Joule Electra Preamp owners?
1246
  • WagnerRC
    WagnerRC Posts: 2,207
    This may be a deal. Would have to track the bidding.....
    http://www.ebay.com/itm/222438651002?_trksid=p2471758.m4704
    pitdogg2 Posts: 27,149
    lightman1 wrote: »
    tonyb wrote: »
    lightman1 wrote: »
    I have a half eaten bag of Cheetos....
    Probably has a hole in the bottom, wink, wink, nudge nudge
    LMAO....a small hole at that.
    Tell the missus I said "Hello" ;)
    She said she never knew you were there....
  • kharp1
    kharp1 Posts: 3,453
    What is the upgrade difference between LA100 and the 150? Anyone? Bueller?
  • kharp1
    kharp1 Posts: 3,453
    Was it the addition of a phono stage?
  • kharp1
    kharp1 Posts: 3,453
    I've read through that before and again tonight but didn't really glean the differences between the two. Sent Rich an email earlier.
    WagnerRC wrote: »
    That is a deal, but with 4 days left and 5 bidders so far....betcha it climbs to around 1k the last day of the auction.
    As far as the differences go with the LA-150, I'm not quite sure myself as Judd was always tinkering around. Could be parts used, point to point wiring, I dunno, but what I do know is his circuit design pretty much stayed the same.
  • erniejade
    erniejade Posts: 6,321
    The tubes are different. I believe the 150 uses the Russian tubes and there should be a separate power supply board
  • george daniel
    george daniel Posts: 12,096
    edited March 2017
    Not trying to derail,, but here is a pic of mine,, it is the LA 100 Mk II version with the dual volume controls.
    F1nut Posts: 51,871
    edited March 2017
    The LA-100 uses a single 5751 with a 6350 mu follower. The LA-150 uses all 6350's. The one in the auction has been changed from an LA-100 to a LA-150. IMO, they should have left it as an LA-100.
    No Russian tubes were used in any of the pre amps, just the OTL amps.
  • erniejade
    Gain tubes are Russian 6c45P1 and the 6H30PI for the MU for the regular 150
    On the 150 A version I had they replaced the 6H30P and used the 6350
  • erniejade
  • george daniel
    My old LA 100 uses Two 13EM7's on two OA 2's in the power supply,,and two 5751's in the line stage
    F1nut Posts: 51,871
    erniejade wrote: »
    You're right Brian. I forgot about that short lived version. It wasn't received well and Jud changed it quickly.
  • erniejade
    The A and mkII are the ones to grab on the 150's for sure. And the phono pre sounded wonderful!
    Mine is the original la-100, also uses 2 5751's for both stages. I think he changed it to one 5751 and one 6350 in the LA-100 mk3.....I could be wrong though.
    F1nut Posts: 51,871
    That's correct Tony.
  • kharp1
    kharp1 Posts: 3,453
    Not sure I can see enough difference worth making a move. Could be wrong, wouldn't surprise me if I was.
  • george daniel
    tonyb wrote: »
    Tony,, what compliment of tubes are in the power supply section?
    OA2 's and the other tubes are 6EM7's. I'm wondering why you have the 13EM7's but I recall reading somewhere that was an acceptable replacement.
  • george daniel
    From what I understand Mr Barber built some that use the 13EM7,, I do not remember if it was in the earlier or later models
    F1nut Posts: 51,871
    He used what was on hand, sometimes 13EM7 others 6EM7, but you can't just swap one for the other.
  • george daniel
    Right,, you had 13's in yours IIRC,, I will never forget that rig with the Manley and those stock 1C's,, good times!
    F1nut Posts: 51,871
    Good times indeed, George.
    I was reading up on some reviews and came across a guy who did just that. Apparently he didn't think the 13EM7'S sounded as good as the 6's. Could be because the circuit wasn't designed for the 13's, I dunno.
    Reading many reviews, I've discovered that if you stay within Judd's recommendations for each model, your going to be a happy camper. He didn't create pieces and told you to tube roll to your preferences like many others do. He designed circuits to work with a certain smaller variety of tubes that sounded best to his ears.
    I like that approach, saves time and money rolling tubes and as we all know some pieces of tube gear have endless possibilities to roll. He included good NOS tubes with his pre's also, not junk leaving you additional costs by hunting up tubes yourself. Guy had a good ear for musicality that's for sure.
  • george daniel
    Yep,, Sylvania TMBP in the front and RCA in the back,,both 5751's,, Mr Barber made it easy!
    I have a pair of RCA 5751'S blackplates in there now, picked up some Sylvania 5751'S Blue tips to try out but haven't gotten around to it yet. Anyone familiar with that tube ?
    F1nut Posts: 51,871
    Some of the caps are different, so yeah it's not going to work.
    heiney9 Posts: 25,482
    Except now your buying something voiced for someone else's ears. If you have the capability to tube roll, you should, just so you know in your own mind the "original" sound is the sound you prefer.
    Some of us on here and in this thread, modify things all the time to get something more. Rolling tubes is just an easier way to see if you can get "something more". All tube gear is voiced with the tubes on hand. If there are alternatives out there I would see no reason not to atleast experiment with suitable alternative tubes.
    Just my devils advocate .02c >:)
    P.s. I've never heard a tube gear owner state "not to roll tubes", that's part of the experience, especially when it can be done so easily and quickly..........ok, I'll shut up now o:)
    F1nut Posts: 51,871
    In Joule pre amps what comes with them is as good as it gets. Rolling tubes is a waste of time and money. I know from time and money.
