SDA upgrade thread 2
2456710
  • muncybob
    muncybob Posts: 3,238
    Man, you been bz! Sealing the cabinets is 1 thing I totally overlooked when I had mine open...dang it! Still, they do pass the push test so maybe it's not really needed on mine. I guess if I open them up again I will do it though along with an inductor change. My wife says they sound good as are and I kinda agree with her. Adding the BH5 was worthwhile for sure...really looking forward to getting my tube pre back for some serious listening.
    Keep calm and mod on!
    Yep, my name really is Bob.
  • honestaquarian
    honestaquarian Posts: 3,260
    I did the push test on mine by pushing in the passive radiator. All of the woofers came out and then immediately settled back down a bit (*not all the way though*) So I definitely have some cabinet leakage somewhere.vypwzv28au1j.jpg
    However I have to go to another hardware store and pick up some more Power Grab in the larger container that you use with the squeeze gun. The ones that I have are like toothpaste tubes and as you can see in some of the pics it ain't workin' out too good. :|:#
  • dkfreebird
    dkfreebird Posts: 1,186
    I think you will find the larger tubes to be harder to work with. Just run a small bead on the seams and smooth it out with your finger. I tried the larger tubes on mine and went to the smaller ones.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • machone
    machone Posts: 1,558
    It's hard to get a gun into the cabinet.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • honestaquarian
    Okay so smaller tubes and rubber gloves it is!
    Thanks @dkfreebird and @machone !!
    If anyone else has any experiences/tidbits/tips post'em here. This is why I started this thread.
  • stones89
    stones89 Posts: 229
    You are doing a good job! Thanks for posting the journey.
    Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
    pitdogg2 Posts: 27,035
    edited March 2017
    they also make a power grab in a pressurized can that might work in there. First I'd remove everything, trying to work around stuff is a pita
  • You can also use a rounded end popsicle stick to form the Power Grab into a nice fillet for cabinet seams.
    yep i always keep a bag of those around. So many uses very versatile. Any craft store or wal-mart will have them.
  • honestaquarian
    You can also use a rounded end Popsicle stick to form the Power Grab into a nice fillet for cabinet seams.
    Popsicle stick eh?
    COOL
    I see`em all the time discarded. Now of course just because I'll be looking for one I won't find any!
    Thanks @littlewoodboats !
  • Nightfall
    Nightfall Posts: 10,084
    I got the self pressurized can type and it worked fine for me. You don't need no stinking gloves, just wipe your finger off on a hand towel. It mostly comes off, the rest in the following days ;)
    afterburnt wrote: »
    Village Idiot of Club Polk
  • honestaquarian
    Nightfall wrote: »
    Dass juss NASTY :#:p
    Nightfall wrote: »
    or you could wash your hands, it is water soluble
  • Nightfall
    I did, still couldn't get it 100% off, I may have just lost patience too soon though.
    afterburnt wrote: »
  • honestaquarian
    edited March 2017
    You know,this requires a LOT MORE work,patience and attention to detail than it looks like on some of the threads that I've seen. You have to make sure you mark the wiring once it's removed from each driver. So that you NOT ONLY know which driver it goes to,but also which is the positive terminal. You also have to have a small,Flathead screwdriver or something of that sort to CAREFULLY pry the drivers out of the countersunk holes in the cabinet. Gluing the magnets ain't no picnic either.
    Next step is to apply more glue to the corners of the cabinet and then apply the Blackhole 5 that you see lying on the cabinet.
  • honestaquarian
    edited March 2017
    The wiring is JUST long enough to go to each driver,so it would be VERY EASY to get it all mixed up.ESPECIALLY when some of it is wired in series! :o
  • honestaquarian
    edited March 2017
    I'm gonna take my sweet time doing this. All this bending over the cabinets and what not ain't exactly a walk in the park anymore when your middle aged :( and I don't have a workshop or workbench in a garage like some of the guys on here. Small apartment here with no basement or garage. :#
  • honestaquarian
    It's a good thing I love my Polk SDA's and like doing stuff like this!! :D
  • honestaquarian
    ONE Blackhole5 pad installed (*yay*) I'm done for now. Get black to this later
  • honestaquarian
    muncybob wrote: »
    @muncybob
    Again my thanks for the BH5. When you do the push test look CLOSELY at the woofers when you push in the passive radiator. While your hand is holding the PR in look to see if the woofers move back inward while your hand is still and holding the PR in. If the woofers move then you got air leakage! I discovered it's far easier to see when the cabinet in flat on it's back on the floor.
  • honestaquarian
    Hobbits?
    Never heard of`em :D
  • Nightfall
    No matter how air tight the cabinets are the MWs will always retract because the dust caps can breathe.
    afterburnt wrote: »
    F1nut Posts: 51,749
    muncybob wrote: »
    @muncybob
    Laying on their backs is not how you test for air leaks because you now have this thing called gravity to deal with. In addition, as Nightfall noted, the drivers will retract regardless. The time span is 3 to 5 seconds.
    VR3 Posts: 29,425
    Looking good! :)
  • muncybob
    On the push test, the drivers will retract slightly but then will maintain their outward position for 5+ seconds...never really timed it but it was more than 5 seconds I'm sure. I'm glad I had my pool table to work on my cabinets!
    So, if I was interested in going to the next level of making my 2B's TL, besides a new tweeter what is needed. My x-overs are already done with sonic caps, mills, etc. I must say, I'm fairly happy with the way they sound now but as usual you don't know what you don't know.
  • honestaquarian
    The rings will be next.
    Now that I think of it the woofers did hold in place for a few seconds after they settled.I'm still sealing the cabinets though. I've already started doing it so..........
    F1nut Posts: 51,749
    muncybob wrote: »
    You don't understand the push test. It is the amount of time the drivers stay ALL the way out, before they react to their resting position.
  • muncybob
    Well then, I guess I have cabinet leakage...opening them up again...sigh.
    F1nut Posts: 51,749
    Push the PR in and hold. The mids will move forward, start counting. Should be 3 to 5 seconds as they slowly retract to a resting position. As you release the PR the mids will suck in, then slowly return to rest.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Yeah, and people look at me sideways when I say I don't like doing the work involved in mods.
    I made a small pry bar from a piece of clothes hanger wire:
    Figure 3. This thingamajig, which was made from a wire clothes hanger to assist in pulling drivers from a speaker cabinet, has proven useful in lifting off the snug-fitting covers of my X600.5 power amps and in spreading strips of Dynamat in tight places.
