Nelson Pass Amp Camp Monoblocks
ALL212
More herd...
The Nelson Pass designed all Class A dual Mono amps.
Article here:
http://www.diyaudio.com/forums/diyaudio-com-articles/214808-amp-camp-amp-1-a.html
Built by me from the amp camp amp kit and premium parts were used in place of some of the generic parts. This kit has the best Vampire RCA's (CM1F/CB) and Parts Express Premium binding posts. Input and output wiring is not stock (cotton wrapped copper on the inputs and Vampire wire to the speaker binding posts) and the caps were all replaced with Nichicon. The only change I made was to NOT mount the way too bright LED's in the front panel but instead I used red ones right at the board.
If memory serves I also replaced all the smaller resistors with higher wattage (same ohm value) resistors.
These run on individual laptop power supplies (19v). The minor upgrade has been done on this so it does run a bit more power than advertised.
Asking $350 and will include the power supplies. Buyer responsible for shipping costs. I'll provide packing.
Article here:
Aaron
Enabler Extraordinaire
DAMMMMNNNN bro!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
What's the power output? Good for 4 ohms?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
Nice! must have been fun to build.
5 watts of Class A power. Think of it as a SET tube amp...tremendously clean and a very powerful 5 watts.
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Here's everything to know. Mine are a bit more powerful as I've done the small modification. You can also use more than 19v (up to almost 30 if I'm not mistaken) but it will run significantly hotter and probably not last very long.
Frequency response 10 - 20 kHz +/- 0.1 dB
• Power per channel 5 Watts per channel (That's 92 decibels coming out of your speakers, assuming you're listening from 10 feet away with 91db efficiency speakers. More than 2 hours at this volume level exceeds occupational safety limits, is more than adequate to annoy your neighbors, and certainly enough to enjoy your music at normal listening levels)
• Distortion 0.7% at 1 Watt (primarily second order harmonic which being even-order is described as "sweet, tubey" and being low-order as "benign/inaudible")
• Input impedence 10 Kohm
• Max Gain 14dB
• Damping factor 3
• Output noise 100 uV
• Power supply input 110-240V
• Power supply output 19V 4.74A
• Heat dissipation 20 Watts per Channel
Aaron
Enabler Extraordinaire -
This one was fun - nice and simple. There is a 250+ page thread over in amp camp land with all kinds of detail.
I've built two and am keeping the heavily modified one.
This one is NOT for sale:
Aaron
Wow......I've been contemplating buying and building that kit for a while. Of course you would have it......
I now know who to harp on when the time comes.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
When you get there let me know - I've a secret...Aaron
So these run pretty hot? I realize with only 2 output devices even if they run hot it's probably not that much heat. The Aleph by comparison dissipates 200wpc. So I guess I could assume about 1/10 of the Alephs heat which can raise room temp by about 3*?
What are the dimensions of the chassis? Approx.?
Contemplating a 3rd rig, why?.................I have no idea....lol.
But these are cool and I know the quality of workmanship!
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Can one build a standard (traditional) power supply? I am not a fan of switching walwarts. But I suppose in the scope and spirit of what these are supposed to be, it's perfectly acceptable.
These ran 24 hours a day in my bedroom setup (my radio alarm clock if you would). They get warm - that heatsink is more than enough to dissipate even in a warm room and I never noticed the temperature go up because of it.
I'd guess it's about 4" square by 10" long.
http://diyaudiostore.com/products/amp-camp-amp-kit - a video towards the bottom of that page will give you an idea of the size.
Some folks have built power supplies. I've thunk it - I decided against it. So, yes, One could build a power supply - just not me. Anything that puts out 18 through 24 or so volts DC at around 4 amps should work. That connector at the back of the housing isn't cemented in so if it would need to be changed to accommodate whatever you might use it wouldn't be prohibitive.Aaron
Bump - I'll bump again Friday and then off to the 'bay.Aaron
GRRRRrrrrrrr!
I really want to do this myself...
I like your photo of the BAAC (Big A** Amp Camp) and noticed you completed it 4 years in the future.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
GRRRRrrrrrrr!
... and noticed you completed it 4 years in the future.
I had no idea I had that kind of power...be careful what mods you employ on these kits!
It's an easy kit to do if you can solder a circuit board - lots of room. The new kits incorporate the small resistor change to bring up the power and lower distortion.
Aaron
Mrs. H'd kill me...
No one wants to try these?
Marky wants to try them -- Marky's just thinking he shouldn't invest 350 smackers in 'em (even though that's a very reasonable price tag). Marky gets cheap, sometimes.
You could always sell off some retirement equipment!
I could get rid of some of my junk, indeed. But I'd have to find a sucka upon whom to foist it.
Sorry to the OP for the hijack! :-P Very nice amplifiers; I would indeed love to hear 'em (actually I would love to possess them... but I can't justify it to even myself). -
Well Mr.H,
Mrs.H got a new car2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
How would these work with a passive tvc preamp?See my profile for list of gear.
@mhardy6647 what are ya......yella? (In my best Biff Tannen impression)Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
I don't know why not but give me some more detail on what you have.
Aaron
its a promitheus tvc,with the 6db option. Speakers are Hornshoppe, Great Horned Heils.See my profile for list of gear.
I can't make any guarantee's but with the 6db option I don't know why it wouldn't work. That combo probably won't blow the walls down but based on your speaker efficiency I'd say room filling at the least.
Like the TVC? Always wondered how one would sound...Aaron
mhardy6647 wrote: »Marky wants to try them -- Marky's just thinking he shouldn't invest 350 smackers in 'em (even though that's a very reasonable price tag). Marky gets cheap, sometimes.
Marky ....Marky ... It's only money....Aaron
It would certainly be worth a try with a TVC or AVC (that's what I use here, albeit with a single-ended, direct heated triode amplifier, plus one extra, outboard voltage amplifier stage).
i love it. It works great with my Monarchy Audio monoblocks. I've tried a couple active pre's,and found they had way to much gain. Every aspect of the promitheus,fills every need I have.See my profile for list of gear.
Note my signature line, a quote from Gary Kaufman (tube nut and amateur amp designer/builder) with whom I'd had a conversation on a similar topic! :-)
Every active preamp I've tried made things sound just a bit less real and transparent than without :-/
I like the AVC I use a lot (but I don't actually know which hardware it is; it's a cheaper Dave Slagle product, I think). It affords an extremely transparent sound overall.
