RTA-11t problem
Ha!, that is nothing. Wait till I get the carver 1.0 I used to own a pair of monitor 10b's that I bought new in 88', those things were awesome. Had a new carver 1.0 just on the verge of clipping, they never failed. Damn, those were the good old days.
Yeah, they don't clip, they just blow up.Political Correctness'.........defined
President of Club Polk -
I still feel it's impedance or the amp itself. Are the other speakers you tested 6 ohm or under? I know if I drop my impedance by half I cant even turn up a quarter of the way without clipping.
I figure if it was crossover issues you would hear it.
If it was the internal wiring causing a short it would happen regardless of the amount of volume.
If it is the speaker wire going to the amp grounding out that'd be easy noticed.
IMO I think it's over driving or internals in the amp.
I am NO audio expert by any means but running through different issues I've had, those are my 2 cents.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
yeah, you are probably correct. It's just strange that the other speaker does not trigger the relay. Thanks.
Who knows, maybe that one is functioning correctly and the crossover that I say is good may have a problem. All the more reason to get them rebuilt.
If i run my Yammy at 10:30 on the dial my brain is getting beat up. I cant imagine going above 12:00. Id be worried about my ears let alone my gear
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
10:00 is plenty for me too. Any louder than 11 or so and my SDA's start sounding like garbage anyway, and that's with 350 watts.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Dang is that black lacquer on top?Just a dude doing dude-ly things
Yes & they are spiked now & not so close to a wall. Gives the rear passive room to breatheRandy-Maine
by David WMG
Ugh. I want the 15s.Just a dude doing dude-ly things
I want the 11's but wife say NO lolRandy-Maine
by David WMG
It's a sheet of gloss black acrylic. You can pry it off from the rear with a putty knife. When I restored a pair of RTA 15TL's I replaced the tops with slightly textured matt black tops as the smooth gloss ones get scratched way too easily.Political Correctness'.........defined
My wife hasn't told me no yet but I've also not fallen into the rabbit hole yet.Just a dude doing dude-ly things
btw i enjoyed reading you archived threads. I would love to get my ears on some 11's someday. To the op - i hope you get the issue fixed. The 11's are well loved around here.It's a sheet of gloss black acrylic. You can pry it off from the rear with a putty knife. When I restored a pair of RTA 15TL's I replaced the tops with slightly textured matt black tops as the smooth gloss ones get scratched way too easily.
Randy-Maine
by David WMG
if you want to here your polks sing put on The cars "Candy-O"
That's a lot of reading....LOLI would love to get my ears on some 11's someday.
I take it you mean the Model/Monitor 11's? They are basically Monitor 10's on steroids with a clearer midrange.
codycadalist, I bought the rdo-198-1
Sweet! Make sure to upgrade the crossovers to allow those tweets. Stock they accept the RDO194Just a dude doing dude-ly things
F1Nut wrote:To convert an RTA 11T model to "TL" status you would have to change one inductor from 0.4mH to 0.3mH, change one resistor from 2 ohm to 1.5 ohm, change one cap from 12uF to 16uF, remove the poly switch, remove a 2.7 ohm resistor and change the tweeter. Not impossible, but probably not worth the cost.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
it currently has sl3000 tweeters.
i read alotbtw i enjoyed reading you archived threads.
... nope i ment RTA11's ive never heard. Ive owned the Monitor 10's & 11's w/peerless tweets that sounded very good
Randy-Maine
by David WMG
I thought the rdo-198 replaces the sl3000
Derwood, look at schematics posted here for both versions, then compare to your speakers. You could very well have the TL version as Polk was known to use up stuff from the previous model.Political Correctness'.........defined
my speakers say RTA 11t. The crossovers are dated 1990, there is only one rectangular resistor directly under a capacitor.
F1nut, thanks.
There's also a chance that a previous owner incorrectly replaced the tweeters at some point in their life. Looks like you have some research to do.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Check what the model number is on your upper passive. If it's SW83 it could be the TLs.Just a dude doing dude-ly things
Randy-Maine
by David WMG
In that case, you have the TL version.
