any recommendations from the professionals?
124»
  • exalted512
    exalted512 Posts: 10,734
    edited October 2004
    dynamat and those baffles have 2 entirely different purposes
    id go with second skin over dynamat
    www.secondskinaudio.com
    its cheaper and better
    if u go with dynamat, go dynamat extreme and get it off ebay for as cheap as you can find it
    -Cody
  • jroberts_101
    jroberts_101 Posts: 106
    edited October 2004
    alright thx guys.
    Polk Momo MMC6500
    Polk Momo C300.2
    Polk Momo MM2124 (2)
    Polk Momo C500.1
    Pioneer DEH-P7600MP
  • jroberts_101
    edited October 2004
    HELLO AGAIN!
    some of you there might be pissed about this - but i called the local car audio shop, and they said 89 bucks for a double sub enclosure. he asked what type of subs, i told him, and he said the sub box would be a cubic foot or a cubic foot and a half. is this a good size? he also said that they used to carry polk and this is a pretty much universal sub box for mid-level subs like the mm2124. so it will work or not? help me out here :) again :) thanks
    Polk Momo MMC6500
    Polk Momo C300.2
    Polk Momo C500.1
    Pioneer DEH-P7600MP
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2004
    Well the recommended enclosure is .80 cubic feet. So for two of them youd need 1.6 which is a little more than 1.5. If he has a 1.5 sealed box for 2 12's then Id say it would work just fine provided its built correctly.
  • neomagus00
    neomagus00 Posts: 3,899
    edited October 2004
    yes, that 1.5 cubic foot enclosure will work, provided that it's 1.5 for BOTH subs - they want like 1.7, but 1.5 will work just fine. if it's 1.5 for EACH sub, go with the 1.0 version, cause that's closer to the .9 they want. i believe that momos tend to have relatively stiff suspensions for their respective class, so they take a slightly bigger box... i think that's right. in any case, get as close as you can to 0.88 each.
    p.s. it's 0.88 for each sub.
  • jroberts_101
    edited October 2004
    sweet thanks guys. from past posts- what would the baffles do? just keep em dry? are they a good idea ? would they help w/ sounddeadening a little? i know that the dynamat stuff is better. just wonderin tho . thanks
    oh and yea i told the guy for 2 subs. double enclosure i called it. so he should be talkin bout that.
    John
    Polk Momo MMC6500
    Polk Momo C300.2
    Polk Momo C500.1
    Pioneer DEH-P7600MP
  • neomagus00
    edited October 2004
    the baffles you were talking about from crutchfield waterproof the back of the speaker; that's ALL they do. The dynamat has nothing to do with waterproofing, it deadens vibrations in the car; this is good. two different animals.
  • jroberts_101
    edited October 2004
    are they necessary? when would my speakers get wet!!??
    Polk Momo MMC6500
    Polk Momo C300.2
    Polk Momo C500.1
    Pioneer DEH-P7600MP
  • spwuinmk67
    spwuinmk67 Posts: 797
    edited October 2004
    They're not needed. Car speakers are made to deal with the elements.
    1993 Ford Ranger super cab:
    Pioneer Premier DEH-P880PRS
    MB Quart QSD216
    in need of amps and subs
    Home:
    52" Sharp Aquos
    PolkAudio Monitor 10's
    Harmon Kardon HK3375
    Xbox 360
    PolkAudio XM tuner
    Owner and co-designer of www.basicholdem.com
  • neomagus00
    edited October 2004
    true, and the inside of your door shouldn't get anything but a bit of a drip in heavy rain, if your seals are decent... now, we wouldn't want to take our speakers dancing in the rain, but a few drips won't hurt a thing.
  • spwuinmk67
    edited October 2004
    Thats a big if though. I had my crossovers in my doors originally, and when I wired them up to my amp, I noticed the terminals getting rusty, so needless to say I moved them. I made a nice little hole in the door, and put it in the little pocket. Not trying to scare you, it is possible for water to get in, but it won't do much, my crossovers still work great.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • jroberts_101
    edited October 2004
    well **** for 7.99 my as well get them man if its a possibility u kno
    Polk Momo MMC6500
    Polk Momo C300.2
    Polk Momo C500.1
    Pioneer DEH-P7600MP
  • spwuinmk67
    edited October 2004
    It's possible for water to get in yes, but it won't cause any dammage.
    MB Quart QSD216
    Home:
    52" Sharp Aquos
    Xbox 360
    PolkAudio XM tuner
  • neomagus00
    edited October 2004
    if you're at all worried about your speakers getting wet, get the eight dollar baffles and you won't have to worry about it. it's like buying expensive speakers - to you they DO sound better, cause you bought em; same with the baffles, you'll be paranoid about em all the time, just spend it and be done with it... that's my advice...
  • jroberts_101
    edited October 2004
    cool thx. c yaaa 4 now
    Polk Momo MMC6500
    Polk Momo C300.2
    Polk Momo C500.1
    Pioneer DEH-P7600MP
