Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
11920222425
  • nspindel
    nspindel Posts: 5,343
    agfrost wrote: »
    nspindel wrote: »
    I still can't believe someone got themselves banned from CP in this group buy!
    it was well deserved. Good times.
    Dude totally went off the deep end.
    F1nut Posts: 48,439
    VSAT88 wrote: »
    F1, I may well be mistaken but I thought I had been told by you that my blade blade 2b speakers were of the type that can be used. It seems that we spoke in another thread about it. My 2bs have one active cable in the interconnect. Only one cable connects between the speakers, the other blade has no connection whatsoever. It terminates to nothing but a blade on the cup/backplate never attaching to the crossover network. I think I spoke with you but maybe it was someone else here and they said I could use an AI-1 / Dreadnought however I would need connect / terminate it at the speaker grounds. When I have time I will try and look back thru my threads and see if I can find it. Thanks for the advice about the 800VA transformer. I have a thread in WTB about a used one and I can wait if need be. I do not have the extra cash now to order new however I do have a case picked out. An old Eico tube Oscilloscope case gutted out. At least I thought about it anyway.
    Ok, I thought you meant 2 separate cables, but I understand what you meant now. As I said, some blade/blade 2B's can use the AI-1/Dreadnought and it seems yours would be one. There is a list of serial numbers of those that can, but I don't have access to it right now.
  • Schurkey
    Schurkey Posts: 2,062
    http://forum.polkaudio.com/discussion/131691/2b-and-early-1c-ai-1-modifications
  • I just checked my SDA-1C's and they are serial numbers 6545 (Right), and 6533 (Left).
    Anybody know what are the "plug adapters and some internal modifications to the crossover"? I have always used a common ground amp (GFA-555) with my SDA-1C's, but I also would like to try my GFA-565 mono-blocks if I can make a tweak to the crossover.
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • Sorry Schurkey, I just noticed the link you provided. Sounds like a very straightforward upgrade.
    One question, why do we need to connect the "other blade" to the negative binding post? I thought that even with the AI-1 compatible pin-blade configuration, only the pin carried any signal, and the blade wasn't hooked up to anything. Am I confused?
    HT
    2 Channel (Office)
    2 Channel (Garage)
    F1nut Posts: 48,439
    edited December 2016
    The pin and blade carry signals with the original AI-1 in which case the blade is connected to the negative circuit.
  • Thanks F1nut. I always learn something every day on CP!
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • VSAT88
    VSAT88 Posts: 1,185
    250GTLusso wrote: »
    No doubt on that one. These guys have forgotten more than I will ever know about Polk speakers.. Now, I will read and document more so that one day I no longer be called "grasshopper".
  • VSAT88
    VSAT88 Posts: 1,185
    Some early production 2Bs and 1Cs used leftover component's from the 3rd generation. Cabinets, IC Cables and Sockets, and I recently had a 1C that had jury-rigged 1B circuit boards. Always best to check exactly what you have.
    Undoubtedly westmass, thats why I am always hovering around here at CP. I have not found anything that I could not destroy yet by thinking that I know what I am doing ! I am learning better now...So I hope.
  • VSAT88
    VSAT88 Posts: 1,185
    Schurkey wrote: »
    Thats the cats meow ! Thanks . Duly noted and snipping tool used to document for the next time..and there will be a next time.
  • nspindel
    I was traveling yesterday and was sitting in the airport terminal, and started thinking about that scooby doo character being banned, but I couldn't remember the details of what happened. I started re-reading the whole thing while I was waiting to get on the plane. Absolutely insane.
    If anyone wants a lesson in how to get yourself banned from CP, check this dude out. Everything was going just dandy until page 8, when Larry started the whole thing by putting up a link to his thread in the for-sale forum, which a few people couldn't see yet because they'd not posted anywhere. Read the next 6 pages or so.
    I forgot that he called Melanie himself and tried to hijack his way back into the sale. That guy went completely off the deep end!
  • I received a call and an email back from Melanie.
    Please let me know if you are interested in participating in another group buy.
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • Dammit I want one,but can't afford it until I get my tax refund in February.
    Also @250GTLusso you might want to follow the lead of the previous newbie poster and have one of the forum members who've been here longer take this over.
  • GDP
    GDP Posts: 27
    Thank you for the responses, I will check my serial numbers, you guys are great.
  • I have no problem handing it over to a more senior CP member. I just thought I would get the ball rolling!
    HT
    2 Channel (Office)
    2 Channel (Garage)
    nooshinjohn Posts: 24,386
    I could use one, but need the case that Larry was making...
    The Gear... Carver "Statement" Mono-blocks, Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 380d DSDIn retirement...TriangleArt Reference SE with Walker Precision Motor Drive, Yamaha CD-S2100 SACD Player.“Every record has been destroyed or falsified, every book has been rewritten, every picture has been repainted, every statue and street building has been renamed, every date has been altered…History has stopped. Nothing exists except the endless present in which the party is always right” — George Orwell“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • GDP
    GDP Posts: 27
    Looks like I'm good on the 2b's both start in the 15xxx, but my SRS 2's are only 563 and 565.
  • Schurkey
    GDP wrote: »
    Blade-Blade SRS-2s? They're the first-generation SRS 2s, based on the SDA 1B. Cannot use the isolation transformer. The later-generation was based on the SDA 1C, which can use the transformer.
    Toolfan66 Posts: 15,727
    Ha, I forgot how crazy this thread turned..
  • 250GTLusso wrote: »
    Hmm.. Just a thought. That quote shows an isolating transformer with 115v per tap on primary and 119.8v per tap on secondary. This is a slightly skewed ratio so that when the secondary is under load there is no net voltage drop. That makes sense in a power isolation application, but is not ideal in our symmetrical use case. If Avel Lindberg are making these to order, do you think they would make one with 115v no load secondary I.e. 1:1 turns ratio on the windings?
    I guess with my dreadnought, the soundstage is skewed slightly right or left, but the room itself probably accounts for more non-symmetry :-)
  • Schurkey
    You're not the first to notice that discrepancy. We've been assured that it doesn't make any difference.
    OTOH, nobody has tested a true 1:1 transformer using the same wire gauge on both primary and secondary--i.e., genuinely symmetrical.
  • nspindel
    Toolfan66 wrote: »
    Hey man, you started it!
  • Mr_Hz
    Mr_Hz Posts: 176
    As for my part... I went to my priest. I am absolved....
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
  • nspindel
    Mr_Hz wrote: »
    Ron, you've got to be good for three more posts on this thread. Then you can finally see the for-sale thread about Larry's enclosure!
  • nspindel
    By the way, I double checked and the price we paid for 12 units in this group buy in 2014 was $292.88/each. So they haven't increased prices since then. I do recall a price increase when I did this order over the first group buy that I did for these transformers, so if there's interest in doing another one, I'd advise that you get it moving forward, because you never know when they can decide to raise prices again.
    I bet if you put up a new thread as an interest check for a group buy, you'd be able to put a crew together fairly quickly.
  • monepolk
    monepolk Posts: 1,139
    ^You did such a great job last time....
  • Count me in! All we need is 10 interested members right?
  • Ok, so we have the following interested parties in the next group buy:
    1.) 250GTLusso
    2.) Drumsolo
    3.) honestaquarian (need confirmation)
    4.) nooshinjohn (need confirmation)
    5.)
    6.)
    7.)
    8.)
    9.)
    10.)
    Any others?
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • vcwatkins
    vcwatkins Posts: 1,993
    Count me in for one.
    Beach Study: ProJect Stream Box Ultra & Pre Box S2 * Pass ACA * DH Labs SS Q10 * Brines Folded ML-TQWT 40-1354Town Study: Elekit TU-8600S * Zu Omen DW * Shunyata Hydra 2 * MIT S3 Beach Cave: Schiit Yggy * Belles 20a * Pass Aleph 30 * Polk SRS 2.3tl * PSAudio PP3 * MIT S3 Beach Den: Dayens Menuetto * Polk R200 / Dynaudio Audience 30 / Usher V-601Town Den: PS Audio DSJr * Joule-Electra LA-100mkiii * Schiit Aegir / Pass F5 Clone * Polk SRS 1.2 * PSA Dectet * MIT S3
  • Awesome! Thank you vcwatkins.
    1.) 250GTLusso
    2.) Drumsolo
    3.) vcwatkins
    4.) honestaquarian (need confirmation)
    5.) nooshinjohn (need confirmation)
    6.)
    7.)
    8.)
    9.)
    10.)
    Any others? Come-on, I know you are out there :-)
    HT
    2 Channel (Office)
    2 Channel (Garage)
