Nelson Pass Amp Camp Monoblocks
More herd...
The Nelson Pass designed all Class A dual Mono amps.
Article here:
http://www.diyaudio.com/forums/diyaudio-com-articles/214808-amp-camp-amp-1-a.html
Built by me from the amp camp amp kit and premium parts were used in place of some of the generic parts. This kit has the best Vampire RCA's (CM1F/CB) and Parts Express Premium binding posts. Input and output wiring is not stock (cotton wrapped copper on the inputs and Vampire wire to the speaker binding posts) and the caps were all replaced with Nichicon. The only change I made was to NOT mount the way too bright LED's in the front panel but instead I used red ones right at the board.
If memory serves I also replaced all the smaller resistors with higher wattage (same ohm value) resistors.
These run on individual laptop power supplies (19v). The minor upgrade has been done on this so it does run a bit more power than advertised.
Asking $350 and will include the power supplies. Buyer responsible for shipping costs. I'll provide packing.
Aaron
Enabler Extraordinaire
    EndersShadow Posts: 17,542
    DAMMMMNNNN bro!
    heiney9 Posts: 25,092
    What's the power output? Good for 4 ohms?
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Nice! must have been fun to build.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    heiney9 wrote: »
    5 watts of Class A power. Think of it as a SET tube amp...tremendously clean and a very powerful 5 watts.
  • ALL212
    ALL212 Posts: 1,558
    heiney9 wrote: »
    Here's everything to know. Mine are a bit more powerful as I've done the small modification. You can also use more than 19v (up to almost 30 if I'm not mistaken) but it will run significantly hotter and probably not last very long.
    Frequency response 10 - 20 kHz +/- 0.1 dB
    • Power per channel 5 Watts per channel (That's 92 decibels coming out of your speakers, assuming you're listening from 10 feet away with 91db efficiency speakers. More than 2 hours at this volume level exceeds occupational safety limits, is more than adequate to annoy your neighbors, and certainly enough to enjoy your music at normal listening levels)
    • Distortion 0.7% at 1 Watt (primarily second order harmonic which being even-order is described as "sweet, tubey" and being low-order as "benign/inaudible")
    • Input impedence 10 Kohm
    • Max Gain 14dB
    • Damping factor 3
    • Output noise 100 uV
    • Power supply input 110-240V
    • Power supply output 19V 4.74A
    • Heat dissipation 20 Watts per Channel
    Aaron
  • ALL212
    ALL212 Posts: 1,558
    This one was fun - nice and simple. There is a 250+ page thread over in amp camp land with all kinds of detail.
    I've built two and am keeping the heavily modified one.
    This one is NOT for sale:711ccepqo5o2.jpg
    Aaron
  • mrbiron
    mrbiron Posts: 5,711
    Wow......I've been contemplating buying and building that kit for a while. Of course you would have it......
    I now know who to harp on when the time comes.
  • ALL212
    ALL212 Posts: 1,558
    When you get there let me know - I've a secret...
    Aaron
    So these run pretty hot? I realize with only 2 output devices even if they run hot it's probably not that much heat. The Aleph by comparison dissipates 200wpc. So I guess I could assume about 1/10 of the Alephs heat which can raise room temp by about 3*?
    What are the dimensions of the chassis? Approx.?
    Contemplating a 3rd rig, why?.................I have no idea....lol.
    But these are cool and I know the quality of workmanship!
    Can one build a standard (traditional) power supply? I am not a fan of switching walwarts. But I suppose in the scope and spirit of what these are supposed to be, it's perfectly acceptable.
  • ALL212
    ALL212 Posts: 1,558
    These ran 24 hours a day in my bedroom setup (my radio alarm clock if you would). They get warm - that heatsink is more than enough to dissipate even in a warm room and I never noticed the temperature go up because of it.
    I'd guess it's about 4" square by 10" long.
    http://diyaudiostore.com/products/amp-camp-amp-kit - a video towards the bottom of that page will give you an idea of the size.
    Some folks have built power supplies. I've thunk it - I decided against it. So, yes, One could build a power supply - just not me. Anything that puts out 18 through 24 or so volts DC at around 4 amps should work. That connector at the back of the housing isn't cemented in so if it would need to be changed to accommodate whatever you might use it wouldn't be prohibitive.
    Aaron
  • ALL212
    ALL212 Posts: 1,558
    Bump - I'll bump again Friday and then off to the 'bay.
    Aaron
  • mrbiron
    GRRRRrrrrrrr! :angry:
    I really want to do this myself...
    I like your photo of the BAAC (Big A** Amp Camp) and noticed you completed it 4 years in the future.
  • ALL212
    ALL212 Posts: 1,558
    mrbiron wrote: »
    ... and noticed you completed it 4 years in the future.
    I had no idea I had that kind of power...be careful what mods you employ on these kits!
    It's an easy kit to do if you can solder a circuit board - lots of room. The new kits incorporate the small resistor change to bring up the power and lower distortion.
    Aaron
  • ALL212
    ALL212 Posts: 1,558
    Last Bump - next stop is the 'bay
    Aaron
    mhardy6647 Posts: 33,070
    Mrs. H'd kill me...
  • [Deleted User]
    No one wants to try these?
    Marky wants to try them -- Marky's just thinking he shouldn't invest 350 smackers in 'em (even though that's a very reasonable price tag). Marky gets cheap, sometimes.
  • [Deleted User]
    You could always sell off some retirement equipment!
    I could get rid of some of my junk, indeed. But I'd have to find a sucka upon whom to foist it.
    Sorry to the OP for the hijack! :-P Very nice amplifiers; I would indeed love to hear 'em (actually I would love to possess them... but I can't justify it to even myself).
    txcoastal1 Posts: 13,134
    Well Mr.H,
    Mrs.H got a new car ;)>:)
  • TEAforONE
    TEAforONE Posts: 1,006
    How would these work with a passive tvc preamp?
  • mrbiron
    @mhardy6647 what are ya......yella? (In my best Biff Tannen impression)
  • ALL212
    ALL212 Posts: 1,558
    TEAforONE wrote: »
    I don't know why not but give me some more detail on what you have.
    Aaron
  • TEAforONE
    edited July 2016
    its a promitheus tvc,with the 6db option. Speakers are Hornshoppe, Great Horned Heils.
  • ALL212
    ALL212 Posts: 1,558
    I can't make any guarantee's but with the 6db option I don't know why it wouldn't work. That combo probably won't blow the walls down but based on your speaker efficiency I'd say room filling at the least.
    Like the TVC? Always wondered how one would sound...
    Aaron
  • ALL212
    ALL212 Posts: 1,558
    Marky :( ....Marky :'( ... It's only money.... >:)
    Aaron
    It would certainly be worth a try with a TVC or AVC (that's what I use here, albeit with a single-ended, direct heated triode amplifier, plus one extra, outboard voltage amplifier stage).
  • TEAforONE
    i love it. It works great with my Monarchy Audio monoblocks. I've tried a couple active pre's,and found they had way to much gain. Every aspect of the promitheus,fills every need I have.
    Note my signature line, a quote from Gary Kaufman (tube nut and amateur amp designer/builder) with whom I'd had a conversation on a similar topic! :-)
    Every active preamp I've tried made things sound just a bit less real and transparent than without :-/
    I like the AVC I use a lot (but I don't actually know which hardware it is; it's a cheaper Dave Slagle product, I think). It affords an extremely transparent sound overall.
