SDA upgrade thread 2
12467…10
  • honestaquarian
    honestaquarian Posts: 3,275
    Well it's here and I've had it for years. So I'm using it
  • honestaquarian
    It DOES tamp down ringing
    F1nut Posts: 52,382
    If you're going to do something at least do it right. I know you've seen plenty of mod threads here, so no excuses.
  • honestaquarian
    :p
    Wahhhh
  • honestaquarian
    Trey is still waiting for some components from Great Britain.
    Can't wait to hear what the finished product sounds like from @VR3
  • honestaquarian
    I'll just keep slugging away until then. More glue to do :(
  • honestaquarian
    What size are the bolts, plates and washers that hold the dreadnought transformer in place?
  • honestaquarian
    Can someone PLEASE tell me what size the bolt is that holds the dreadnought transformer to the case? I need to get one before they start shipping in a couple of weeks. Also the plate that goes on top of it.
  • dkfreebird
    dkfreebird Posts: 1,189
    There's a list on page 10 of the buy thread with everything you need.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • honestaquarian
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited April 2017
    You know honestaquarian, when get all of the mods completely finished, and you've got the Dreadnought in place and everything starts to break in, you better have a good supply of Toilet Tissue handy...just sayin
  • honestaquarian
    Well Tito is on call :'( ;)
  • honestaquarian
    5/16"-18 x 3-1/2" ASTM F593 18-8 Stainless Steel Tap Bolt
    SKU: 71185 1 x1 $1.97 $1.97
    5/16" x 1.250" OD Grade 18-8 Stainless Steel Fender Washer
    SKU: 0172789 1 x2 $0.37 $0.75
    5/16" 18-8 Stainless Steel Medium Split Lock Washer
    SKU: 71065 1 x2 $0.12 $0.23
    5/16"-18 18-8 Stainless Steel Finished Hex Nut
    SKU: 70711 1 x2 $0.19 $0.38
    Fastenal.com parts list for the bolt which holds the dreadnought transformer to the case.
  • honestaquarian
    So those should arrive right before the transformers ship out from Avel-Lindburg
  • honestaquarian
    edited April 2017
    I could clearly see when I was trying this original Dynamat that it was so old that the adhesive really wasn't sticking very well anymore. As you can see above the pieces that I cut and stuck to the midwoofers have been falling off. Oh well as much as I hate to admit it @F1nut was right once again dammit!!
  • machone
    machone Posts: 1,586
    Don't know. Looks thin. Dynamat extreme is at least 1/16" thick I sticks incredibly strong.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • honestaquarian
    https://www.amazon.com/Dynamat-10415-Self-Adhesive-Deadener-Speaker/dp/B00020CATC/ref=sr_1_5?ie=UTF8&qid=1491875173&sr=8-5&keywords=dynamat
    Okay what about this?
    I'm not trying to completely cover the outside of the speaker baskets like most on here would do. Again I know from my own experience what F1nut in another thread said about only needing to use a little bit.
    F1nut Posts: 52,382
    That's only a 10" square sheet, not nearly enough.
    I've purchased from this seller on eBay, hookedontronics. Check out what deals they have.
  • honestaquarian
    Thanks @F1nut
    Found them
    If I'm not covering the entire woofer basket and only using a couple of patches per driver. How much would I need then?
  • dkfreebird
    The wedge pack is all you should need. You should have some left for other projects.
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
  • honestaquarian
    Wedge pack????
  • dkfreebird
    edited April 2017
    Yes'it is 24.50 plus free shipping from the company F1nut sent you.
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
  • dkfreebird
    That's the one.
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
  • honestaquarian
    Thanks again @F1nut and @dkfreebird :)B)
  • dkfreebird
    If you haven't done your dreadnought box yet you might as well get enough for it. :)
    Eversolo Dmp 8
    SVS SB3000 sub
    Oppo 103
    Pangea PC
  • honestaquarian
    Well again you don't have to cover the entire inside of it. A patch on each wall should be more than enough. It just looks good in pics when you overdo it by covering everything.
  • honestaquarian
    Okay just bought one from those guys
  • mikeyb128
    mikeyb128 Posts: 2,885
    You would be surprised what even a little dynamat does, a little can go a long way.
    2 channel:
    Theater:
