Dreadnaught Avel-Lindberg 1000VA Transformer Group Buy?
1…1718192123
  • VSAT88
    VSAT88 Posts: 1,390
    Schurkey wrote: »
    There is a list of serial numbers of those that can, but I don't have access to it right now.
    http://forum.polkaudio.com/discussion/131691/2b-and-early-1c-ai-1-modifications
    Thats the cats meow ! Thanks . Duly noted and snipping tool used to document for the next time..and there will be a next time.
  • nspindel
    nspindel Posts: 5,343
    I was traveling yesterday and was sitting in the airport terminal, and started thinking about that scooby doo character being banned, but I couldn't remember the details of what happened. I started re-reading the whole thing while I was waiting to get on the plane. Absolutely insane.
    If anyone wants a lesson in how to get yourself banned from CP, check this dude out. Everything was going just dandy until page 8, when Larry started the whole thing by putting up a link to his thread in the for-sale forum, which a few people couldn't see yet because they'd not posted anywhere. Read the next 6 pages or so.
    I forgot that he called Melanie himself and tried to hijack his way back into the sale. That guy went completely off the deep end!
  • 250GTLusso
    I received a call and an email back from Melanie.
    Please let me know if you are interested in participating in another group buy.
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • honestaquarian
    Dammit I want one,but can't afford it until I get my tax refund in February.
    Also @250GTLusso you might want to follow the lead of the previous newbie poster and have one of the forum members who've been here longer take this over.
  • GDP
    GDP Posts: 27
    Thank you for the responses, I will check my serial numbers, you guys are great.
  • 250GTLusso
    I have no problem handing it over to a more senior CP member. I just thought I would get the ball rolling!
    HT
    2 Channel (Office)
    2 Channel (Garage)
    nooshinjohn Posts: 26,178
    I could use one, but need the case that Larry was making...
  • GDP
    GDP Posts: 27
    Looks like I'm good on the 2b's both start in the 15xxx, but my SRS 2's are only 563 and 565.
  • Schurkey
    Schurkey Posts: 2,130
    GDP wrote: »
    Blade-Blade SRS-2s? They're the first-generation SRS 2s, based on the SDA 1B. Cannot use the isolation transformer. The later-generation was based on the SDA 1C, which can use the transformer.
  • crispybrown
    250GTLusso wrote: »
    Hmm.. Just a thought. That quote shows an isolating transformer with 115v per tap on primary and 119.8v per tap on secondary. This is a slightly skewed ratio so that when the secondary is under load there is no net voltage drop. That makes sense in a power isolation application, but is not ideal in our symmetrical use case. If Avel Lindberg are making these to order, do you think they would make one with 115v no load secondary I.e. 1:1 turns ratio on the windings?
    I guess with my dreadnought, the soundstage is skewed slightly right or left, but the room itself probably accounts for more non-symmetry :-)
  • Schurkey
    You're not the first to notice that discrepancy. We've been assured that it doesn't make any difference.
    OTOH, nobody has tested a true 1:1 transformer using the same wire gauge on both primary and secondary--i.e., genuinely symmetrical.
  • nspindel
    Toolfan66 wrote: »
    Ha, I forgot how crazy this thread turned..
    Hey man, you started it!
  • Mr_Hz
    Mr_Hz Posts: 176
    As for my part... I went to my priest. I am absolved....
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
  • nspindel
    Mr_Hz wrote: »
    Ron, you've got to be good for three more posts on this thread. Then you can finally see the for-sale thread about Larry's enclosure!
  • nspindel
    By the way, I double checked and the price we paid for 12 units in this group buy in 2014 was $292.88/each. So they haven't increased prices since then. I do recall a price increase when I did this order over the first group buy that I did for these transformers, so if there's interest in doing another one, I'd advise that you get it moving forward, because you never know when they can decide to raise prices again.
    I bet if you put up a new thread as an interest check for a group buy, you'd be able to put a crew together fairly quickly.
  • monepolk
    monepolk Posts: 1,154
    ^You did such a great job last time....
  • DrumSolo
    Count me in! All we need is 10 interested members right?
  • 250GTLusso
    Ok, so we have the following interested parties in the next group buy:
    1.) 250GTLusso
    2.) Drumsolo
    3.) honestaquarian (need confirmation)
    4.) nooshinjohn (need confirmation)
    5.)
    6.)
    7.)
    8.)
    9.)
    10.)
    Any others?
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • vcwatkins
    vcwatkins Posts: 1,992
    Count me in for one.
  • 250GTLusso
    Awesome! Thank you vcwatkins.
    1.) 250GTLusso
    2.) Drumsolo
    3.) vcwatkins
    4.) honestaquarian (need confirmation)
    5.) nooshinjohn (need confirmation)
    6.)
    7.)
    8.)
    9.)
    10.)
    Any others? Come-on, I know you are out there :-)
    HT
    2 Channel (Office)
    2 Channel (Garage)
    F1nut Posts: 52,406
    For those of you SDA owners who may be thinking, but I don't run mono blocks or have a non-common ground amp, so why do I need one of these let me tell you, you need one. The improvement in sound quality is not subtle.
  • Schurkey
    For those of you SDA owners who's speakers are new enough to accept an isolation transformer, who may be thinking, but I don't run mono blocks or have a non-common ground amp, so why do I need one of these let me tell you, you need one. The improvement in sound quality is not subtle.
    FIFY.
  • machone
    machone Posts: 1,588
    For sure.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • MrBuhl
    MrBuhl Posts: 2,419
    I missed out on a run once, thanks to one of our kindest Polkies, I was able to grab one, you will not be sorry, strike while the iron is hot, sometimes its a lot more than a year or two between these group buys!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    edited December 2016
    I'm in... but would feel more confident in the effort if it were led by someone that has been around a while. I don't mean to doubt your integrity GT...
    Btw, how did you arrive at such a legendary moniker. I have '61 Lusso in rosso corsa over palomino hides. It was restored in 2009, but I haven't had the nerve to take it outside...hdzyywef6h5r.jpg
  • honestaquarian
    @nooshinjohn
    250GTLusso wrote: »
  • nspindel
    What he said.
  • 250GTLusso
    Nooshinjohn, I grew up with two 250GT Berlinetta Lussos (SN4851, and SN5861), and a 250GTE Series II (I cant remember the SN right now).
    Here are a couple pictures of when we owned 1964 Ferrari 250 GT Berlinetta Lusso SN5861
    And what the car looks like today (after a Chuck Wray restoration back in 2006)
    That is a very nice 250GT SWB that you have. I know several other owners of SWBs (SEFAC Hot Rods, etc.). What serial number is your SWB?
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • 250GTLusso
    Nooshinjohn, I grew up with two 250GT Berlinetta Lussos, SN4851(1963) and SN5861 (1964) and a 250GTE Series II (I can't recall the serial number at the moment).
    Here are a couple pictures of SN5861 when we owned it:
    In the driveway of my mom's house
    At Mosport
    At Watkins Glen
    And a recent picture after it was restored by Chuck Wray (completed in 2006)
    Here is a recent picture of SN4851 at the Goodwood Revival (we sold it to Tex Otto, but ultimately ended up with Chris Evans in the UK)
    That is a very nice 250GT SWB. I have always loved those cars, particularly the '61 SEFAC hot rods, and know several owners. What serial number is your SWB?
    HT
    2 Channel (Office)
    2 Channel (Garage)
  • 250GTLusso
    Nooshinjohn, totally understand your hesitation (I have utilized personal references before with overseas vehicle purchases involving very large sums of money), so I am not offended at all.
    If there is a more senior member of CP willing to coordinate the group buy I would be more than happy to hand it over to them.
    For now I will keep stoking the fire until someone steps in to take the lead.
    1.) 250GTLusso
    2.) Drumsolo
    3.) vcwatkins
    5.) nooshinjohn
    6.)
    7.)
    8.)
    9.)
    10.)
    Did I miss anyone?
    HT
    2 Channel (Office)
    2 Channel (Garage)
