How to blend in multiple subs? Multiple room eq?
WLD I think you may be right. A 4 stack would be good.
Thoughts on JL Audio F113 x4 or F212 x2 or 2 Gothams?Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Another picture with SF Stradivari and REL G1 sixpack.
Attending the show in Chi is the closest I will get to that type of gear but....if I had your money and was a picky as you are, I would have something custom made to match the Strads. I would first grab four of the 15" Rhythmik Servo custom installation kits. http://www.rythmikaudio.com/DS1500ci.html
Then have a cabinet maker build four curved enclosures that have Rel R1, JL Audio Gotham, etc type of shape....or a shape similar to the Rockports....or at least use its shape for inspiration.
Then, do a Piano black finish to match the Rockports and you will have something that none of your buds have!
Post edited by WLDock on2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
Geez...
Crazy
WLD - I see Gothams can be daisy chained. Thoughts? Single auto EQ coming off one sub... Should be an easy install no?
Also looking at the velodyne dd+... It has servo... Any good?Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Conventional wisdom in the sub world is that you pay more for similar performance when going store brands vs Internet direct. I would be shocked if velodyne did anything better than threw rhythmik equivalent.
Geez...
Crazy
Or even do the Seaton Sound Submersives...two masters and two slave units.
http://www.seaton-sound-forum.com/post/product-listing-availability-status-and-pricing-3366417
http://www.seaton-sound-forum.com/post/finish-options-a-collection-of-photos-4292198
Mark Seaton was a part of a massive and crazy expen$ive Rockport Arrakis build....they used three Submersives!
http://www.whatsbestforum.com/showthread.php?7501-Seaton-Submersives-amp-Rockport-Arrakis-amp-Mira-Grands
***Great read on page three. He has the curves of all three subs. The rear location was much better then the front two. he shows the correction, and the final graph. Great info about how placement in the room can make a dramatic difference and DSP is a must to really dial things in. ***
The DD+ is legendary...can't go wrong there...they are just pricey. Would do several Servo Rhymiks over a single or dual for the money.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
Would have to pounce on a good deal WLD...
The SVS SB13U can be had for about $1400 out the door with tax.
The Gothams and Fathoms, I would have to contact my guy in Florida to see what he can do, it would have to be freighted to me.
I need an elevator in the new house if I don't get a first floor media room.
re Mark Seaton, I've met him for dinner once... he's a nice guy.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Here's one for $3550: https://www.audiogon.com/listings/subwoofers-jl-audio-fathom-212-gloss-subwoofer-2016-07-12-home-theater-60610-chicago-il
a couple in the $4300 range: http://www.ebay.com/sch/i.html?_odkw=Fathom&_osacat=14990&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=Fathom+F212&_sacat=14990
But no one wants to ship these things. A pallet would be the only way...14.92 in x 31.96 in x 20.39 in - 224 lb each!!! Yeah, you could use a freight elevator!
Another sub that seems very nice and looks very high end is the MartinLogan BalancedForce dual opposed products. They even offer the Perfect Bass room correction kit. However, the pricing is a bit steep....$3995 for the 12" model. https://www.martinlogan.com/balancedforce/index.php
https://youtu.be/7BjAsK2xqjY
The only problem I have with those dual subwoofers like the Gotham or F212 is the size.. it's truly a pain to lift 200+lb items upstairs... I am seriously needing a first floor media/stereo room in the future or an elevator because this is ridiculous.
I do like the 4 SVS SB13U, especially if I can room correct them.
Otherwise, F113 would be a solid choice x4.
A Couple Velodyne DD18+ would be great choice too.
I am not really afraid of shipping, I have contacts who ship Rockports and Wilsons, Adcom Freight, easy to ship. Call them once, they pick up the pallet.... I swear it is easier than shipping fedex and I don't get the PFB issue.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Of note, problem with ML BF is the size... it's seriously the size of a table.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
errorMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
Geez...
Crazy
That picture is just crazy. The amount of work that goes into that system is just nuts, both in the logistical sense and financial sense. Props go to that guy for sure. Next level.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
SVS, JL Audio, Velo DD all great choices....and in multiples? I'm sure two of any of those would do it for music. However, four stacked would ROCK the you know what out of even a 20'x25' room for music! A coupling gain as high as 6 dB is possible under the best conditions. You might become a fan of organ music?
http://www.soundandvision.com/content/deepest-bass-ever#xWua3ytR2hzTSEeX.97
Camille Saint-Saëns’ Symphony No. 3,
I love to play the Toccata and Fugue in D Minor from time to time at levels that shake the walls...LOL!2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
Yeah I've been reading lots of reviews on the SVS SB13U, it is a mighty sub. That dsp system is very tweakable. Not even sure I need full room correction, but still might.
That internal room correction with the JL Fathoms just might take the cake.
Rels G1 has a speaker level input that just makes it respond faster than either JL or SVS...
So many choices.
But I agree, I want multiples... A wall of bass.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Joey,
What are your room dimensions? What is the cubic feet? This really needs to be considered. It's not all about what you can cram in the room.
Your thread name is "How to blend in multiple subs? Multiple room eq?"???? Keep this in mind. It is about the blending.
I really never considered subs in 2 channel until the Wilson demo at RMAF will the Alexandria's and the Thors. The presentation was really good.2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
is this for your 2 channel system?
For my small living room 2 channel setup a little 8" non-ported sub works fine and most of the time it isn't turned on and it works better then the 12" SVS I use for HT.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
txcoastal1 wrote: »Joey,
Exactly... a sub can work in a 2ch setting.
The room right now would only need the subs on at the lowest possible setting if I go multiple.
The room of the future will be big. 25x20 or 30x25 dedicated, probably 10 foot ceilings. Likely main floor, or I will need an elevator if in the 2nd. This stuff is getting heavy.
is this for your 2 channel system?is this for your 2 channel system?
Yeah, but if I have too many subs in the room, I can always branch out. Probably need a single SB13U in the family room. Or 2.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
The more I think about it, the more I kinda want that Gotham @WLDock ...
2 of them flanking the speakers, one can be slaved to the other. Both have calibrated mics. Easy set up.
Only thing hard is the lifting lolMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Is the SVS ported?
I'd assume the sealed is quicker and better for music.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
I don't know when/If I will make it back down that way. I missed a flight to Belize last year and had to stay a night in Houston...thats one of the few times I've been in TX for flights layover, transfers, etc.
Look, there's a couple of used ones on ebay for about the cost of a single new one. The used 2011 Buick LaCrosse CXS w/Touring package, black leather, moonroof, navigation, etc was less money...LOL!:
http://www.ebay.com/sch/i.html?_odkw=&_osacat=14990&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=Gotham&_sacat=14990
Speaking of TEXAS...WHO LIVES IN AUSTIN? Joey, txcoastal1, Skip, anyone? Bueller? Bueller?
There's an amp on CL that I'm looking at. Anyone willing to do the legwork, pack and ship?
Sorry to derail Joey....
Not mua, Galveston County here
Skip, Halen, and Joey are Dallas area2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Looks like the guy might be willing to ship so I might be OK.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
Ha... we will have to see how next year goes and if the wife lets me. At the very least, I would want 2 or 4 SVS SB13U.. depending on how it sounds in my friend's place.. he is placing an order for 2 SB13U as of right now and I will get to demo it. We have similar speakers.
He actually has a better preamp. And he has a bigger room.
Emm Dac2x/TSDX transport into Audio Research 5SE preamp.
The house needs an elevator or a first floor media... it is way too difficult to keep hiring piano movers to move these things. It's a pain in the butt... first I gotta find a piano mover willing to move a non-piano item, then I have to find one who also can insure the product being moved.. it's not easy. And it was near impossible for them to move the Rockports in the crates.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Surprised nobody has mentioned Funk Audio. They are in another league compared to JL in my opinion. Ditched my F112 for a Funk and never looked back. Plus, plenty of choices for finish.
We don't often discuss subwoofers of this caliber on this forum, given that only rarely do subwoofers come up, and SVS seems to be the brand du jour here.
I agree with you that Funk Audio looks very worthy of consideration, though Joey may prefer the known quantities of SVS and JL Audio, which are certainly more established entities. -
Joey loves Canadian brands funk audio is a brand that needs to be brought up more. Great subs and even better finishes.
Svs is brought up so often here because it is a proven brand, tested, tried, and true. Plain and simple. For a polk site, there is a lot of non polk brands in discussion.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
I live pretty close to Austin. Close enough that I just spent 16 hours driving around and fixing air conditioners.
I can help you out.
I can help you out.
WLD - are you buying the Gotham??
Do eet!!Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
