1 x1 $1.97 $1.97
5/16" x 1.250" OD Grade 18-8 Stainless Steel Fender Washer
SKU: 0172789 1 x2 $0.37 $0.75
5/16" 18-8 Stainless Steel Medium Split Lock Washer
SKU: 71065 1 x2 $0.12 $0.23
5/16"-18 18-8 Stainless Steel Finished Hex Nut
SKU: 70711 1 x2 $0.19 $0.38
Fastenal.com parts list for the bolt which holds the dreadnought transformer to the case. -
So those should arrive right before the transformers ship out from Avel-Lindburg
https://www.amazon.com/Dynamat-13100-DynaTape-Sound-Deadener/dp/B002WP362U/ref=sr_1_1?s=industrial&ie=UTF8&qid=1491870570&sr=1-1&keywords=dynamat+extreme
Will this work properly for the drivers and passive radiator?
I could clearly see when I was trying this original Dynamat that it was so old that the adhesive really wasn't sticking very well anymore. As you can see above the pieces that I cut and stuck to the midwoofers have been falling off. Oh well as much as I hate to admit it @F1nut was right once again dammit!! -
Don't know. Looks thin. Dynamat extreme is at least 1/16" thick I sticks incredibly strong.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
https://www.amazon.com/Dynamat-10415-Self-Adhesive-Deadener-Speaker/dp/B00020CATC/ref=sr_1_5?ie=UTF8&qid=1491875173&sr=8-5&keywords=dynamat
Okay what about this?
I'm not trying to completely cover the outside of the speaker baskets like most on here would do. Again I know from my own experience what F1nut in another thread said about only needing to use a little bit. -
That's only a 10" square sheet, not nearly enough.
I've purchased from this seller on eBay, hookedontronics. Check out what deals they have.Political Correctness'.........defined
Thanks @F1nut
Found them
If I'm not covering the entire woofer basket and only using a couple of patches per driver. How much would I need then? -
The wedge pack is all you should need. You should have some left for other projects.2 Channel
Oppo 103
Pangea PC
Wedge pack????
Yes'it is 24.50 plus free shipping from the company F1nut sent you.2 Channel
Oppo 103
Pangea PC
That's the one.2 Channel
Oppo 103
Pangea PC
If you haven't done your dreadnought box yet you might as well get enough for it.
Oppo 103
Pangea PC
Well again you don't have to cover the entire inside of it. A patch on each wall should be more than enough. It just looks good in pics when you overdo it by covering everything.
Okay just bought one from those guys
You would be surprised what even a little dynamat does, a little can go a long way.2 channel:
Theater:
